Nokia E5 Cell Phone Logo
A
Anonymous Posted on Dec 08, 2012
Nokia E5 is running slow
Everything on my phone is lagging. applications. web browsers. messaging. everything
5 Related Answers
Anonymous
  • 53 Answers
  • Posted on Jul 14, 2009
SOURCE: nokia 6300 java accesss point problem
other browsers are not supporting your mobile
Anonymous
  • 66 Answers
  • Posted on Oct 23, 2009
SOURCE: slow sending text message
it is your sim server problem
Anonymous
  • Posted on Apr 18, 2010
SOURCE: When trying to send texts from my nokia E63 I get
well here is one solution dat worked for me... backup all ur messages, contacts, pics or whatever stuff saved on ur fone to ur memory card/PC/ online storage. Once u have done this take out ur memory card from Ur fone n format by dialing followin code *#7370# ... U'll be asked to enter ur security code. once u done dat fone will restart in one minute and original factory settings will be restored.
Anonymous
  • Posted on Nov 24, 2010
SOURCE: my web network on my nokia 1680c-2 doesnt work
nokia 1680c2 mobile network problam so plz give me jampar solushion.
Anonymous
  • Posted on Jul 26, 2011
SOURCE: my nokia 2690 mobile always
to proto ?e mate plnou pam?t ty zpravy se nemaji kde ulo?ovat
2answers
Where can i do softwear updates for my acer laptop, it begining to lag a bit.
Hi. Windows updates the drivers automatically once a new digitally signed driver is detected specially Windows 10. By lag do you mean applications open slower than usual or do you mean browsing with a web browser has become slower? If the latter, try clearing your browser's cache.
- On Mozilla Firefox: Press CTRL+SHIFT+DEL simultaneously and click Clear Now
- On Internet Explorer browser: Press CTRL+SHIFT+DEL simultaneously and click Delete
- On Google Chrome: Press CTRL+SHIFT+DEL simultaneously and click Clear Browsing Data
- On Microsoft Edge: Press CTRL+SHIFT+DEL simultaneously and click Clear
I'm having this problem in my nokia e5 : My memory
If the phone notifies you if the phone memory is getting low. To free phone memory you have the following options:
  • Move data that you want to keep to an alternative memory (mass memory or memory card, if available) or to a compatible computer.
  • Remove data you no longer need.
Use File Manager or the respective application in your phone to remove data or to move data to alternative memory as described in the user guide. Typically you first mark files to be removed or moved and then you select the corresponding option (Delete orMove to folder).
Use Nokia Ovi Suite to move data to a compatible computer.
In order to free phone memory, you could remove or move the following:
  • Messages from Inbox, Drafts and Sent folders in Messaging
  • Retrieved e-mail messages from the phone memory
  • Saved Web pages. Clear the web browser cache to free some phone memory (e.g. select Options > Clear privacy data >Cache).
  • Saved images, videos, or sound files (in Gallery, Photos,Videos or Music player)
  • Contact information (in Contacts)
  • Calendar notes (in Calendar)
  • Downloaded application packages
  • If there are applications which are not needed any more, uninstall them with Application Manager
  • Any other data that you no longer need
If you are deleting multiple items and any of the following notes are shown: Not enough memory to perform operation. Delete some data first or Memory low. Delete some data, try deleting items one by one (starting from the smallest item). After deleting data, restart (power off/on) your phone.
Tips: Use the memory card or mass memory instead of phone memory in the Camera or other applicable applications in case the selection is available (e.g. via Options > Settings >Memory in use).
I hope this helps!!
Aug 06, 2017 • Cell Phones
1helpful
How can i block numbers and messages on nokia e5
The easiest way is to have the phone ring-in only for the names and numbers in your address list. In addition, you can have the phone ring-in for numbers that you specify. Follow the Nokia instructions by CLICKING HERE
I cant configure gmail account in my e5 phone
Your Nokia E51 phone is capable of many connection options with wireless services, including the ability to connect to email servers and receive email messages. You have access to your inbox, mail folders, and the capability to send and receive messages wirelessly from your email account. If you have email through Outlook Web Access, you can access emails from your Microsoft account.
Instructions
Set up Outlook Web Access
1 Press down on the "Menu" button on your phone and then click on the 'Set up e-mail" icon. You can also select "Main menu," then "Email" and then "New."
2 Click on the selection for "Messaging" and then click down on "Options." Select the option for "Settings," then "E-mail." Select "Options" when the application opens and then click on "New mailbox."
3 Make sure that the email setup wizard starts up. Click the option to "Start e-mail setup." Click the option for "Mail for Exchange."
4 Type your email address in the address field and then type your password in the password field. The default password for many Nokia devices is "12345."
5 If you use a different username for the Outlook Web Access, type in the username. Otherwise, leave this field blank.
6 Type in the "URL" from which you access Outlook in order to check your mail. Click on the option for "Next." Wait as the message "Connecting to Mail for Exchange server" displays on the Nokia.
7 Read the terms and conditions and then click on the option "OK" when you accept. Make sure the window "What to sync" appears. Click on the "E-mail" option to sync your email to the Nokia and then click "Next."
8 Click the option for email to either "Delete from phone" or "Keep on phone." Select "Delete" in order to free memory on the device.
6helpful
3answers
I want to completely format my nokia e5
Hi, If you want to format your phone,be sure to back up all important files contacts,calendar,messages etc. before doing this method because everything will be deleted after the process.
Then follow these steps: - On your home screen,just type *#7370#, a message pop up "lock code" - Enter the your current code if you change it before,otherwise the code will be 12345 as the default.Your phone will reboot automatically,Now your phone is in original settings. GoodLuck=)
With nokia c5-00 cell phone the file transfer can not be done even with nokia pc suit cable connection. i get message that the mobile phone rejected the operation
install the USB driver , it will including in CD
search on Nokia web for USB driver for nokia E5. hope it can solve your problem. good luck
1helpful
2answers
I need unlock code for my new Nokia E5. I just bought it last week but the phone is locked. How do I unlock it?
You just have to follow the instructions on this website :
http://hyfeno.com/unlock-nokia-e5/
You will need an unlock code that you will fin at :
http://www.globalunlock.com/phones/home
Remember that unlock code are not always free...
2answers
How to remove the software from memory card
Well, when you deleted some application it has to be done through installer. You might just delete application pressing C button. In that case there's an install file but no application acces. Try use Y-Browser and if you can't find the file then format the memory card.
Rate me if it helped. Thanks.
1helpful
My computer lags when I play games online
Memory may help you, it also may not. One thing that can cause a system to run slow is from alot of startup programs and services. Also an infection could cause it to run slow to. I recommend lettnig a professional help you.
http://www.nicklockard.com
1helpful
3answers
N73 very slow
My phone always lags, because there are some apps run in the background. One day I suddenly find in LEO Privacy there is a Boost feature, and then I always use it, and now my phone runs faster. LEO Privacy Applock Boost Hide Android Apps on Google Play
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
