Question about Gaggia Syncrony Espresso Machine
My machine say's to ventilate after dispensing 1/2 cup.
I have a Gaggia Synchrony Espresso Machine and once the machine has dispensed half a cup of coffee it stops and the ventilate sign appears.
I ventilate, using the nozzle but no steam comes out nor does the ventilate sign disappear.
Once machine is switched off then on again I can go through the same cycle.
How do I fix this ?
  • francelogis7 May 25, 2009
    bonjour, j ais une saeco royal elle me verse une demie tasse et puis elle affiche "purger" je dois l'eteindre pour recommencer le meme cycle... en sachant que je l ais purger plusieurs fois par la buse panarello pourtant l'eau chaude arrive bien mais sa dure 9 secondes...puis encore purger j 'essaie meme le detartrage au bout de 6 seconde elle affiche detartrage fini... le mode emploi dit pompe defectueuse... merci de votre aide.
2 Suggested Answers
  • 109 Answers
SOURCE: Gaggia Syncrony not dispensing properly
It sounds like you need to program the coffee level.
Have a look on this page for the instruction manual.
http://www.coffeeitalia.co.uk/downl-manual.php
Posted on Feb 25, 2010
Screen indicates to ventilate and won't allow any fuctions till ventilated. Have ran ventilate cycle several times, however machine still indicates to ventilate. Water flow is extremely low to nil when...
If you open the steam knob and only can get a half cup of water, then your flow meter in the machine have to be replaced.
If you need to replace the flow meter then it has spare part number: 286473300
Make sure to descale your machine often.
Jul 20, 2008 | Gaggia Titanium Espresso Machine
Where can I purchase a replacement dispenser shute for Gaggia Synchrony Logic Type SUP 020 Ser.#9005GA40015808? Many thanks.
Check the site at importika.com they have a list of repair areas any one of them will have a spout in stock.
Mar 10, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Jan 04, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Synchrony wont work after decaling
Check the thermostats on the boiler and the boiler element?
Jul 14, 2009 | Gaggia Syncrony Espresso Machine
No cream on the espresso when dispensed
I was having this trouble with Lavazza beans and Morrisons (horrible) beans. I switched to Formula 6 from James' Gourmet Coffee on the internet and every cup has a great crema layer and good taste.
With the old beans I could get an occasional good cup, it seemed this was more of a problem if the machine had been switched on for a long time before making the cup. I use a Gaggia machine with a Gaggia MDF grinder on 8 or 9 setting, with the new beans I now get a great cup all the time so I'm going to try more the James' range!
Nov 05, 2008 | Gaggia Tebe Espresso Machine
Gaggia titanium dispenses different amounts of brew
First thing to you should try is descaling your machine if you haven't already. If descaling does not work then it might be some kind of leak issue.
You see, when leaks are present internally in the espresso machine it varies the amount of the cup, because a portion of the water which should have gone into your cup, has leaked into the machine.
It looks like your machine needs some service.
Visit www.CeriniCoffee.com if you need service in the New York City Area.
Jun 19, 2008 | Gaggia Titanium Espresso Machine
Ventilate problem
Can you make a cup of water or there will only comes a half cup?
If you only get a half cup then you have to replace the flow meter in the machine.
Apr 27, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony Espresso Machine Logo
108 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
