Question about Troy Bilt 5.5hp Self Propelled Mower
My 5524 troy built snow blower wheels have locked up in gear
5 Suggested Answers
SOURCE: My Troybilt Snow Blower wheels have locked up
Just found the same problem with mine.  The bearing on the gear shaft is frozen.  To replace these, follow the instructions in the manual to replace the friction wheel, then tap out the bearings in the side of the case, you'll probably find one frozen up.  As long as you're there, might as well put in a new friction wheel.  Mine is looking pretty worn after fighting the bearings all winter.
Posted on Apr 19, 2009
lonewolf1996
  • 142 Answers
SOURCE: I have a Troy built front wheel drive mower made
It sounds like you need a new belt for the front wheels.
Posted on Jul 31, 2009
  • 89 Answers
SOURCE: how do i essemble a pull starter on a troy built
to just put the rope in take starter cover off look inside the cover and turn thr pully to the left counter clock wise turn till it turns no more line up the two hole one from the pully and one on the starter cover where the rope was originaly put the rope in thr hole and tie a knot this is called preload has to have tention on thr pully to pull the string back but if thr spring is broke its another process
Frazier
Posted on Nov 02, 2009
flores136959
  • 215 Answers
SOURCE: Wheels have locked up on
spray some WD 40 on them let it sit on them for a little wile then try.
Posted on Mar 01, 2011
Troybilt snow thrower wheels lock up cannot push or pull. Model 5524. Whats up?
Sounds like friction disk is not retracting for pressure plate. Flip snowblower up on front end and take out 4 or 6 bolt out of cover plate. wheels will be in the air so try to turn wheels and look. Your fiction disk is the rubber wheel that moves with you gear shift lever. It should not be touching round metal plate unless your handle on bars is push down to in gage drive. Most snowblowers have a spring to pull metal plate back your probably broke or rusted off.
Feb 24, 2015 | Garden
Troy built snow blower the electric starter grinds
sounds like your starter pinion is stripped. remove your starter and inspect the gear. If the teeth are worn then replace gear if not replace starter. you will also want to check the teeth on your flywheel
Oct 07, 2014 | Garden
Will a 42 inch troy built 2 stage snow blower fit a 2013 troy built poney
howdie what are ya changein ?the blower the motor need more lmfo please or measure the parts line them up look at them you Deside what it looks like I can,t see it so tell me more thks for your time
Oct 06, 2014 | Garden
Troy bilt 5524 snow blower with no spark
check kill system... there is a safety switch close to the auger or the cover for it... then suspect a coil but next time, how about mentioning the engine because troy bilt never doesn't make engines
Aug 24, 2014 | Garden
Troy built 8 hp tiller how to adjust the reverse lever
There is a Turn Buckle on the Cable and adjusted that way. But you may have an Issue Internally. If the Rod that holds the Wheel has become lose, you may have to remove the rear cover and tighten everything back up
May 29, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Where are the grease fittings ona Troy built riding Lawnmower that has a19hp Koehler engine and the mower is called bronco
There are only 4 I know of inside the 2 front wheels on the axle and 2 on the steering knuckles.. you may have some on the deck spindles but most of them are sealed now days
Apr 24, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Snowblower always in gear and wont throw snow and cant move when engine is off
Service kit available for that mess of gears in the motor box(needle bearings inside the gear seize up), there is also a shear or sacrificial adapter mounted to the impeller input shaft Parts and Diagrams for MTD 31AS63EF729 2011 check around part # 7 and 15 top right hand corner. hope this helps. if this didnt help check out this web site
Feb 05, 2014 | Garden
Troy-bilt 5524 snowblower - the drive wheels are locked. Pulled it apart and everything turns but when all gears are in place wheels won't turn - If I move the small gear from the drive it works but goes...
The outermost large gear has 'needle' bearings that will over time get snow, salt grim caught in them and they freeze up. Remove the gear and intially work some WD-40 into the bearings with your fingers. Mine loosed up fairly easy. Continue adding WD-40 to kind of rinse away the grim. Then, dry it out with a rag. I added some lithium (white) grease and worked it good before replacing. Once replaced, it will spin like a top!
Oct 31, 2010 | Kitchen Ranges
Apr 11, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
246 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
