Question about BOSS AUDIO SYSTEMS Car Audio & Video
How to bypass the parking brake wire for a boss in dash dvd/mp3/cd player in a ford ranger
Need help on how to bypass the parking brake to install our boss BV7330
  • 109 Answers
SOURCE: bypass parking brake wire
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
Posted on Jun 06, 2008
  • 4 Answers
SOURCE: need help bypassin parkin brake wire
you need to hook up the foot brake like it said but hook up a switch on the parking brake wire to ground do not hook it up to parking brake just a switch ground one side ant togle it while your foot is on the brake once the screen is on leave the switch in that position you will have to do this every time you turn the car off but you can see the screen while driving
Posted on Apr 08, 2009
SOURCE: bypassing car dvd parking brake
The yellow wire that the manual says that you "need to hook up to the parking brake" just needs to be grounded. Its that simple, you do not need any switch or anything, just find a part of the car behind the unit and ground it.
Posted on Apr 30, 2009
J-Chris Ward
  • 731 Answers
SOURCE: I have put a boss in-dash dvd player iny car and i
That is static off the motors electrical's system. Go to a radio shack and get a noise suppressor the positive end go on the positive end of the radio and the negative end go to ground this will bleed off the static just like a capacitor in a power supply. Ask one of the old guys at Radio Shack.
Posted on Feb 15, 2011
rockmeister
  • 2047 Answers
SOURCE: BOSS 7300 in dash DVD
The flicker which happens is as a result of a power failure in the unit. Whenever this power fluctuation occurs it causes the unit power to go off and then restart. The restart is what brings about the screen which displays media at the top and the radio display screen. try tracing the cables which supply power to the unit for any inconsistencies to sort this out. Also you can check te use which affects the supply of power to te unit.
Here are 2 links to help with bypassing the brake. The first is a video while the other is a detailed step by step explanation.
http://www.youtube.com/watch?v=NgdfLst2QvQ
http://www.ehow.com/how_7265002_bypass-brake-wire-dvd-player.html
hope this solution has been helpful?
Posted on Mar 27, 2011
There is no parking break wire on my panasonic indash how do i bypass it
http://service.us.panasonic.com/OPERMANPDF/CNNVD905U%20INSTALL.PDF
Looks like the cable named"Side Brake" (Bright Green)must be grounded at all times to get your dvd always working, hope this helps.
Nov 07, 2013 | Panasonic Strada Cn-nvd905u Dvd Cd...
Cant play dvd says parking brake on screen
you can not play dvd's when the car is not in park with the e brake on. I"m assuming it was factory installed or by a dealership??? they hook a line from it to your brake sensor. it's illegal to watch movies while you're driving. so long as theyre behind your seat and out of your view theyre legal, otherwise they hook it to your brakes.
Aug 14, 2012 | JVC Kwav60bt 6.1" Dvd Cd Mp3 Double Din...
How to install boss bv7330
Hello
Get into this link. You can download the installation manual to your set from here.
www.transpulsar.es/mediapool/77/.../CAT_Boss2012_loRES.pdf
Jan 25, 2012 | Car Audio & Video
When I insert a DVD, such as "Due Date"; even while my car is off and parked. The screen displays a message saying "ATTENTION You can not use this function while driving. Although I can hear...
the unit will have wires that need to connect to your foot brake, and parking brake. Its the law in the state I live (Alaska) that professional installation requires the dealer to install the wires to the foot and parking brake. There is usually a sequence to getting the picture up. (like holding down foot brake while applying parking break) then the message will disappear.
I simply bypassed this by connecting the two wires to the AUX (usually red wire) so there was a 12 volt draw. added two switches inline to act as the brake sensors.
Feb 28, 2011 | Boss BV7965 Car Video Player
I am about to install my boss bv8962 unit into my vehicle but I want the parking break safety feature bypassed. What do I do differently during installation so that my passengers will be able to watch tv...
Yes, you can bypass parking break feature by connecting the corresponding wire of BV8962 to ground, also you could add a 3 pin toggle switch to get a normal and bypass mode switch, this can be wired of this way, the common pin of toggle switch to your video unit, at the other pin, it could be connected the parking break wire (normal mode) and the remaining one to ground (bypass mode).
Feb 26, 2011 | BOSS AUDIO SYSTEMS BV8962 Car Video Player
I bought the jensen vm8113 for the dvd player. I travel a lot with my family and thought that the dvd player would keep my passengers occupied while i drive. Problem once i installed it, i found out that...
To be honest with you, it's a very easy fix. If you read the install manual it shows the parking brake needs a negative (-) to function. In theory you hook this to the parking brake and when it's applied it will sent a negative to the attached wire, thus activating the playback. Just attach this wire to the negative ground on the system or wire a switch and install it in dash. With 1 wire going to the parking brake wire on the cd and the other going to the ground so you can de-activate it when you wish.
Sep 03, 2010 | Jensen Car Audio & Video
Car Audio & Video Logo
46 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Kazim ERGUNEY
Kazim ERGUNEY
Jerry Umali
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
