Question about Ovens
Need instructions for BonJour double boiler cookware
How can I get replacement instructions for my 1.5 quart Bonjour stainless steel double boiler? Lost them!
SOURCE: replace doors on jenn air oven with stainless
It is possible but usually costs more than the oven is worth. Call Marcone appliance parts in St. Louis for pricing.
Posted on Jun 29, 2008
  • 97 Answers
SOURCE: Need a manual to operate five year old Jenn Aire wall oven
Jenn Aire model tag are usually at the opening of the door, or may have to pull unit out...be sure to check around the door before pulling out.
Posted on Jun 08, 2009
  • 13 Answers
SOURCE: How do I find out what model my Neff is please -
open the bottom oven door and you will find a small silver plate on the left side of the oven frame. the model number follows the letters "ENR".
Posted on Jul 29, 2009
mark_37388
  • 100 Answers
SOURCE: THE INSIDE GLASS BROKE
part number is 4449259 of the inside glass you will pay around 60.00 for it good luck
Posted on Jan 12, 2010
  • 572 Answers
SOURCE: oven seems to work but the display panel dark.
Posted on Feb 11, 2010
What type of cooking vessels are needed to use on the Technika cook top which is induction heated .
it only works with cooking vessels made of magnetic materials. The commonest such materials used for cooking vessels are stainless steel and cast iron. Cookware suited for use with induction cookers, from the extreme high-quality end down to thrift-store modest, is readily available; but if you already have a stock of mostly expensive aluminum or copper or glass or pyrex cookware and little or no cast iron or stainless,
Dec 19, 2010 | Ovens
We have a GE Profile cooktop in the house we bought. I found the manual from previous owners of house and it is a JP350. It has white knobs (4 large and one smaller one). I would really like to have...
Bonjour, j'ai un four GE Profile électrique acheté en 2006 et lorsque je veux me servir du fourneau, tous les boutons digitaux sur lesquels j'appuie donne comme résultat "LOC On". La plaque fonctionne toujours bien c'est seulement pour la programmation du four que j'ai un problème. Est-ce qu'il se peut que j'ai appuyé par mégarde sur quelque chose qui verrouille les commandes car jusqu'à dimanche dernier il fonctionnait bien? Comment régler ce problème? Merci à l'avance
Nov 05, 2010 | GE Ovens
No heat when oven is turned on, fan ok
did you check if the element is craked could need to be replaced. even if you don't see anything check with ohm meter make sure there is some resistance (over 20) also try oven on boiler see if that helps
May 18, 2010 | Smeg SE210X/1 Stainless Steel Electric...
How to remove scratches from stainless steel appliances
Try this at your own risk. Step 1 Consider using a product made for stainless steel2_bing.gif such as Scratch-B-Gone or Bar Keepers Friend (see Tips).
  • Step 2 Or, try spraying an all-purpose cleaner (such as Formula 4092_bing.gif) on the scratches.
  • Step 3 Use a non-metal scouring pad (such as Scotch-Brite pads) to rub the cleaner in, always rubbing in the direction of the grain.
  • Step 4 Keep the stainless steel wet with the cleaner as you work, and rinse the pad often.
  • Step 5 Rinse the surface and wipe dry.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Tips & Warnings
    • Before using any treatment on your stainless cookware, sink or appliances, it is wise to call the manufacturer for advice.
    • A new product called Scratch-B-Gone is touted as the "first aid kit for stainless steel." You can find it at many home improvement stores.
    • Bar Keepers Friend is another product for stainless steel. It can be found in most grocery or home improvement stores, or at www.barkeepersfriend.com.
    • To keep stainless steel sinks from scratching, put a rubber mat in the bottom of the sink to protect it.
    • Avoid using abrasive
    Please rate 4 thumbs for the free answer
    Mar 13, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Hotpoint uy46 style line stainless steel, 2 year old, main oven fan takes 20 to 25 mins to start then runs too slow and some times stops, but the heat element is glowing red and very hot
    The symptoms you describe are an indication that the fan motor is in imminent danger of breaking down altogether.
    You need to replace it as soon as possibe, otherwise you will end up with the element burning itself out, thus doubling the cost of repair.
    Please rate my solution.
    Thankyou.
    Jan 26, 2010 | Hotpoint UY46 Style Line Stainless Steel...
    Cleaning the stainless steel griddle??
    We buy DeBruce Polish at debruce polish.com this stuff really works!!
    Mar 28, 2009 | Thermador Professional Series PO301...
    GE monogram double oven display getting extremely hot
    Usually the knob type controls uses the bulb for temperature regulation. There is usually only one adjustment available - otherwise the thermostat has to be replaced. - that dial with the temperature graduations on it. the whole unit - the bulb in the oven is connected to it.
    Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
    Ovens Logo
    70 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
