Question about Sharp Mx-3100n Color Copier Super Clean-practically
Error code E7-06 sharp copier MX3100N
ERROR CODE E7-06 WAS ON SCREEN WHEN I CAME IN. I UNPLUGGED IT, AND TOOK OUT A LARGE SHEET OF PAPER FROM BOTTOM RIGHT DOOR THAT WAS "JAMMED"...IT CAME OUT EASILY. WHEN I TURNED THE COPIER BACK ON, AFTER A MINUTE YOU COULD TELL IT WAS TRYING TO MAKE ANOTHER COPY, AND THE DATA LIGHT WAS BLINKING.....BUT IN ANOTHER MINUTE, THE ERROR CODE CAME UP AGAIN, AND THE PAPER WAS SITTING IN THE SAME LOCATION.
  • 2072 Answers
SOURCE: Sharp AR-287 Copier error code H5-01
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Posted on Mar 17, 2008
SOURCE: Error Message: Check SPF/RSPF START to Resume
I just fixed this problem on my sharp all in one. The white rollers on the underside of the copier cover were not rolling well. I took an alcohol prep pad and started cleaning them, rolling as I went. A large piece of lint fell out. I put the documents in the document feeder and they fed through like a charm. Hope this helps.
Posted on Jan 07, 2009
  • 2976 Answers
SOURCE: sharp 5316 showing paper jam sign at right door but no paper
Shut it off, wait 30 seconds, turn it back on. If the path IS clear, the error will be gone.
Posted on Feb 23, 2009
  • 67 Answers
SOURCE: The "Paper Jam" light on my Sharp AL-1631 copier stays on
The paper detector on the fixing units have a history of going bad. The fixing unit is the hot roller above the drum inside the right door on the top. As the copy comes thru the rollers the paper hits a plastic lever that is spring loaded and located in the middle of the fixing unit. The sensor is all the way to the right side of the fixing assembly. If you move the lever in the middle you'll see a piece of plastic moving on the right, that piece comes out of the sensor and if can't reset the jam, that piece may not be resetting itself back inside the sensor. This is difficult to try to explain.
Good luck
Bob
Posted on Apr 23, 2009
  • 990 Answers
SOURCE: Sharp copier SF-2025 displays an error code U%.
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
Posted on Oct 01, 2009
What does error code dc on sharp 3100n mean?
image cartridge cyan need to be replaced
Jul 04, 2014 | SHARP MX-3100N
Error code U6-02
You have a large capacity double tray, the code is for the lift up motor in the right hand tray (that lifts the paper stack to the rollers) pull out the tray and see if there is paper wadded between the tray and the back wall of the machine blocking the motor boss from meshing with the tray.
Clear the motor error code with SIM 15 in the service area of the machine (from copy mode, # * C * to access)
If the code comes back your lift motor is worn out and needs to be replaced
Apr 20, 2014 | Sharp Mx-m450n Mfp Multifunction Booklet...
Printing data light is blinking
Check if the machine print is put to paused, go to status and make sure you it is on resume not paused.
Dec 12, 2013 | Copystar Sharp MX-3100N Copier : Sharp...
HAVE A SHARP MX3100N COLOUR MACHINE...THE PROBLEM IS I CAN SEND FAXES,BUT CANNOT RECEIVE JUST KEEPS RINGING CONTINIOUSLY..ITS ON AUTO RECEPTION
Try a new phone line from the wall to the machine. Make sure to plug it into the "line" and not the "ext/phone"
Jun 01, 2011 | Sharp MX-2700N Color Copier
Jams but only w/sheet feeder
Theres is a spring clutch in the adf that goes out. Once that is fixed it should work just fine.
Aug 13, 2008 | Sharp AR-507 Copier
Aug 06, 2008 | Sharp AL-1655CS Copier
Canon i470D...code 302 (paper Jam) shows up on the digital screen. There is no jam. When this happended the document printed, but while printing reversed it self(paper went backward) then went properly...
I had the same problem. I took a card stock sheet of paper. When you turn the printer on and it trys to take the paper thru, I forced it thru and had some small pieces of paper come out. I had the front open so I could see what was happening. It fixed mine, hope it helps u.
May 06, 2008 | Office Equipment & Supplies
Sharp Mx-3100n Color Copier Super Clean-practically Logo
43 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
