Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
NrO fault code on bosch logixx 8 - Bosch Logixx WFT 2806 Front Load Washer/Dryer
NrO is child lock. Hold start button for 5 seconds to remove.
Posted on Jul 06, 2014
SOURCE: Bosch washing machine logixx 8 front loader error
Det er for koldt i rommet, eller vandrør har frosset til.Sett opp temperatur i rommet eller tine rør
Posted on Jan 15, 2010
  • 414 Answers
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Posted on Jul 07, 2010
  • 3741 Answers
SOURCE: i need a bosch WAS24466GB user manual
click on the link below and download the manual,if asked you will have to enter model number or else you can download user manual directly from the link:
bosch user manual
thanks.
Posted on Aug 31, 2009
Testimonial: "thank you, that was very helpful"
SOURCE: bosch logixx code f-23 .wat does it mean?
it means the float at the base of the machine has been triggered. Open the back panel on the machine (turn off power and water tap first) then remove all screws and take metallic back off. Dry inside base with a towel and push down the float which is located in the corner. This will reset it. Keep an eye on it as it may mean you have a leak.
Posted on Aug 04, 2010
  • 3 Answers
SOURCE: My bosch logixx 8 sensitive front load washer is
I have a Bosch Logixx was bought in April 2009 and I have had this problem several times, it seems like a button or coin can block the pump, you may need to try turn machine off and pull out plug, take the drainage hose out of the holder, remove sealing cap, allow detergent solution to flow out, put the closing cap back on hose, carefully unscrew the pupm cver, see if anythings stuck there, re-insert pump cover etc. I have had to call repairmen out 3 times ( pump blocked not covered under warranty) and had pump replaced, I WOULD NOT BUY BOSCH ever againa s there after care service is rubbish and I paid $1800 for this metal junk.
Posted on May 18, 2011
Bosch avantixx 8 waq error code e44
E44 means a motor fault. More here: http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes.html
Mar 03, 2015 | Bosch Washing Machines
Bosch washing machine (logixx 8) shows error code F57
The E57 error code on the Bosch Logixx 8 means that there has been a door lock fault.
Feb 13, 2015 | Bosch Washing Machines
Bosch logixx 8 E57
Circut board of the motor is demeged.if you take out the board witch is next to the moyoryou will see on the electronic print
The demeg.
Nov 20, 2013 | Bosch Logixx WAS2446 Front Load Washer
Bosch Logixx 8 - unblocking pump/removing front panels
Bosch Logixx 8 Washing Machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 30, 2012 | Washing Machines
I have a bosch logixx 8 washing machine. Fault code f67 when I turn the machine on. What does this mean?
I have Logixx8 WAS 32782 that got the f-67 code. I had it repaired today and the technichan updated the software. f-67 was indicating "lost contact with display panel". The display panel had of some reason erased its software. SW update was the standard solution.
Oct 02, 2010 | Bosch Washing Machines
Bosch Logixx 8 Washing Machine E-NR-WAS28466GB /03
The heqating element has blown - common problem on our machine - happens around once per year - under warranty - now on our 3rd new heating element !
Mar 17, 2010 | Bosch Washing Machines
Bosch logixx 8 washing machine showing F37
F37 is because of operating the unit below specified temperatures.
Pressing the temperature button twice shows a snowflake and sets a defrost function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jan 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
720 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
