Question about Canon Copier Toner Cartridge Npg 4 For Np 4050, 4080, Black
How to canon np 4050 scanner lamp continuously on
  • Canon Expert
  • 1,326 Answers
It would be in service mode, why would you want to turn it On continuously??? Does the lamp turn ON with warm up? If so, the lamp and fuse is good. When you make a copy, will the lamp turn OFF and ON when it is scanning the original? If it dose, you will need to replace the scanner power cable. This copier is very, very, old.... I was trained on it over 20 years ago... Parts may be hard to find.... Good Luck
Posted on Sep 05, 2013
I have machine canon 6030 np and there problem called : E224 please send how can I solve it
Basicly, a E224 is a scanning lamp error code. Here's a question for you??? Will the scanning lamp turn "ON" at all? If so, then the problem is with the scanner power cable. If the lamp will not turn "ON" you may have a blown lamp & or thermal fuse on the scanner unit. You can not clear the code until the problem is fixed. Good Luck
Feb 16, 2011 | Canon NP 6035 Copier
E02 in canon Np 160
I believe a E02 deals with the scanner. Your copier is very old. It has been a long time scine I've worked on one. Have you checked that the exposure lamp has continuiy? If so, you may have a blown thermal fuse for the scanning lamp. Also, dose the scanning lamp turn "ON"? You may have a broken scanner lamp power cable. You should be able to order the parts on line.. Good Luck...
Dec 27, 2009 | Office Equipment & Supplies
NP 4050 -
The door may be closed, but there is a inter lock switch that is not being closed. If you have all four paper tray, try to turn the copier off and disconnect the bottom two cassette's from the back of the copier and turn it back "ON" and see if the copier works. If it dose you have a problem with the bottom two tray's. You have a very old copier, can you do with out them? If not the switches are toward the front & it may just be knocked out of place... Good Luck...
Sep 17, 2009 | Canon NP 6050 Copier
Can u tell me the load capacity of canon 4050
2.5 kva with 4 battrys any company
best for u.
Aug 04, 2009 | Canon NP 6050 Copier
I want to bye the model np 4050 i want known the price
I happen to have a NP 4050 for sale. Please contact me at yaucano1970@gmail.com. Thanks.
Feb 19, 2009 | Canon NP 6050 Copier
Canon NP 4050
I use this one
precisionroller.com
Oct 19, 2008 | Canon NP 6050 Copier
Cannon np 4050
The toner is not adding correctly into the developing assembly. 1) If toner hopper is overfilled, the toner motor worm gear splits as a result of the hopper becoming packed tight. 2) Sometimes the worm gear splits under normal use.
Jun 03, 2008 | Canon NP 6050 Copier
Canon np 4050 low fusing temperature
I am not 100 percent sure what is happening to your machine after it comes to ready, but I will offer some thoghts.
If it comes to ready and then goes back to a low heat situation. It very well could be the board if it doesnt maintain heat.
Now that being said, once a coiper comes to ready and reaches full heat, it will switch over to pulsating the heat roller, not staying on fully all the time. That is how fusers are designed. Full on until they reach operating temperature, then pulsating to maintain the rollers heat level.
If you are having a problem with the image not fusing to the paper, you may have an issue with the pressure roller not making good contact with the heat roller.
There may be a software setting that needs adjusted to increase the fuser operating temperature.
The flickering heat rod, once the machine reaches ready, seems appropriate.
If you want more of an idea, can you be more specific as to whether the machine is faulting out with an under heating situation, or is the image not fusing to the paper properly?
Dec 07, 2007 | Canon NP 6050 Copier
Canon Copier Toner Cartridge Npg 4 For Np 4050, 4080, Black Logo
52 people viewed this question
old marine
old marine
