Question about LG DLE2532W Electric Dryer
Can't find the reset button on my lg tromm dryer
cherylogle
SOURCE: lg tromm dryer electric cooling light staying on
I called LG after seeing this light as well and they say it's supposed to stay on and should "blink" at the end of the cycle. I've never remembered this light staying on in all the years of owning this machine but she (LG rep) said it was normal. Otherwise, if you've checked everything and it's not drying clothes, you may need to have your dryer serviced. :(
Posted on Dec 14, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Posted on Dec 23, 2009
SOURCE: my lg tromm DLG69885 gas dryer is not heating; oth...
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
Posted on Jul 04, 2010
heatman101
  • 43501 Answers
SOURCE: My LG Tromm electric dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 08, 2011
KevinWhite
  • 1902 Answers
SOURCE: My LG TROMM Dryer won't start the tumble when set.
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing, also check the belt if that is fine. Please get back to me if you have any other questions.
Kevin
Posted on Jul 06, 2011
The start button on my lg tromm washer does not work
The plastic piece that you push may be broken or the switch that it pushes may be broke. Sometimes you have to hold the start button for a few seconds before the actual start will take place.
Feb 19, 2015 | LG Tromm Front Load Washer And Dryer Set
How may belts on lg tromm dryer
The start button is a momentary start button. It energizes a relay type switch to keep power on. Try holding the start button in for awhile and do not let go. If the machine keeps running, then for sure, the relay type switch is defective and needs to be replaced with a new one.
May 24, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG Tromm dlg5988w dryer won't heat. I am trying to reset the heat sensor but can't find it. I have removed the front cover but not sure exactly what I'm looking for.
Make sure you have 240 Volts going to the dryer. The motor runs on 120 Volts, but the element needs 240 Volts. If that checks out, you would need to trace the wiring using the wiring schematic. That could be fun.
Aug 09, 2011 | Dryers
My LG Tromm DLE 5977W will tumble but won't heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Aug 03, 2011 | LG DLE5977 Electric Dryer
My LG Tromm electric dryer has no power. I turned it on and it ran for a few min. and just turned off. I have tried the breaker and also unplugged it and plugged it back in but no luck. Is there a...
heatman101
Apr 08, 2011 | LG DLE2514 Electric Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
May 20, 2010 | LG DLG5932W Gas Dryer
LG Tromm Dryer Thumps when running
The drum on my dryer is cracked, it thumps the entire time it runs, and it snags up all of my wife's clothes. We hate these appliances!
Aug 14, 2009 | LG DLE2514 Electric Dryer
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG DLE2532W Electric Dryer Logo
127 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
