Question about Staples ID Armor SH2836ID2836 Shredder
How do I take apart a paper shreeder apart with model #id armor xc180p
Left side seems to want to shreed but right side doesn't shreed
2 Suggested Answers
SOURCE: I have an ID Armor
I think it is necessary for you to take it apart. Is your shredder designed to handle plastics such as CDs? Try these steps and see if it will do you any good.
Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers. Look for small debris from the CD which may be stuck inside the shredding/feed mechanism.
Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small plastic scraps that may cause a jam.
If the cleaning failed and your shredder still wont start. You need to have the shredder serviced as the damage may have extend to cause a mechanical failure on the device.
Hope this helps.
Posted on Sep 20, 2011
Shredder says overheat
They get a lot of paper dust in the motor area
Feb 12, 2017 | Staples Office Equipment & Supplies
Delayed start
Unlikely if it was working normally before you cleaned it. You have most likely disconnected someething
Dec 14, 2012 | Casio Parts Cash Register PC Desktop
Why is my ID Armor ID-XC200D making a horrible noise when I shred?
kkrenn641:
That "horrible noise" is probably caused by the shredder gears meshing improperly. If you disassemble it again and look carefully at the gears, you will most likely see that some are not mating properly... Usually the motor gear and the first idler gear that meshes with the motor gear. If those two gears seem to be separated a bit, or slightly mis-aligned look carefully at where the motor mounts, and you may see that the plastic "bed" where the motor is mounted has melted from heat from the motor. This is caused by using the shredder too long without letting the motor cool down. You may be able to shim the motor housing to realign the gears, if you have the patience!
Sep 13, 2012 | Staples ID Armor SH2836ID2836 Shredder
Left margin cuts off text
If text is cutted of, this is a problem of the settings of your paper size. It can be different according the software you are using (Do you print from MS Word or some other application?) You have to control the paper size settings in your driver. In your pop-up screen of the printersettings, you'll see an example on the right side. It shows the printing area. You can change it on the left size. Sometimes the numbers doesn't change, than you need to push the button 'properties' and look for the papersize in here. If that also doesn't work, make a pdf of your document and try to print it again, and hit the button 'paper size based on pdf' in your driver.
Nov 30, 2011 | Canon PIXMA MX860 All-In-One InkJet...
Hi, I am having problems printing a Word document. When I press Print, it only prints two-thirds of the page. What am I doing wrong please?
Okay, the paperfeed at the top, on the left hand side there is a grey slide, (right in the printer) to hold the paper in place. Use it to keep the paper straight! It seems that if the paper goes in straight, the whole page is printed, if it doesn't it messes up the page.
Worked for other people having trouble with Epson Printers
Sep 15, 2011 | Epson Office Equipment & Supplies
Canon mp220 pulling paper to the right and jamming
This is caused either by a small piece of paper left in the printer after a paper jam where the majority of a sheet of paper has been pulled out but with a corner torn off and still left in the printer or it can be from a foreign object dropped into the paper feed tray. Sometimes turning the printer upside down and shaking it can dislodge the object, if it doesn't, you will need to take the printer apart to look for the problem. A few philips head screws around the printer will need to be removed first then carefully 'pop' the plastic clips apart using a small flat screwdriver.
Sep 11, 2011 | Office Equipment & Supplies
I don't have any sound on my pc,with XP home. I can't find any driver for my motherboard
You can download the audio and device drivers for your laptop from the motherboard manufacturer's WEB site.
I cannot give you the link to the motherboard manufacturer's WEB site because youhave not provided me with the details of the make and model of your motherboard.
Aug 21, 2011 | Computers & Internet
Stopped working while i was using it
Mine does that when it jams, or overheats. Try toggling the switch between forward and reverse to clear any jam. If that doesn't work, you can unplug the unit, turn it over, and remove jammed paper with needle nose pliers.If there is no jam, try letting it cool for a while and then try in the reverse position.
Oct 29, 2010 | Staples ID Armor IDX50B Shredder
Shreeder Feeder jammed , appears cleared, makes a humming noise when attempting to feed paper and a similar noise when hitting the reverse button. Help please. Thank you.
It could be one of two problems and they are both usually caused by over feeding. Either the tooth rollers have junped out of their sockets or they are jammed tight with paper which would cause the first to happen also. There are safety switches but unplug the unit any way. Get on the output side of the shreeder and start pulling paper or remove the metal object that was dropped into its throat. Hopefully, you won't have to take it apart to put the rollers back into their sockets.
May 28, 2009 | Office Equipment & Supplies
Shredder won't accept paper on left side
If you think you have taken all the screws you may not know that most often there will be a hidden screw ot two under a sticker or a plug.It may be that your unit has tabs that simply need to be pulled apart. Unfortunately I only know Fellowes products but maybe this will help. Good Luck.
Feb 22, 2008 | Royal VF1000MX Shredder
Staples ID Armor SH2836ID2836 Shredder Logo
87 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
