Question about SanDisk Sansa e250 MP3 Player
Where did all the memory go?
Windows Explorer says that there this 1.64Gig used out of the 2G. But all of the used space in the files and folders on the e250 (tmp; system; photo; music; record; playlists; pictures) only add up to 347Meg in total. This includes all hidden files and folders. This is when the device is in MSC mode; There do not appear to be any significantly sized files when I put it in MTP mode) So where has all that other 1Gig of space gone to? I would really appreciate any advice on this please.
  • gough brown Jun 10, 2007
    Thanks for the suggestion, however I had already tried that(sorry I should have said that in the original note).
    The defrag worked and the files were restructured, however there was no space reclaimed. The memory map after the defrag shows a block of memory used in the early sectors and a block used in the middle. Lots f white space, but Windows still shows the memory all used when I show properties. Thanks for trying. Any other suggestions would be appreciated.
    Brownie99
  • gough brown Jun 11, 2007
    Thanks 24seven!
    You were right. The scandisk and defrag did work. It was my lack of system knowledge that got in the way of the complete solution!.
    The scandisk/defrag created a folder called FOUND.000 and which contained dumps of the erroneous files that scandisk/defrag found.
    Why didn't I see this folder before?
    I couldn't see that FOUND.000 folder in Windows Explorer when I used the "open" option to view the folders in the sansa drive letter.
    But when I right clicked on the drive letter, and selected "open as Portable Media Device" I would see the FOUND.000 folder with all these files taking up the 1.3Gig of space.
    What was the fix?
    I have deleted that FOUND.000 folder using Windows Explorer and now I have the missing 1.3Gig of space back.
    Thank you 24seven. You are an mp3 saver!
    I'd also like to acknowledge "BigSam" who on March 3rd posted on another forum, a similar fix for the sandisk e260.
    Brownie99
THANK U SOOOOO MUCH!!!
Posted on Aug 14, 2007
  • 883 Answers
Try running Windows scandisk and then defrag on the Sandisk player.
Posted on Jun 10, 2007
Deleting tracks off 4gb sa2640 gogear
The files are not deleted from the device but moved to the recycle bin. To completely remove the files from the MP3 player, use the following procedure:
1. Open Windows Explorer by double clicking the My Computer icon on your desktop.
2. Click on the Tools menu and select Folder Options.
3. Select the Tab View and check to select the Show hidden Files and Folders option.
4. Navigate to the device. A folder called recycle bin is available. Completely remove this folder from the device.Once the recycle bin folder is removed, the files are completely removed from the device and the free space is available.
Mar 27, 2014 | Philips GOGEAR SA6045 MP3 Player
Tip
File system errors / possible firmware bugs.
Here are some observations.
With the internal memory formatted by the player itself:
1) The player always has multiple malformed root directery entries that don't show up as files in Windows Explorer. Particually, the "Services" folder is slightly malformed. On some systems, the Services folder won't show up in Windows Explorer (like Windows 98).
2) Any memory formatted by the player whether intneral or a microsd card, will be completely missing a partition table.
If the internal memory is formatted by anything else other than the player itself:
1) The player will not be able to write the library database and user settings to the internal memory. The song and artist names will always be "Unknown" and "rebuilding library" every time the player is truned on. The library database and user settings files show up as multiple zero length files in the root directory, one with the same name for each time the player is turned on.
2) The Audible directory will be created and filled with many, many garbage files with garbage names with very big sizes that don't actually take up memory space.
3) Trying to use a microsd card that was formatted by anyhing else results in the player hanging when rebuilding library when it tries to scan the external microsd card. The player has to be shut off buy holding the power switch.
on Jun 28, 2008 | Insignia Sport MP3 Player
I have inserted a memory card and added music onto this but can' play it. I can see that they are there when I check the computer but I can't see them on the MP3
Make sure that the mini card is only 2g only a 4g isn't compatible.. Check in the sansa settings to see if the card is recognized...The folder and files are hidden. Connect the sansa and open up your explorer so you can see the music folder Click on TOOLS on the top of your explorer then click on FOLDER OPTIONS then click on VIEW Where it say's Hidden files and folders click on Show Hidden files and folders...You will be able to see the folder and music.. to undo reverse info..
Oct 21, 2011 | SanDisk Sansa e250 MP3 Player
I am losing hard disk space What can I do Thanks
1- Do hard disk cleanup - This will help you remove hidden files and folders
2- Move or delete old videos and pictures
3- Compress some old files
Aug 03, 2010 | IBM ThinkPad T30 2366 Notebook
Hi, I got a new 2.GB SD card & have transferred all files including latest maps update but a red X appears on the device. Its not running? Please help
It is possible that some hidden files on the original/internal memory have not been transferred.
