Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool bleach tray doesn't drain - Whirlpool Duet GHW9150P Front Load Washer
4 Suggested Answers
scottludwig3
  • 4 Answers
SOURCE: bleach dispenser does not drain water
i just had the same prob i took off the top snap cover for the bleach and saw were the water goes out and it was clogged cleaned it out and it drains great again
Posted on Nov 17, 2009
backwoodsctr
  • 169 Answers
SOURCE: whirlpool duet washer, bleach does not come out of
Calcium deposits have accumulated in the reservior. Try running some CLR through it
Posted on Nov 23, 2009
  • 29 Answers
SOURCE: I do most of my
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
Posted on May 13, 2011
How to unclog Whirlpool Cabrio Washer Bleach Dispenser Full of Water?
hot water will be safe yes u can remove the dispenser but may be a bit difficult to figure out it should just snap and pull out once disconnecting the hoses
Mar 17, 2015 | Whirlpool Dryers
Kenmore front load 110.46462501 mid cycle all lights flash won't drain
Check your drain pump/filter may be located bottom right of machine/hold drain hose over bucket with around 2 feet from floor level should pump if no blockage....Remove any blockage .hope this also solves tray fault
Jun 27, 2012 | Kenmore Front Load Washer
We don't have access to the back of fridge as it is fitted. what happens if we put bleach or milton into the drain-hole?
You can pour a 50/50 mix of bleach and water down the drain hole, but I wouldn't stop there. If you take off the front grill of the refrigerator, you will see the condenser coils with a tray under it. This is where things from the drain hole ends up. If you have a small long handled brush you might be able to clean it out.
Jan 02, 2012 | Liebherr Refrigerators
The bleach doesn,t empty out. Both it and the fabric softener stay full of water.
This is a common problem with many machines.
I suspect that it is the conditioner/softener tray which needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Bleached out streaks on my clothing. After running a bleach cycle, the next load of clothing has bleach streaks...thus ruining the clothes. I have even tried running a water cycle only after a bleach...
Hi from retired Englishman in SW France @ 16:16 Mon afternoon.
Yes- I have a POSSIBLE solution but it depends on some answers-
I do not know your exact model- does it have a specific container for bleach or is the bleach poured into one of the powder/fluid/ conditioner trays?
If the latter, have you removed the tray and thoroughly cleaned it? If not it is possible that not all of the bleach is siphoning out properly because of a (partial) blockage. A similar thing happens to many people with the conditioner/softener tray. Because it is liquid the tray cannot have a simple open rear end else the conditioner would just pour in straight away so it uses a 'tube' down which the conditioner siphons/pours- providing that the tube is clear.
Trays are removed in a few different ways- pressing down on a plastic lip at the rear centre, pressing up on a catch underneath the tray OR by pulling then finally lifting the tray out.
Even if a blocked tray is not the answer, it is still worthwhile taking it out and cleaning on a regular basis. In the same way, particularly if you live in a 'hard' water area i.e. lots of calcium, it is well worthwhile running a sachet of proprietary anticalc powder/liquid through the machine- say every 3 months as I do!
I really hope the problem is the tray- though that might be too simple!
Best of luck,
John C
Jan 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
After each load the "fill bleach cup" is filled with water. I have to take the whole tray out and flip it up-side-down to empty the water. I cannot find where the thing can be clogged. I can't use bleach...
Bleach & fabric conditioners "syphon away" into machine... try adding 1/2 lt water to the bleach compartment, if it then syphons away your syphon is not blocked. If it does not drain you will need to find the syphon cap - genarally just a tube, most manufacturers will make the tube a different colour to the rest of the draw.
If it did drain when water added you may have issues with bleach not being a part of that particular cycle, delicates for example...
Apr 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bleach dispenser does not drain water
Aug 06, 2009 | Whirlpool Washing Machines
The fabric softener and bleach tray won't drain
clean the caps sometimes they get clogged and cannot syphone
Jun 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
