Question about VinoTemp VT24-G 24 Bottle Wine Cooler
Vinotemp 24 - keep hearing ticking sound
My winecooler not working, the light does not turn on and the temp is not working either. The only thing I hear is ticking sound. what's wrong and how can I fix this?
  • 1 more comment
  • rmdspam Mar 29, 2009
    I have the same problem; the unit is less than 2 years old.
  • Anonymous Apr 28, 2009
    I have the same problem trying everything to fix.
  • Anonymous May 16, 2009
    the cooler doesn't work, i hear the ticking sound and see that red and green leds are on (on the back of the cooler)
It's the overload protector thats gone bad. Remove the plastic cover on the side of the compressor( LG model NS30LACG). The OLP is the one on top. If you open it up you will find that it may have some burn marks from electrical arcing. The part number is on the side (P6R8MC). Do a Google search for it. It costs about 12 bucks.
Posted on Aug 10, 2009
Call Vintemp, Your Breeze Aire needs service, they will refurb it(prob. has lost it's refergerant charge). I had mine done about 5 years ago about $150.00 then.
Posted on Jan 12, 2009
Why would Vinotemp (VT-21TEDS-2Z) winecooler just stop working?
Could be any number of reasons. If it's had problems with setting temperature, suspect the thermostat first, Failing that, check through the power circuit from mains in to compressor.
Apr 28, 2014 | Refrigerators
Vinotemp 28teds doesn't work, no fan, temp or light, what's up
Probably somewhere in its history there was an incident of total failure.
Dec 31, 2013 | VinoTemp 28Bottle FreeStanding Wine Cellar...
Our 18 bottle vinotemp cooler quit cooling, the electrical is ok
Sounds like the cooling unit, i.e. heat sink and controller chip. $35 + $10 shipping from vinotemp, and you install yourself. I'm looking at the same thing (on the 28TEDS), though mine came after having to replace (for $45 and my own installation, incl. soldering) the circuit board. I hope yours doesn't go, too. I've read of others. Pretty poor quality parts they appear to use. I'm trying to find somewhere to buy the controller chip on its own, as the heat sink is simply a hunk of metal. Hopefully that's do-able, as it is with computer cpu's.
See:
http://www.vinotemp.com/Browse.aspx/446/Replacement-Parts
Dec 28, 2009 | VinoTemp VT-18TEDS 18-Bottle...
Vinotemp (VT-60), cools, but doesn't turn off regardless of the temp setting. It will run, cut off for aprox 5 seconds, then continue running. Is thermostat broken? Can it be repaired?
It will either be the thermal resistor or the controller of which the electronic thermostat is a part and yes it can be repaired. It is a reasonably common and cheap fault to repair. If you go to the following link you can get the service manual FOC
http://www.vinotemp.com/Resources/Documents/VT60.pdf
and you can contact a repair company via Vinotemp at the following link
http://www.vinotemp.com/Service-Support/Repair-Companies.aspx
Nov 05, 2009 | VinoTemp VT-60 Wine Cooler
VT12TEDS display black, clicking sound in back panel, tic, tic, with a blinking light diode, but no fuse seen, nothing moving, maybe at times the fan blades want to move but do not, they spin freely by...
My VT-12TEDi stopped working after about six months; the common ticking sound from the controller board. After a little research, I found the 16V 1000uF 16mmx10mm capacitor (silver and black can) on the board (upper left corner) was bad. Visual indications are the typical "popped" top of the capacitor can. I purchased a quality replacement capacitor for less than $1 and replaced it. It was a very easy soldiering job that most people with a pencil iron could do. The unit works great now and I don't expect it to go out again anytime soon.
Jan 18, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Vinotemp wine cooler won't cool
It sounds like your control module is bad. Vinotemp does list the replacement part as available at a cost of around $35
Nov 14, 2008 | VinoTemp (VT60GNV) Wine Cooler
I have a vinotemp it stopped cooling no light and keeps making a ticking sound, I tried to unplug it for a while and plug it back and the ticking sound goes back again but still no light no cooling, please...
You can fix this for $5. You can confirm the problem by taking the back off and see of the red and green led on the circuit board are flashing. They will be steady if the board is ok. The fan is usually just rocking too like it is trying to start. The part is a capacitor and is $5, but you will need to be able to remove and solder a part on the circuit board. If you need the part, just let me know.
David
Oct 23, 2008 | VinoTemp VT24-G 24 Bottle Wine Cooler
Vinotemp VT-60 Condenser won't shut off, unit running way too cold
It might be a sensor or control board problem. Any appliance repair place should be able to help you out with this. Or you can try contacting the manufacturer directly for help or if you need to purchase replacement parts. Otherwise, my cheapest suggestion would be to hook the cooler up to a timer, so you can turn the unit on and off maybe every 20 minutes or so. That should help keep it from causing more harm and then you can monitor the temperature with a thermometer. Hope that helps!
Aug 29, 2008 | VinoTemp (VT60GNV) Wine Cooler
Winecooler danbydwc2121bls
I have a unit similar, I am replacing the control board and related parts - basically the electronic and electrical parts in the area the separates the two sections
May 18, 2008 | Danby DWC283BLS Wine Cooler
Furniture Logo
1,711 people viewed this question
Top VinoTemp Furniture Experts
Dan Webster
Dan Webster
jackj59
Level 1 Expert
jasbo
jasbo
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
