Question about Linksys Wireless-G WRT54G Router
Unable to connect PS3 to linksys wrt300n, key exchange timed out, signal 100% and key is correct?
I have Linksys WRT300N, and currently there are multiple devices connected to it and they all work great (this laptop, two phones, a smart TV, and an iPad) and connected with ease. However my PS3 will not, and I can't for the life of me figure out why. I've tried different settings on both router and PS3, it can detect the network and has 100% signal strength. It just times out trying to exchange the key info (WPA). Please, any help would be great.
  • Linksys Master
  • 32,281 Answers
For instructions on setting up the PS3, Xbox, or Wii, for a wireless/Internet connection. please click on this link :- http://fixhomenetwork.com/xbox-play-station-wii.php
Posted on Dec 09, 2012
  • 1 more comment
  • Robert C
    Robert C Dec 30, 2012
    I tried using the link provided and still no positive result. I did manage to connect though, and all I did was disable the wireless security from a WPA-WPA2 Personal. Asssuming all settings are identical between the disabled and secured method, what is the problem? I'm not that tech savvy and I'm at about my limit of knowhow on this.
  • Chris Hingee
    Chris Hingee Dec 30, 2012
    By disabling the wireless security it opens your wireless network for anyone to use your internet connection.
  • Chris Hingee
    I recommend you enable WPA2 encryption again and configure all your devices with the wireless WPA2 encryption setting.To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router. Connect a LAN cable from the Linksys to the LAN port on your computer. Open a browser and enter the Linksys configuration URLhttp://192.168.1.1 The default login = admin The default PW = admin You can protect your router by changing the default admin PW (write it down and put it in a safe place) Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access. Now apply these settings to the wireless card in your laptop/computer. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wi...
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
rohitraiden
SOURCE: Support
Try these steps:
1. First of all connect your PC Directly with Modem & check if you're able to go online or not.
2. If No , then contact your ISP.
3. If yes ,Disconnect CAT5 cable coming out of Modem from PC & connect into WAN port (on rear panel you'll find it) of Linksys WRT300N Router , After that on rear panel you'll find small hole with a Reset button inside it. Use needle or pen to press it quiet hard for 1 minutes continuosly, This'll restore all default settings.
4. After that give static IP - 192.168.1.2 to your PC ,subnet mask 255.255.255.0 ,default gateway - 192.168.1.1 & connect your PC directly with a LAN port on the back side of Router.
5. After that type 192.168.1.1 in the address bar of your explorer & login window will come , type username = admin & leave password field blank, then you'll get Blue coloured Router configuration page, From this page you can configure your Router.
6.Now if your Internet connection is Cable then default setting will work for you, However for DSL connection ,on this page you'll find internet connection type - selectiondrop down box - select PPPoE into it for DSL connection.
7. After that restart your computer & you should be able to go online.
Posted on Jan 07, 2008
Happy2Help
  • 59 Answers
SOURCE: Cannont connect 3rd laptop to Linksys Wireless router WRT54G
Hi taejardine,
Try logging into the router to see whether the Wireless MAC Filter is Enabled. Since you already know that the DHCP limit is set to 50, I presume you've already logged into the router successfully. The Wireless MAC Filter is on the Wireless tab (the second tab, next to Setup), and is the third parameter from the left.
If the filter is enabled, simply add the MAC ID of each of your devices to Permit list (this won't affect your friends' use of the router).
If both of their devices work, and none of your devices work, then the odds are pretty good that the MAC ID Filter is the culprit. I hope this helps - please let know if I can be of any further assistance.
Kind regards,
H2H
Posted on Dec 16, 2008
Joed911
  • 4338 Answers
SOURCE: WRT300N wont connect wireless
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 01, 2009
Yomitako
  • 70 Answers
SOURCE: WRT300N Router Issue
What I would recommend, would be to give the router a factory reset. To do so, you'll need a paper clip first. On the back of the router, you should see a pinhole-sized rubber nub of a button labeled reset. To reset, unplug the router from power, then press and hold that little reset button in, and plug the router back into power (you might have to do some nifty acrobatics for this one, or get a friend to give you a hand). Keep holding the reset button in for about 20 seconds, and let go. If I recall, you probably won't see any real indication on the router itself that it worked, however, you should be able to log back into the router manually, and set your connections back up again, in the event that the settings may have become corrupted somehow. If this doesn't work though, then there may be further problems, in which case, you may need to get onto Linksys' website, and download the most recent firmware for your model of router, and then try setting it up again. If that doesn't work, then the router may be experiencing some kind of hardware failure, in which case, if you are within the manufacturer's warranty, contact Linksys for repair or replacement (or through your place of purchase). If you are not within warranty, then buying a new replacement router may be your only other option. Hope this helps!!