  1. If you are using Windows open the directory corresponding to the internal card.
  2. In Windows explorer activate the TOOLs menu on the menu bar,
  3. Select Folder Options, then the
  4. View Tab.
  5. In the main screen that pops up, look at the tree and locate for Hidden Files and Folders,
  6. Put a check mark in the radio button that says Show hidden files
Use the explorer to visit the folder corresponding to the internal card
Point inside the folder away from any icon and press CTRL A to select All, then CTRL C to copy all the selected files and folders.
Go to the second (formatted) card and press CTRL V to paste all.
Verify that you copied everything by comparing the amount of disk space the two folders (in internal memory and in external card) occupy. Values should be very close.
Jun 23, 2010 | Tomtom ONE GPS Receiver
Dell Dimension 4600 desk top out of virtual memory
Some computers can be slow or short of hard drive space for quite simple reasons.
Windows and other program hide temporary files in lots of different places
The best option is not always a program or utility and if you want to do as much as you can for FREE like I do then you have a few options.
1. First you need to be in windows explorer.
2. Click TOOLS and FOLDER OPTIONS
3. Now click the VIEW tab
4. Tick the Show Hidden Files And Folders option
Unpick Hide Protected Operating System Files (it may warn you but you can ignore it)
5. Click APPLY then OK
6. NOTE some files may not delete this is OK Also DO NOT DELETE the folder itself where mentioned for cleaning.
7. Using windows explorer go into the WINDOWS folder and look for a directory called TEMP (it is possible there may be more than one)
8. Select all the contents and delete them. Do the same for any other temp folder e.g. temp000
9. Now navigate to Documents and Settings
There are quite a few folders in here that can be cleaned up
10. Look for folders named "Local Settings" In there you will find more TEMP folders that can be cleaned out
11. Now look inside the Temporary Internet Files. Delete anything EXCEPT cookies. Otherwise passwords for some sites you have stored may need you to type the password again.
12. Do this for each user / profile you see.
13. Now check the C: drive itself and see if there are any Temp folders and clean those out too
To prevent accidental deletion of any files windows needs you should go back to step (4) and change the two settings back to their original
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Dec 11, 2009 | Dell Dimension 4600 PC Desktop
Transferring music files with a memory stick
Insert the memory stick into a USB port on your computer.
Windows will recognize the device,
and give you a choice of applications, i.e., play music with Windows Media Player, or, use Windows Explorer to browse.
Select Windows Explorer.
Click to select the files/folders.
Choose "Copy Files".
Copy into your "My Music" folder on your new computer.
Nov 14, 2009 | Computers & Internet
FREE UP HARD DRIVE SPACE
Hi! Your 3 Gigs of memory have nothing to do with your disk storage. You may try freeing some disk space by doing the following:
Clean up your recycling bin by selecting the Empty Recycle Bin option, after right clickin on the icon.
Clean up the All User's temp directory, usually within your Windows installation drive-> Windows folder, called TEMP folder.
Clean up your own TEMP folder, usually hidden and found within your own user name folder. To make this folder visible, in File Explorer, go to Folder Options, and find the entry that reads: Hide system files. Uncheck the option. Make sure you reset it after you're done.
A little riskier is to try to resize your virtual memory, or the amount of disk space that Vista (and other versions of Windows) uses to emulate physical RAM, when you have exhausted it.
You may also save disk space by sacrificing the Hibernation feature by disabling it. If you do this, by going to the Advanced Settings of Vista, under System, uncheck the box next to your drive, and while having Hide System Files also unchecked, you can physically delete the file, usually found at the root of your main drive (usually C:) Note: For this change to take effect, you will have to restart your system with a cold boot.
Try buying some software similar to Norton Utilities (a reduced of it is available in Norton 360) that will defragment your drive but will also clean up stray and orphan files left behind by improper uninstallation of other software and temp files left behind when an application like Word, or any other, crashes.
Oct 08, 2009 | Computers & Internet
Sandisk m2 2g card got currupted.....
format it on the PC with FAT16 type file format
Dec 09, 2008 | SanDisk 2GB Memory Stick Micro M2 Memory...
Sandisk m2 2g card currupted
the write is corrupted..myt due be due to some hardware error..!!
SanDisk Sansa e250 MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
