Question about Graco Baby Gear
Remove straps from graco sweetpeace
Removing the straps
2 Suggested Answers
SOURCE: need a user manual for graco sweetpeace newborn
I received a Sweet-peace newborn swing and the A/C plug is pushed in. Is there a way to retrieve it? How hard will it be to take the swing apart and retrieve the plug? You can reach me at my e-mail at: dragonman34@mail.com Thank you for your time.
Posted on Oct 24, 2010
Remove fuel tank on 95 Ford aerostar. It has a vapor leak we must repair a leak in vapor recovery system
Removal and Installation
  1. NOTE: Make sure fuel tank (9002) is properly supported during removal and installation procedures.
    Drain fuel from fuel tank .
  1. Loosen fuel tank filler pipe clamp.
  1. Remove fuel tank heat shield (9A032) from vehicle.
  1. Support fuel tank .
  1. Remove bolt from rear fuel tank support strap (9092) and remove rear fuel tank support strap .
  1. Remove bolt from front fuel tank support strap and remove front fuel tank support strap .
  1. Partially lower fuel tank to gain access and remove feed and return lines from sender ports. To disconnect push connect fittings, refer to Push Connect Fittings in this section.
  1. Remove electrical connector from sender unit.
  1. Remove fuel vapor hose from evaporative emission valve (9B593) .
  1. Lower fuel tank from vehicle.
Apr 04, 2017 | 1995 Ford Aerostar
How do you adjust straps on a baby car seat?
Graco SnugRide 35 : Adjusting Harness Straps - YouTube
? 6:41
https://www.youtube.com/watch?v=vl_JSaEuu0U
Jun 23, 2012 - Uploaded by Baby Car Seat Installers
This video shows how to adjust harness straps for the Graco ...Graco SnugRide 35 : Adjusting Harness Straps. Baby Car SeatInstallers.
Britax B-Safe: Adjust Car Seat Harness Straps - YouTube
? 3:12
https://www.youtube.com/watch?v=XGHnSLXRqq8
Mar 2, 2014 - Uploaded by Baby Car Seat Installers
We teach you step by step on how to move the harness strapshigher as your child grows. This video is for ...
Nov 17, 2015 | Cosco Baby Gear
Crouch strap
Hi
Please contact Graco for assistance with correct use of the harness
Get news from Graco delivered right to you inbox
May 10, 2014 | Graco Nautilus 3-in 1 Car Seat
Recall
Graco Snug-Seat
From the Owners' Manual:
STOP USING INFANT RESTRAINT AND BASE AND THROW IT AWAY after the date molded into the back of the infant restraint. "DO NOT use this car seat after December (Year)"
Please cut off the straps and remove the cover from the seat before throwing away (or recycling). This will keep others from trying to reuse or resell the out-of-date seat.
-- Marc
Jun 10, 2013 | Graco 8A03QST
1990 ford ranger gas tank straps replacement
Get new straps. Drain gas tank if possible, prop up gas tank from underneath, remove old straps, install new straps.
Jan 12, 2013 | Cars & Trucks
Couldn't found the gas tank bolt
The tank has to have straps holding it on &
the straps have to have bolts or nuts
Dec 04, 2012 | 1988 Chrysler LeBaron
We need the base to a Graco Sweetpeace baby swing.
Under the "Add your solution or ask for clarification" window click on the camera icon to add photo.
May 25, 2012 | Graco Sweetpeace Newborn Soothing Swing...
REPLACING FUEL TANK STRAPS
I know it can be a bear if the bolts and pins are rusted. Unless the new straps are OEM, some after market straps don't fit quite as well and you need Godzilla strength to manover them into place to get them pinned and bolted back up.
You shouldn't have to drop the tank as long as you do the straps one at a time. Get a floor jack, transmission jack or even a motorcycle jack and place wood under the gas tank and do one strap at a time. I used a second jack to help push the strap in place so I could push it into place on a 97 Dakota. Good luck and sometimes it goes smooth but, some times it makes a preacher say things they wouldn't say in church. :)
Dec 28, 2011 | 1996 Dodge Dakota
Baby Gear Logo
62 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
