Question about Ovens
Eloquence by Gaffers and Sattler
Pilet light on but will not work
4 Suggested Answers
SOURCE: HEATING ELEMENT GAFFERS & SATTLER BUILT-IN
our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
Posted on Nov 22, 2010
SOURCE: I have a 1965 gaffers
My Mom has a 1965 Gaffler & Stattler Mark 21 wall mount oven, it had the "Same Problem", People may tell you that the flame switch is no longer avalible but I found a universal fit flame switch at Applance Parts Center, I took the old part in and had it matched up, with a minor modification to the thermal sensor mounting bracket, "drilling a larger hole and lightly crimping it", it's a perfect fit, "problem solved". You may want to try cleaning the pilot light area with a small wire brush first, if that dosn't work try a jumper wire on the two terminals of the flame switch, if that works then replace the flame switch.
This operation can be done without removing the oven from the wall mount, just remove the two screws from the panel at the inside rear of the broiler, you will find the flame switch behind the panel it has two screws two wires a thermo leed and a sensor tip that goes up to the thermo sensor mounting bracket above the pilot light, the thermo sensor mounting bracket has one screw and a nut behind it, you will also need to remove one end of the 1/4" pilot gas pipe in order to remove the thermo sensor mounting bracket, When your done puting it back togather, check for gas leaks using soapy water in a spray bottle, a dish soap solution works great, also check your vent pipe connections.
After I cleaned the dust and grease out of this old thing, the 45 year old clock and timer started working again.
My Mom is very happy, try and find new oven to fit the cutout and vent, we saved a lot of $$$,
"Good Luck".
Posted on Jan 06, 2011
aviral_srms
  • 1216 Answers
SOURCE: I have a Gaffers and
Sounds like the oven ignitor is weak. If everything else is working it must be a bad ignitor. These are usually easy to replace and can expect to pay $70-$100 for the part. Check to see if it glows when in bake mode first. If it does then replace the ignitor. You can look at the ignitor, when not on, if it is white-ish then it needs replace or if it doesn't have a full glow, can compare to broil ignitor, then it needs replaced
Posted on Jun 28, 2011
How do I turn off the timer on my gaffers & sattler wall oven?
Try rebooting the oven; unplug it for 90 seconds, or flip the circuit breaker off for 90 seconds, then back on.
Apr 17, 2016 | Ovens
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
Oven won't light
ck thermal coupling see if its to far from pilot light or burnt out
Feb 18, 2012 | General Ovens
I cannott get oven to turn on, asssume it is with the timer as light & grilll work. Model no 6381902
Light and grill work. I assume that the oven indicator wont light when you turn the oven on. If so the timer is probably in automatic mode. Set the timer to manual mode and the oven should work. If the indicator light is coming on at the moment the oven element is probably faulty.
Feb 11, 2011 | Ovens
I have a 1965 gaffers & sattler wall oven with the oven on the top and the broiler on the bottom. It began having issues lighting even though the pilot light was on. Now the burner doesn't light up at...
"Good Luck".
Nov 18, 2010 | Ovens
Repair or buy new oven.
replace the element....they are not that expensive.
Jul 20, 2010 | Ovens
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
Ovens Logo
62 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
