Question about Sony STR-DA4ES Receiver
My reciver a4es goes in to protect mode after disconect all the speaker wires
No noise
5 Suggested Answers
  • 13 Answers
SOURCE: SONY STR-DE125 READS PROTECTED
protection is designed to protect the output transistors from, shorted speaker wires, shorted speakers, too low speaker impediance,make sure the amp is well ventilated.
turn the amp off for 1 to 2 hours to allow thermal reset if this fails most likley some internal damage has occured and the unit will need to be serviced
Posted on Sep 02, 2009
  • 336 Answers
SOURCE: soon as i turn power on my sony receiver goes
Resetting probably won't fix it, Sounds like it needs output transistors and some resistors and/or fuses
Posted on Nov 29, 2009
  • 4234 Answers
SOURCE: won't go off protect mode
When the speaker wires shorted to each other, the output transistors for that channel probably shorted as well. This means that the receiver needs repair. The typical parts cost for this usually runs between $20-$40.
Dan
Posted on Feb 18, 2010
  • 360 Answers
SOURCE: Sony STRDH800 emits a loud
Check the source of humming noise. Disconnect the input cables of source one by one. A faulty source should be found. It may be the source or the cable connecting from source to receiver. If a faulty cable, replace it & if it is source, repair it. Also try connecting a separate earthing for the receiver. A separate earthing stud is normally provided in receiver for separate earthing. If none of these solution work then you will have to look inside the receiver for loose earthing from various PCB's especially preamplifier.
Posted on Aug 03, 2011
Protection mode
Try tapping it on the top or sides with your hand or fist, I was told this buy a body of mine, That has been a (Electronic) Tech for over 20 years now, Tap it fairly hard,It has work for me with recievers And amps to get them out of the (Protection mode.What causes them to go into (Protect) Is a short in a speaker lead or the speaker wire come disconected some how,Or there could of been a power surge.
Oct 04, 2012 | Yamaha RX-V1400 Receiver
My JL A6450 won't leave protect mode
there has to be a short in your wiring start by disconecting the speakers and see if it goes off
Jun 19, 2010 | Jl Audio A6450 Car Audio Amplifier
Reciver is going to protection mode and sound turns off
is some speakers is defective, or not present (connected), check all cables
Jun 06, 2010 | Harman Kardon AVR 340 Receiver
No audio sound, Reciver going to protection mode
If you bought the extended warranty, you need to go where you purchased it and they can look it up on their computer system. If it's out of warranty, the repair cost is debatable. Between 125-175 average. 50% of the cost.
Jun 03, 2010 | Harman Kardon AVR 340 Receiver
Reciver goes into protect mode as soon as I turn it on.
Remove speaker wires and try again. If it still goes into protect mode, the problem is internal...shorted power transistors or some other fault. Check fuses also.
Apr 01, 2010 | Harman Kardon HK 3480 Receiver
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
Is in protect mode
I don't have and I'm not familiar with this particular receiver model, but common sense tells me that your receiver is trying to alert you to the fact that you may have shorted speaker wires, and it has gone into protect mode, to prevent itself from blowing up.
Please check your wires at the back, or best yet, if your receiver has a test mode on the remote control, use it. It tests your speaker connections for shorts, for wrong polarity, etc. If this receiver has surround sound, and all speakers are connected, it goes round and round creating some white noise from all speakers as it goes, until you press the Test button again.
Should one or more be connected improperly, or the wires be shorted, it will display a message telling you so.
Aug 21, 2009 | Sony STR-DE485 Receiver
Amp in power protect
Protection Circuit is bad. It needs to be serviced. If all speaker wires are disconnected and it's still in protection, it's got a problem. Hope this helps
Aug 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
The amp turns on but goes to protection mode
Have you checked the REM wire, if it is the wiring may have gotten fried.
Or you may need to get new parts replaced within the amp.
Both issues happened to me.
Mar 27, 2009 | Car Audio & Video
Turns it self off with a sparking noise in the speakers
The unit has a built in protection mode if a fault occurs in the speaker wiring. If its in protection mode the power button light will flash and display goes blank. Try disconnecting all speakers and see if it stays on, if so it could be a shorted speaker wire or bad speaker.
Dec 23, 2007 | Denon AVR-3805 Receiver
Sony STR-DA4ES Receiver Logo
29 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
