Question about iLO (2 GB) MP3 Player
Flash error ilo mp3 player
Ok i got the new medis player update and everything was goin fine..then when i tried to go to the link in ur fix it instructins..the link dont work..it keeps sayin page unavailable. so now what do i do i tried pastinin in the addy but it still wouldnt work..could u please send me a new link or addy to go to to get the firmware...thanks.
  • 8,596 Answers
Try one more time, as I was just able to view it (Note: the link will not work if you do not have a default program set to Unzip files).
https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip
-Tha Mp3 Doctor
Posted on Jan 13, 2009
Flash Error!
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable.
2. Open Windows Media Player.
3. Go to the Sync or Devices tab and delete all content from the player.
4. Go to the Tools menu and select Options.
5. Select the Devices tab, highlight the ILO or Siren player and click on Properties.
6. Uncheck the box "Create Folder Hierarchy on Device"
-Tha Mp3 Doctor
Sep 27, 2008 | iLO (2 GB) MP3 Player
Ilo Mp3 player
Remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted. On the iLO, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the iLO will remain off during this time, making the screen appear to be blank. An hourglass should appear on you computer and Windows should say, "Found new Hardware 'SMTP3500". Launch the Rave-MP firmware update program (Start>Programs>Rave-MP> Firmware) Click "Get Firmware". Select "iLO256" and let it download new firmware. Click "OK" when prompted. Click "Update Firmware". It will now search for the iLO. This may take a while depending on how corrupted the firmware is, so be patient. After it has found the iLO, it will say, "A device has been detected in recovery mode and is being initialized. Please wait." The iLO should come back to life and start showing it's glorious "USB Connected" screen. The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start". It can take anywhere from 2 to 4 minutes to re-flash the iLO and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the iLO! Why are you still reading this? Great, did something happen? Well, If the program fails to find the iLO and gives you an error like, "Device Timeout" or something similar, you need to reinstall the iLO drivers. This can be done by inserting the iLO cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again). Plugging it into a new USB port is the fastest and easiest option though. Also check the following link for there FAQ: http://www.uiss.6x.to/ Good Luck
Sep 18, 2007 | iLO MP3 Player
ILO 2GB MP3 Player
reformat it using itunes software
Sep 10, 2008 | iLO (2 GB) MP3 Player
Flash error ,back up data and format the player
it keeps saying format the player and back up the dta
Sep 04, 2008 | iLO (2 GB) MP3 Player
Flashing ilo.
I found that connecting the MP3 player to the computer with the patch cord causes the player to reset and eliminates the problem. It only takes a few moments,just disconnect when the pc tells you it is safe to remove the device.
Jan 19, 2008 | iLO (2 GB) MP3 Player
Won't Play
i have the same problem and mine wont turn off in less i take out the battery it just keeps on flashing the ilo logo if some one knows how to fix it or how i can contact the manufacture (i lost my instruction book) it would be greatly appreciated.
Jan 15, 2008 | iLO (2 GB) MP3 Player
Ilo won't turn on.....
Sep 18, 2007 | iLO (2 GB) MP3 Player
MP3 ilo
You should backup your data and format the player. Plug her in, copy your music onto your computer, then format it by right clicking the drive in My Computer, then going to Format, then clicking Start. After it's finished, copy your music back over to the player and it should be sorted.
Sep 07, 2007 | iLO MP3 Player
My iLO MP3 wont download anymore
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Aug 11, 2007 | iLO (2 GB) MP3 Player
Restarting
OK it may be the Battery ensure it is "Fully Charged". Take Batt out and replace it again, sorta to "Reset it". If the Batt is OK and it is still "Faulting" then return it to the manufacturer for repair/replacement.
Jul 31, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
37 people viewed this question
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
