Question about Motorola Mobility CLIQ Cell Phone
How do i bypass motoblur setup on motorola defy
Motoblur login
Ensure you have a data connection and then use the WiFi option to create a MOTOBLUR login when you power up the phone the first time.
Go to the ATRIX 4G community on Motorola Owners Forum with any additional questions.
Mark
Customer Support
Jul 24, 2014 | Motorola Mobility MB860 ATRIX 4G QUAD BAND...
How do I pair motorola h700 with motorola defy?
Enable Bluetooth on your Defy. Then follow these instructions H700 Different Paring Instructions then search for H700 on your Defy.
Mark
Motorola Support
Apr 13, 2014 | Motorola Mobility H700 Wireless Headset
If Motorola Defy reset back to Factory, will it allow me to open and use phone
Yes you'll need to create a new motoblur account or log on to an existing one.
Feb 04, 2014 | Motorola Mobility Defy Cell Phone
How to bypass Motoblur account login screen
When you get to the Motoblur screen press and the 4 square icon until a keyboard appears and type [alt]E[altE] BLUROFF it only works one time and you have to do it each ti,e you see the BLUR sign up page
Feb 27, 2013 | Motorola Mobility CLIQ XT (2 GB) Cell...
How to open a motoblur account
The first is you must have a SIM card that is configured with the correct data plan and set up a MOTOBLUR account to gain access to your phone. To create MOTOBLUR account can only be done from the phone.
Now you can create a new account in MOTOBLUR wit:
  1. Press register tap new account
  2. Enter your name, your current email address (where MOTOBLUR can send account information), and a new MOTOBLUR account password.
  3. Done
Then you can set up your account. For the first time you login to your account, better you do:
  1. Add your accounts. To add an account, tap it and enter the user name or email and password that you set up on that account.
  2. After you sign in, your phone imports your contacts from your SIM card.
  3. To see your contacts, Tap Contacts from the programs menu.
If you love manual work, you can import contact manually from SIM card with:
  1. Tap Contacts
  2. Press the Menu key
  3. Tap Settings
  4. Tap Import from SIM card
  5. Tap OK to confirm
Some time you don't need the MOTOBLUR account and want to delete it, you should contact your Motorola Call Center to request for your MOTOBLUR account be deleted.
Feb 14, 2013 | Motorola Cell Phones
My Motorola Defy will not hold a charge. Had full charge at 8:00 Am and by 2:00 PM battery was dead. No apps running or Wi-FI on. Second day in row this has happened
The DEFY is feature-rich and can run a virtually limitless number of applications, making it useful for many tasks. Your particular usage will affect how long you can go before recharging your battery. Playing games, running applications, and surfing the Web increase the power use of the computer-like functions of the DEFY Calling and texting utilize its phone functions. Depending on your use mix, time between charges will vary. We know you want to use the device to its fullest and offer you these tips to help you get the most from your phone while going as long as possible between charges.
Things you should know about charging your battery.
New batteries are not fully charged. Plug the battery charger into your phone and an electrical outlet. Your phone might take several seconds to start charging the battery.
Tip: It may take several charging cycles for your battery to reach optimum performance.
The battery charger shipped with this device is designed specifically for Motorola mobile phones. Other chargers might take longer to charge your battery, or cause your calls to fail during charging.
Tips to extend battery life:
  • During initial set up of your MOTOBLUR account, your phone's battery may drain faster than usual due to the amount of data transferred. After the initial sync, and a few charging cycles, your battery will reach its maximum capacity.
  • We strongly recommend to keep the phone attached to the charger during the MOTOBLUR initial sync.
  • When not transmitting a lot of data or surfing the Web, set your device to connect to 2G network.
  • When setting the phone down after use, quickly press the power key to invoke a blank screen. Selecting a shorter back light duration will also help conserve power by blanking the screen when not in use.
  • Lower the display brightness.
  • Use the AC adapter to charge your phone whenever possible.
  • Toggle Bluetooth, Wi-Fi, and GPS on or off as needed. There are some apps that can help do this easily. While we do not endorse or guarantee these solutions, or provide support for them, some owners have reported success using an application called "Battery Widget " which can be downloaded from Android market.
  • Ensure applications are closed when not in use.
  • Clear all notifications from the notification bar as much as possible. Click Here to learn more about notifications.
  • We suggest charging each night so you start the day fully charged and ready to go!
Motorola DEFY Battery Manager - Benefits
A feature called Battery Manager is now part of the DEFY software
  • It provides options for significant battery savings by reducing data traffic when not needed, and by dimming screen when battery is low.
  • Two optional settings:
Data Timeout
· With this feature: After a period of inactivity, background data updates stop until the user starts using the device again.
· Without this feature: background data is constantly updated (Email, Social Networking, News Feeds, etc.), even overnight.
Auto Brightness
· When Battery Level gets low, screen automatically dims.
Battery Manager: How To Use It
To access battery manager
  1. From the home screen press the menu key
  2. Tap settings
  3. Tap battery manager
Three Modes are available:
  1. Performance Mode (default) - Data Timeout and Auto Brightness are OFF
  2. Smart Mode - Data Timeout and Auto Brightness are ON with different settings during Peak and Off-Peak times of day. User can change various settings.
  3. Battery Saver Mode - Data Timeout and Auto Brightness are ON with settings to maximize battery savings. User cannot change the setting
May 24, 2011 | Motorola Mobility Defy Cell Phone
Motorola Mobility CLIQ Cell Phone Logo
402 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
