Question about Miele Novotronic H350-2B Electric Single Oven
Oven is not heating after new install - Miele Novotronic H350-2B Electric Single Oven
How do i set up brand new oven , the fan comes on but no heat
If your oven is brand new, just check if it's properly connected.
You are not supposed to set up ovens, . Ovens are not as smartphones or computers. They are supposed to work when you install them.
So if it won't work, call warranty service
Oct 31, 2015 | Ovens
Belling xou69 mf fan working oven not heating up
probably needs a new heating element, easy to install
Feb 05, 2013 | Ovens
How do you replace the bottom heating element
Turn off power to oven, remove two screws on heating element mount, pull heating element from wall of oven, remove two screws connecting electric leads to heating element.
To install new element, reverse steps. Make sure screws connecting heating element to wires are very tight -- otherwise they will arc.
Charlie
Jan 09, 2011 | Ovens
Removing oven element to install new one
Turn power off at service panel (220 volt circuit breaker). Remove screws from heating element mount on wall of oven. Pull heating element from wall of oven far enough out to see the where the wires/lugs are screwed to the heating element leads. Remove these screws. Replace element. Make sure screws on heating element lugs/leads are tight -- if not tight, arcing will occur.
Charlie
Jan 08, 2011 | Ovens
No heat to the oven
if the heating element "rod" doesn't turn orange (hot) when it's on it's bad so; remove the heating element and get a new one from an appliance parts site on the web and install it don't forget to unplug the range first!
Apr 20, 2009 | Vulcan ECO2D Electric Single Oven
My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not...
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning features are not recommended by most appliance technicians.
Self cleaning causes parts to fail often.
Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Bottom oven not working
If its brand new, most possibly the electrician did not bridge the mains connection. It sounds like an installation fault. There is usually a jumper between 1-2-3 on the L connection on the mains, and a jumper between 4-5 on the N connection. Oshie
Nov 27, 2006 | Gaggenau EB294/295 Electric Double Oven
Miele Novotronic H350-2B Electric Single Oven Logo
32 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
