Question about SuperMicro Computers & Internet
Supermicro x9dai won't post, beep, boot or much of anything else
This is the second motherboard with the same issue. At this point, I assume it is something I'm doing wrong and not the hardware. That said, it is driving me crazy! I have the motherboard in the case, I"ve tried booting it with no cpu, one cpu and two cpus. The same with different combinations of ram and power supply connections to the board. The 24 pin from the PS to the MB is connected and so are the other 2 8-pins (I've tried with just 1 8 and the 24 and both 8's with the 24...again, can't get the system to just post. This is leading me to believe the board is toast. I have contacted SuperMicro (no help to this point). Thanks in advance for any help, its much appreciated.
  • nicolae cristian Nov 05, 2013
    this mb will no boot with v2 of cpu from intel.You must upgrade your bios to ver. 3.0 with an older cpu.The 8-pin conectors must be pluged in for cpu's!!!!
  • 40 Answers
This motherboard won't work with latest v2 cpu's from intel , until you upgrade your bios to 3.0 version.(you must plug your 8pin conector for cpu's , both of them !!!!!).So you must start the mb with an older cpu , then upgrade bios .
Posted on Nov 05, 2013
Jay_Sav
  • 93 Answers
SOURCE: System will not start up. Cpu fan spins once, then nothing.
It is more than likely that when your old power supply died a death, it damaged some components on the motherboard. Replace the Motherboard and chip, and you should be back in business. You can pick up some good value bundles to save money on buying the parts seperately. The power supply working again after turning off and on, is because there is a little trip in the power supply that triggers when it detects a fault. Powering down resets that trip allowing it to try and work again.
Posted on Mar 05, 2009
  • 35 Answers
SOURCE: WINFAST 760GXK8MC motherboard problem
It's possible that while booting your motherboard without the 12V power connected you physically damaged some components which eventually lead to the chip burning up.  However, it is quite possible that this motherboard was defective as Foxconn has discontinued it.  I would recommend RMA'ing (return merchandise authorization) the motherboard back to Foxconn.  While no one wants to wait for shipping it is probably your best bet.  Even if you order the chip that has been damaged, and can properly solder it back in place, there will most likely be other physical damage that is not visible to the eye.  I would recommend another motherboard, and Foxconn has quality mobo's for around $50.  Try visiting www.newegg.com. Hope this helps :)
Posted on Apr 22, 2009
  • 70 Answers
SOURCE: gigabyte MB no boot ga-ma790fx-dq6
did you replace the battery on the mainboard if its weak it will not beep
Posted on Aug 05, 2009
  • 396 Answers
SOURCE: SuperMicro X7DAL-E will not power up
I am using the same board with a PC Power and Cooling 1 K Watt power supply which is a little high in price and no longer available. I have been using PC Power and Cooling since the 1980’s and have had few problems and they have always kept up with the latest power standards if not exceeding them. The replacement power supply has even more power.
However, you can find adapters to use 4 pin IDE drive Power connectors for the 4 and 8 pin power connectors. PC Power and Cooling and Cables To Go both sell them. That is the cheapest fix for you but I would also use the PCI-E auxiliary power connector.
Follow the links:
http://www.pcpower.com/products/accessories/power_supply/
http://search.cablestogo.com/?Ntt=8+pin+power+supply&N=0
http://www.cablestogo.com/product.asp?cat_id=925&sku=35522
Posted on Jan 22, 2010
pgh_pa_guy
  • 2992 Answers
SOURCE: I've got a new Gigabyte
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Posted on Nov 20, 2010
Testimonial: "Thanx - cleared up the confusion about P1. Additional tests are pointing to a d.o.a. motherboard."
There is something wrong with my Nikon D3000. It turns on but doesn't show anything on the screen and when I look through the lens it's shows a grainy dark film. It can't be the lense because I...
There seems to be two separate issues here. I'm going to assume you have a charged battery pack in the camera.
First, the screen. Turn the camera on. Do you see the menu when you press the MENU button? Does the shooting info show when you press the Info button? Can you see previously taken photos when you press the Playback button? If none of those show up then something is wrong with the screen (or the battery is dead).
Second, the viewfinder. First, make sure the viewfinder in the back is clean. Now turn the camera on and look through the viewfinder. Do you see the eleven focus marks? Do you see the info at the bottom? Now turn the camera off and remove the lens. Don't touch anything inside the camera! Do you see a mirror at a 45-degree angle? Is it clean? Look at the focusing screen above the mirror. Is it clean? Now look through the viewfinder and point the camera out a window. Do you see a more-or-less white blob, or the same grainy dark film?