Posted on May 22, 2009
Am using Linksys WRT300N v1.1 wireless router but all LEd are glowing except power led. and i am unable to connect through wired ethernet ports and also wireless is not working.
Try to reset the configuration of your router from the reset button and try that you getting the console with its default username and password.
Jun 18, 2011 | Linksys WRT300N Wireless Router
WRT300N: does not boot, all leds are lit
Solution 1.
How can I reset the Linksys WRT300N to factory defaults?
Hold the Reset button on the Linksys WRT300N for about 30 seconds.
What is the IP Address, Username and Password to log in to the WRT300N?
IP Address: 192.168.1.1
Username: none
Password: admin
You should also know the configuration of your ISP provider after reset. You'll need to re configure your connection from modem to router.
Solution 2
How do I upgrade the Firmware on the Linksys WRT300N?
# 192.168.1.1 -> Administration tab -> Firmware Upgrade sub-tab. Click "Browse" and browse to the firmware upgrade file on your computer. Click "Start to Upgrade". Do not reset or power cycle unit while it is upgrading.
Username: none
Password: admin
Apr 10, 2011 | Linksys WRT300N Wireless Router
Linksys wrt300N wireless light not blinking
the wireless connections says limited or no connectivity when it does not get IP address from the router.
There might be problem with the wireless settings of the router.
if your network is a secured network then you will need to check the network key.
You can try to upgrade the firmware of the router. that will be a good option.
Click Here for step by step solution
Oct 29, 2009 | Linksys WRT300N Wireless Router
How do you connect the new PSP Go to Linksys WRT300N router?
On the PSP make sure the WLAN Switch is turned on. To connect to your router, go to System Settings > Network Settings > Infrastructure Mode then select the Network that you want to connect. If it's Linksys, select Linksys and press X. Select Scan and choose the wireless network and Enter. If it asks you for network key, type your wireless network key and connect. That should do it.
Oct 06, 2009 | Linksys WRT300N Wireless Router
WRT300N is no longer detected
Hook up your ether cable to a port other than the WAN port.
Type this into a browser...
http://192.168.1.1
Linksys WRT300N Wireless Router. ... Default IP address: 192.168.1.1
Oct 01, 2009 | Linksys WRT300N Wireless Router
Linksys Wireless WRT300N
Try going to the configuration page and check if it is sending a wireless signal.
Dec 24, 2008 | Linksys WRT300N Wireless Router
Need the driver for Linksys WRT300N V1 ... can't find the CD
The LINKSYS WRT300N is a standalone device, there are no software/driver needed on your PC for the router to work. However, there is an easy Setup Wizard that is in the CD that normally comes with the unit.
Unfortunately, Linksys did not make the specific Setup Wizard (Version 1.3) for the WRT300N available online. However, if you care to try the Setup Wizard for a WRT54GC, it may downloaded from the LINKSYS ftp site here. I used to have a WRT54G and I did make use of the Setup Wizard for that model. I upgraded to WRT300N. The setup wizard for the old WRT54G worked likewise on the new WRT300N.
Alternately, the WRT300N can still be configured without the CD or the Setup Wizard by logging into the Configuration Page (192.168.1.1). Remember to use LAN interface when setting the router (as shown in the connection diagram) and set your PC to an IP Address of 192.168.1.2, Subnet Mask of 255.255.255.0; Follow on screen instructions and enter settings/configurations manually.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information. Additionally, if you still prefer to have a copy of the original WRT300N Setup Wizard, pls include your email address that I may send it to you as an attachment.
Good luck and kind regards.
Nov 24, 2007 | Linksys WRT300N Wireless Router
Linksys Wireless-G WRT54G Router Logo
126 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
