Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Picture comes on than turns off and red light stays on
My Mitsubishi wd62327 tv turns off by itself and then the red light stays on. I can turn it back on and the picture shows. About 2 minutes later the tv will turn off and the red light will stay lit.
  • joepa330 Nov 13, 2007
    I have the same tv , the warning for the bulb came on about a month ago and the tv went dark on Friday the 9th. I got another bulb but it doesn't work. The power comes on, there is a humming noise like a jet engine starting up, but not as loud (lol) then the noise repeats itself. Then the lamp light blinks green, then turns solid red. Could this be the ballast and is that easy to replace? I also put the light inside without the cage to make sure the connection was true and I put a screwdriver in the slot in front as though the cover was on. The light still didn't work. What gives?
    New Friend:
  • 129 Answers
You can reset the tv to factory default settings , but before that I need more info ab manufacture date and purchase date you can find the first one on the back cover, if the tv has more than 5000 hrs of use problably the lamp, filter or fans can cause this problem, hope it helps you . let me know
Posted on Jun 12, 2007
  • Graham Peters
    Graham Peters May 10, 2014
    How do you reset the tv lg model 62DC1D-AB
Red light blinking no picture just sound
How many times the standby LED flashes at a time?
Aug 04, 2012 | Mitsubishi WD62327 TV
I turn the tv on it stay on for one second then it goes off thats when the lamp button comes on its red. then the red light comes on and it stays on although the tv is off the red lamp light is still on
Your lamp timer may be maxed out which means you should change the lamp and reset the lamp timer. When the timer max's out it won't turn on till it is reset.
Feb 09, 2010 | Mitsubishi WD62327 TV
Tv power light comes on but screen is black. Do I need to replace the bulb. It's model Mitsubishi WD62327
is there sound. first check the secondary filter capacitor and then check for dry join. don't forget to check the HOT transistor.
Sep 30, 2009 | Mitsubishi WD62327 TV
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
How do i turn off v-chip on my mitsubishi tv model # is WD62327
Let me know brand and model number of your TV to look for its Instruction Manual for you.
Dec 05, 2008 | Mitsubishi WD62327 TV
Mitsubishi model# wd-62327
You will need to do a self diagnosis test first.
Dec 03, 2007 | Mitsubishi WD62327 TV
Tv goes red????
I red drive problem possibly on the red crt board or from the video jungle IC, like a bad red driver transistor, The resistors on the crt board could be changing value, or the crt socket on the red driver board could have poor solder connections on them. This is not a problem that a end user should attempt, as there is high voltages on the CRT drive boards. Going to need to have the tech monitor the set and test untill problem occours. Should not be a big deal .. Good Luck
Aug 14, 2006 | Mitsubishi WD62327 TV
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
335 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
