Question about HP Scanjet 5590 Flatbed Scanner
HP Scanjet 5590 nothing showing in Scan to box
This problem only arises when using the HP software. If I used windows to scan it works fine. I need the HP software to be able to scan to a PDF. I've reloaded software, made registry modifications as per the HP website and nothing seems to work. Any guidance would be appreciated. I'm running XP pro w/ SP3.
    Problem Solver:
  • 8 Answers
Go to control panel and start using the scanner from their it may work
Posted on Jan 12, 2009
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
Scan documents to PDF
Use the HP scanjet 5590 software that come with the scanner. There will be an option in the software to scan it up and turning it to a .pdf
If you don't have the CD, you still can download it on the HP's website
Feb 28, 2011 | HP Scanjet 5590 Flatbed Scanner
Is there any software for scanning can use with this scanjet 5590 with win 7...it seems i cant install hp photo and imaging software on my win 7 machine..help me..
Try downloading the latest software from HP: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=377691&lang=en&cc=us&taskId=135&prodTypeId=15179&prodSeriesId=377689
They list Win7 versions of the full software issued Dec 11, 2009, as well as just the basic drivers. However, if you installed the scanner using the generic drivers in Win7, you should be able to scan using Windows Fax and Scan or Paint. (In Paint you bring in the images as if they were on a camera.)
I hope this helps.
Feb 09, 2010 | HP Scanjet 5590 Flatbed Scanner
HP Solution Center does not recognize the scanner anymore... We are operating on a Windows 7 system... the drivers had to be downloaded from the internet because the cd that came with the printer was for...
I had the same problem and solved it. I was using HP Solution Centre to run my HP Scanjet 5590 on Windows 7 Pro 64 bit without problems. Then I ran the scanner using Windows Fax and Scan, but didn't like it, so went back to HP Solution Centre - whereupon the scanner was not recognised.
After hours of reinstalling software etc etc, without success, I suddenly noticed four device icons on the left hand side of HP Solution Centre. These were labelled (when hovered over with the mouse) hp scanjet 5590, hp scanjet 5590 #2, hp scanjet 5590 #3, hp scanjet 5590 #4. Only the top icon was active, but when I clicked on any of the four it moved to the top.
Clicking on hp scanjet 5590 #2 gave me a working installation once more - problem solved. No doubt the multiple icons arose from my desperate attempts to try different USB ports.
Feb 02, 2010 | HP Officejet 6500 Wireless All-in-One...
My scanjet 5590 was working ok, but suddenly stops scanning right
try reinstalling the scanner softwares and if this doesnot help do a master reset of the scanner
Jul 22, 2009 | HP Scanjet 5590 Flatbed Scanner
HP 5590 - cannot scan and save doc directly to jpeg format
I need the scanned documents be saved as pdf in HP scanjet 5590
Apr 27, 2009 | HP 5590 ScanJet Flatbed Scanner
HP Scanjet 5590 scans inmage on other side of paper on ADF Ok on flat bed
Really strange! May be the brightness is not controlled in the ADF mode, too bright to scan data on the backside also. Try reinstallig the software.
S. Mohan
Aug 18, 2008 | HP Scanjet 5590 Flatbed Scanner
ADF
1- reinstall drivers
2- Use the WIA driver for Windows OpSys
3- Pay close attention to options in dialog box. Select ADF or Document Feeder as an option
4- Depending on the OCR application [personally I prefer PaperPort] the imaging process can be very eaasy or somewhat difficult
Jun 02, 2008 | HP Scanjet 5590 Flatbed Scanner
Blank Scan from HP Scanjet 5590 Flatbed Auto Feed
Scanning is possible in 'Text' mode and 'Picture' Mode. In text mode, which is simple 'Black & White", this can happen, particulalrly if the text is in color. Either you increase the contrast settings or scan the document in Grey/color and convert it to B&W using the software. By this you need not check if there is output!. ( I am assuming that otherwise the scanner is performing okay). File size in B&W is very small as compared to Grey/color.
S. Mohan
Apr 04, 2008 | HP Scanjet 5590 Flatbed Scanner
HP Scanjet 5590 Flatbed Scanner Logo
353 people viewed this question
Ben Johnson