Apr 11, 2013 | Cameras
I change the power supply cause its not work and now its ok but there nothing display on the screen only the word say power seving
Assuming that you have correctly hooked up the power supply and that when you turn on the computer the power supply powers up as well as the CPU fan and the hard drive spins up, you have a video problem. While this COULD be because of a bad power supply, I think there is another hardware issue here.
You say you changed the power supply because it didn't work. I'd ask why didn't it work--did it suddenly make a popping sound or did you smell burning electronics? If so, when it failed, it may have taken part of the motherboard with it.
If you have an integrated motherboard (the video is actually part of the motherboard), then that is probably the issue here.
Just to be sure, disconnect everything BUT the CPU and memory and video. Then try to start it. If you see something on the screen (like a message telling you there is no boot device) then you can assume the hard drive or CD has gone bad. Reconnect the hard drive to see if it starts. Then the CD.
If you fail to get any image on the screen, assume that your motherboard is shot.
Mar 21, 2012 | Gigabyte GA-G41M-ES2L Motherboard
CS35-TL motherboard
I believe what you are seeing is the monitor displaying "no input signal". My question at this point is, how do you know the motherboard is running? Are you getting the single beep for successful post? or are you just hearing the fans kick on when power is applied and assuming its working? The computer kicking on but not posting can be caused by a grounding issue from the mother board to the case. You can buy small rubber washers at the hardware store to place between the case and the motherboard were the screws go in. This will eliminate most grounding issues. If what I have said is not the case, then please clarify your post some.
Jan 27, 2012 | DFI CS35-TL Motherboard
Acer3000 yellow light solid and will not power on Help! Is this motherboard issues?
It's very possible you have motherboard issues. Hardware failures will often resemble the machine being stuck in "sleep mode". You can try a power "reset" in case it is stuck in sleep mode. Press and hold the power button for 30 seconds. If successful, the machine will boot (probably in safe mode) and you should be able to re-configure your power settings to disable sleep mode. If this doesn't work, you most likely have hardware issues and the motherboard is most likely the culprit.
Aug 20, 2011 | Acer Computers & Internet
When I try to print I get an error message scanner failure turn power off and then on
Hi there.. Regarding with your issue, one of the possible reasons why is that the printer is saying that it's because there might be a big chance that there is something wrong with the scanner bulb of your printer that can lead into a hardware failure.. now here's the document that you will need to follow to resolved the issue.
open this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00587971&cc=us&lc=en&dlc=en&product=421991&tmp_track_link=ot_search#N82
now after doing all the steps on the website and if it didn't help, then do a semi full reset by unplugging the power cord from the back and then press the # and the number 6 at the same time while the power is off..after a few seconds reconnect the power cord from the back of the printer while still holding those buttons up until you see something on the screen of the printer saying "nvm reset" something like that..
but still after doing a reset and it didn't fix the problemthen the printer is having a hardware failure or in other words it become faulty.
if you have any questions, dont hesitate to reply on this message..
Goodluck!!!
May 30, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have A desktop motherboard model asrock m266a,when i start it it will have 3 long beeps and stops for a while and another 3 long beeps
Hi.
3 long beeps means there's a problem detected with the keyboard. Remove the keyboard and turn the computer on and see if it boots up. Also a good idea is to make sure the system memory is seated properly in the slots.
Regards.
May 03, 2011 | Computers & Internet
Alarm sounds coming from the computer
hi I think it has to do with Asus AI Bios. It usually informs you when something wrong with your hardware. I had issue when it was sayin wit strange computer voice that CPU fan has failed! May be your PC is overheated when it makes this sounds!
May 21, 2010 | ASUS P4P800E Deluxe (90M8LCW0G0EAY)...
Wifi not found
See if a PCI or network controller card appears in Device manager first (control panel).
If the computer detects the WIFI card it will be installed or appear with an exclamation point.
Check that first, if the card appears with an exclamation mark, click uninstall.
Download the WIFI card driver from Compaq. Install the driver and restart the computer.
Once the computer restarts, then it should automatically detect the hardware and boom should be working.
If this does not solve the problem (assuming the exclamation point was there) then uninstall the WiFi card again and restart the pc.
This time allow the computer to restart and detect the hardware. Do not click anything on the hardware wizard. Instead run the WiFi card driver software again. Restart pc and hope it works.
If not, let me know and we can try something else.
Brian
Jul 05, 2009 | Compaq Computers & Internet
D945GNT motherboard is giving an alarm
yor mainboard is working or not first?
second if is not working they are two posibilities, one your ram is gone , or miss placed or something else, second your processor is gone or wrong.
if it is working i dont now, anyway in the both cases try to clear the bios rom first
Apr 01, 2009 | Intel D945GNT Motherboard
Computers & Internet Logo
945 people viewed this question
Top SuperMicro Computers & Internet Experts
David
David
Victorman
Victorman
Joseph Hoffmann
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
