Westinghouse mastermind 708 noisy bearing?
It is very noisy when spinning, sounds like a bearing
  • 1314 Answers
SOURCE: washing machine dosnt spin dry,
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Posted on Jun 03, 2008
  • 1294 Answers
SOURCE: door lock on westinghouse mastermind 708 washing machine
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened.
Posted on Apr 13, 2009
  • 65 Answers
SOURCE: The machine is westinghouse mastermind
Yes the transmission can seize. Check to see if the water inlet is blocked. Shut water off and discount hot and cold water inlets to see if they are blocked. If so then further invesigation is needed to see if something jammed inside the machine like a penny, diamond ring, earring, loose change or something small stopping the spin cycle. If this is the case you might have blown the circuit within the machine. Hope this is helpful
Posted on Aug 28, 2009
  • 6 Answers
SOURCE: I have a Westinghouse mastermind 708 washing
I would check the internal coin trap/drain to make sure it is not blocked with socks or 3-in1 dryer sheets. If the water does not drain it backs up and causes error messages and spin problems. These are normally not listed in the manual so you have to take off a panel to find it. Could be at the bottom or in the back. Unscrew and check the trap and remove any blockage. Prepare for a mess if you can't fit a bucket under the trap!
Posted on Oct 23, 2009
SOURCE: My westinghouse mastermind 708 is
most home appliances have many ELECTRONIC components......these components are very sensitive to electrical irregularities that enter your home electrical system......these irregularities can cause some components to freeze up.......pull the plug and leave your westinghouse 708 unplugged for several minutes.......plug it in again and it will reset all of these control components........hope that helps!
Posted on Jan 07, 2011
My mastermind 708 dosen't spin after wash cycle.It spins fine in the wash cycle but dosen't drain water or spin in the spin cycle.Pease help
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Jul 01, 2011 | Westinghouse Washing Machines
My westinghouse mastermind 708 is flashing SE or 5E? what does this mean please?
Jan 07, 2011 | Westinghouse Washing Machines
I have a Westinghouse mastermind 708 washing machine and it does not spin after wash cycl. i think it might be the pump to pump water out, it still makes a humming noise
Oct 23, 2009 | Westinghouse Washing Machines
The machine is westinghouse mastermind 708 is there any other part that can seize besides main drum bearing?
Aug 28, 2009 | Washing Machines
Door lock on westinghouse mastermind 708 washing machine
Apr 13, 2009 | Washing Machines
I have a mastermind 708 7kg front loader and SE is flashing and maching won't work can you help please
Ihave a mastermind 708 7kg front loader and the SE is flashing and machine wont work can you help please? Thankyou
Aug 03, 2008 | Washing Machines
Washing machine dosnt spin dry, front loader westinghouse mastermind 708, 7.5 kg
Jun 03, 2008 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
