Question about Vizio 60" Class 60.04" Diag. 1080p 120Hz LED-LCD HDTV E601I-A3
Vizio 60" LCD 120Hz WiFi not streaming
Not sure why the connection to our Vizio (upstairs) is so slow (273Kbps) compared to our playstation 3 (12 Mbps), which streams in HD very well and is further way from the router (downstairs). Testing the download speed on our laptop its 38Mbps. I'm stumped???? any help will be greatly appreciated.
5 Suggested Answers
SOURCE: Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Posted on Jan 29, 2009
  • 8 Answers
SOURCE: No picture on vizio lcd
It's likely not a backlight, but a mainboard. If you are feeling frisky, take the back off and get the model number off the mainboard and check eBay.
Posted on Aug 22, 2009
SOURCE: Vizio SV470M, picture is moving too fast
This is often called the "Soap Opera" effect...I had a similar problem and found that changing the settings helped tremendously. Here are the settings I use:
Picture Mode: Movie
Backlight: 18
Brightness: 49
Contrast: 52
Color: 42
Tint: 2
Sharpness: 3
Advanced Video
Noise Reduction: strong
Color enhancement: off
Advanced Adaptive Luma: Off
Enhanced Contrast Rato: off
Color Temperature: Normal
Red: 121
Green: 128
Blue: 118
Smooth Motion Effect: low
Real Cinema Mode: Precision
Also, there's a great thread on the Soap Opera effect here:
http://www.hometheaterforum.com/forum/thread/291611/the-soap-opera-effect-on-modern-displays
Posted on Mar 18, 2010
  • 8457 Answers
SOURCE: Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Posted on Apr 07, 2010
I have a 60 inch Vizio smart tv. I can't connect with Netflix. I can't find my Wifi on the connectivity screen.
Do you know for sure your WiFi is working? If it is, is your TV within range of the signal?
May 05, 2017 | Vizio Televison & Video
Hi, I have a Vizio model number E552VL. I have had it a little over 2 years and the picture is getting a little dim and less sharp. Do need the backlight inverter kit to fix it? Thanks
I am not familiar with that kit, have you tried to compensate with the picture controls as much as possible?
I found this link:
Replace LCD Backlight Inverter on Any Monitor for
I wouldn't take preemptive action unless it got pretty bad. Here is a video that may have some applicbility.
Jan 02, 2015 | Vizio 55" E552vl Wifi Internet Apps 1080p...
PROGRAMS PLAYS FOR SHORT WHILE, STOPS AND BUFFERS TO 25, AND THEN WON'T PLAY REST OF PROGRAM.
You have a slow Internet connection. This may be caused be the Streaming Stick being far from the wireless router. The best way to watch Netflix is to have an internet connection of 25/25 Mbps and use a wired (ethernet ) connection to a Roku 3 for example. If you are using DSL that would be a problem because of slow internet speed. Try to imorove the position of the router closer to the Streming Stick if possible. I stream at a distance of 30 ft and it never buffers with a wireless connection to a 720p TV and have a wired connection to a Roku 3 10 a 1080p TV and it works beautifully. Good Luck!
Jan 01, 2015 | Roku Streaming Stick HDMI Version
BUFFERING SLOW, THEN PICTURE COMES THEN DROPS.
You probably have a slow internet connection. It is recommended that you have a minimum 25/25 Mbps connection from your provider. If you do then the streaming stick might be too far from your wireless router. Try to move the router closer to the Streaming Stick if possible. The best way to watch streaming video is with a wired ethernet connection with a Roku 3 or other wired device. Good Luck!
Watching ,orange is the new black season 2. will play then start buffering up to 25, then show message we're having trouble showing this title right now. try again, I do, but same buffering ha
How to increase download speed on Roku 2
You probably have a slow internet connection. It is recommended that you have a minimum 25/25 Mbps connection from your provider. If you do then the Roku might be too far from your wireless router. Try to move the router closer to the Roku if possible. The best way to watch streaming video is with a wired ethernet connection.
Dec 26, 2014 | Televison & Video
Cant connect to the wireless net work
You probably have a slow internet connection. It is recommended that you have a minimum 25/25 Mbps connection from your provider. If you do then the Roku might be too far from your wireless router. Try to move the router closer to the Roku if possible. The best way to watch streaming video is with a wired Ethernet connection with a Roku 2 or other wired device.
Nov 28, 2014 | Roku 2 XD Streaming Player 1080p (3050R
I have Netflix on my upstairs Vizio smart TV, but for some reason will not connect on my downstairs Vizio smart TV? Please help.
First thing I would check is Internet connection on the smart tv that won't connect. If that doesn't work try downloading new software for Netflix. Try those and see what happens.
Oct 14, 2014 | Netflix
Our apps on the Vizio TV do not work
Apps require that the TV is connected to your router and that there's a live internet connection. Is your TV connected to your router?
Sep 16, 2014 | Vizio E3D420VX 42-inch 1080p 120Hz 5ms 3D...
Vizio 60" Class 60.04" Diag. 1080p 120Hz LED-LCD HDTV E601I-A3 Logo
101 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
