Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Green Screen The picture is fairly clear and the sound is great. However, the picture has a very bad green tint to it. What should I do? It is a 2004 60pp9202/17f
    Scholar:
  • 87 Answers
Sounds like the coolant in the green picture tube needs changing.
Posted on Jan 12, 2009
67" Samsung DLP. Last night it started flicker to a green tint. Back to normal then green tint. Now it's completely a green tint. Still has picture and voice but green tint and not bright like before.
In those sets there is what they call color wheel and it could be on its way out it sounds like its stuck.or not working prop in any case you need to bring it in for service place
Mar 26, 2013 | Televison & Video
Picture is not clear. Has a green tint and glow.
Repalce the coolant in the CRTs. You can get the Phillips CRT coolant replacement kit at www.tvrepairworld.com the kit contains the coolant and the CD with instructions
Oct 13, 2009 | Philips 50P8341 50" Rear Projection...
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Help me willtab guru man...Please.
What is the make and model of your television.. green tint and vertical lines indicat a problem with the light engine..although the clear menu says otherwise..im not sure what type tv you have. lcd plasma change the light im guessing you mean bulb .. this indicates to me you have a dlp. but green tint to me indicates a tube projection type tv... so im just guessing hear. vertical lines also indicate a bad buffer board on a plasma or lcd. so let me know what you have
Jun 16, 2008 | Televison & Video
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Feb 18, 2008 | RCA 20V500T 20" TV
Green Tint on half of the screen
This is most likely a defect in the optical unit (about $1500.00 part). If out of warranty probably will just have to live with it. Those op units are also hard to get.
Jan 15, 2008 | JVC HD-61Z575 61" Rear Projection...
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Picture tinted green
green tint & screen dark means that there is a problem in green video circuit. 1 check green video supply . 2 components in green video ckt. 3 adjustment in green video section. 4 check for signal to green video.
Sep 16, 2007 | Toshiba 36AF42 36" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
150 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
