My AOC 17" computer monitor has turned to a yellow/mustard colour
  • Louie  Role
    Louie Role May 11, 2010
    Hi and welcome to FixYa,
    Initially, post back the exact model number. Offhand, some ideas to explore/consider:
    • if it were a conventional/CRT type, then possibilities are:
    1. video cable. Try replacing or twisting the end closer to the CPU. If that would correct, then a replacement is required. If none is readily available, a temporary workaround is to "wing" the position where it will work and secure the cable in that position with the use of "plastic ties";
    2. color drive transistor. There would be 3 color drive transistors at the small square PCB at the rear of the CRT. One of them could be faulty or cold solder issue. If you have experience with electronics and working in high voltage areas, then try re-soldering the pins of each transistors or replace as needed.
    • if it were an LCD type, then possibilities are:
      of "plastic ties";
    2. video interface. Internal electronics of the LCD monitor. The best approach would be to access and reference a Service Manual.
    Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
    Brigadier General:
  • 6,966 Answers
Posted on Jan 13, 2009
AOC CT720G (Black, Silver) 17" CRT Monitor driver
The monitor probably doesn't require any special driver. There are drivers for your motherboard video chip, or if you have a graphics card. If you need to make adjustments to the monitor, the manual is here... http://www.manualslib.com/manual/8152/Aoc-Ct700g.html
Jul 10, 2014 | AOC CT720G (Black, Silver) 17" CRT Monitor
Monitor colour goes pink
The monitor needs to be repaired or replaced, with the low prices today you could pick up a nice LCD monitor.
Sep 16, 2009 | AOC CT720G 17" CRT Monitor
Screen got yellowish color
Sounds like overstressed video cable, at least that wire for BLUE signal, 'cause when image is yellow - the BLUE color is missing.
Open the monitor and ring coaxial wire in blue insulation.
Sep 11, 2009 | AOC CT720G 17" CRT Monitor
Mymonitor is an AOC 1770 CRT, it have a light
make sure you dont have a bent pin on the cable where it plugs in. a bent pin will make different things happen to your colors. if the whole thing is tinted, yellow, or purple it usually is an issue with the plug. also, if you have an old screen plug it in and eliminate the video card as the culprit.
Jun 19, 2009 | AOC 1770 17 in.
Black screen saying no signal
turn off the computer and get a can of compressed air blow out all the dust and make sure everything is tight put back together and see iff it works. geek squad charges 99.99 to do this in store.
Jan 28, 2009 | AOC LM729 17" LCD Monitor
AOC 7 F 17" the OSD keeps on flashing
DIAGRAMA DE CABLE VGA DE MONITOR AOC MODELO F1770 DE FABRICACION O MONTAGE EN CHINA
Aug 03, 2008 | AOC 7F 17" CRT Monitor
AOC 17" Flat CRT Monitor
Could be problem of key switches!
Try replacing or check for leakage,high resistance across switches using ohmmeter.
Samir
Jul 26, 2008 | AOC CT720G 17" CRT Monitor
Problem in AOC 17
Your second step in troubleshooting this problem (after you check the connections) is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is probably shot.
May 09, 2008 | AOC CT720G 17" CRT Monitor
Aoc 7 ELR 17 in. CRT diagram
no necesitas tener TODOS los diagramas para reparar esos monitores,trata de usar la cabeza. try searching altavista...
Jul 04, 2007 | AOC 7 ELr 17 in.CRT Conventional Monitor
Computers & Internet Logo
483 people viewed this question
David Payne
David Payne
