Question about LG 42LC5DC 42 in. LCD Television
Hook up PS3 hdmi to hospital LG tv - LG 42LC5DC 42 in. LCD Television
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
  • 3 Answers
SOURCE: PS3 not working on reg tv's after HDMI use on LCD HD tv
Shelley,  the fix for this is simple! Hold down the power button for about 5 seconds and the system will beep. This resets the video setting for your ps3 from HD too whatever the current cables are that you are using too hook up too the tv. This works on my PS3 which I just bought about 3 months ago and should work with the older ones.
Posted on Jun 05, 2009
  • 40 Answers
SOURCE: i have an lg 50pg20 and i cant hook up my ps3 using the hdmi cabl
Make sure the xbox display settings are not defulted to 480. Have you tried using the component hookup instead? Theres really not that big a difference in quality between the two if your settings are correct in the xbox display menu.
Posted on Jun 19, 2009
  • 3 Answers
SOURCE: my lg tv will not go into hd mode, i have a hdmi
upgrade software file needed from lg using usb port.
Posted on Feb 02, 2010
budmrtn
  • 11361 Answers
SOURCE: My LG 32LC2D Tv will not connect to my PS3 with
Your PS3 video resolution is set too high for the monitor to display, try starting at lower resolution first and go up from there.
Google PS3 resolution setting.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jun 18, 2010
My lg flatron n2294a - PM displays an "out of range" message and won't wirk with my ps3 when using the hdmi or AV option. Whats wrong?
Your resolution on your ps3 may be too high for the tv to display. Hook up your PS3 to you TV with the HDMI cable. Now, when you turn on your PS3, hold the power button on the PS3 for 5 seconds. It will reset the PS3 video options and recognize the HDMI connection. It will then search for the correct resolution settings on the TV. Press (X) to confirm. And that's it. You should be set. If not, then the TV is acting rather strange.
Apr 01, 2013 | Computers & Internet
When I hook up my LG plasma to PS3 and Cable box, I don't get any sound or colour on the PS3. The TV /cable box works fine. Any ideas on the wiring?
What type of connections are you using? HDMI? Component? Composite? What audio? HDMI? Optical Digital? Analog audio?
Are you saying you get video from the PS3, but it is in Black&White only? Is there an NTSC/PAL selector on the PS3? If so, it may be set wrong. Set to NTSC if you're in the United States.
Feb 01, 2013 | LG 50PC3D 50 in. Plasma Television
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
No signal from ps3 to lg tv via hdmi
if this is the first time you've hooked it up via HDMI then you have to go back to the old cables first. Hook those up to the old TV or the new one, then go to settings and switch to HDMI. It will give you 30 seconds to change the plugs again so you can view the HDMI. Then select ok. Hope this helps
Aug 20, 2009 | LG 42LC2D 42 in. LCD HDTV
Jun 05, 2009 | LG 37LC2D Television
I have an lg 50pg20 and i cant hook up my ps3 using the hdmi cabl
Apr 26, 2009 | LG 50PG20 50 in. Plasma HDTV
Can't play PS3 on LG 42LC7D tv
use hdmi cable from ps3 to rear of tv (you should have hdmi 1 & hdmi 2)then ppress input on remote until you get hdmi 1 or 2 on screen walaa
Dec 20, 2008 | LG 42LC7D-UB Television
LG 42LC5DC 42 in. LCD Television Logo
663 people viewed this question
