Question about HP VECTRA VLI8 P3 Motherboard (KZM6120)
Bad RAM slot on HP motherboard
I have an HP Pavilion, 5 months out of warranty, and the #1 memory slot seems to have died. I've swapped out RAM chips and it's definitely the slot (or some other hardware issue), not the chip. In the BIOS it thinks the slot is empty.
The board is an ECS MCP61PM-HM, which HP calls a Nettle-GL8E.
I could live with 3 gigs instead of four since I'm running a 32-bit version of Vista, but it takes forever to boot, I assume because it's running a RAM check over and over before timing out after 20 minutes or so. Is there some hardware solution to this short of swapping out the motherboard? If not, I'll see if there's a RAM check I can turn off in the BIOS, but I hate to lose that function.
  • HP Master
  • 2,404 Answers
If the memory slot isn't recognizing any memory you stick in there then the motherboard has to be replaced.
Posted on Jun 16, 2009
Ram slots problems
Are you sure it's the slot and not the ram? Try switching the ram to isolate which memory chip is bad. You can start by using on ram and one slot, then booting and if it's ok, move it to the next slot and boot. Once you've tested that one memory chip, do the same thing with the other memory chip. More than likely you've got a bad memory chip.
Try switching the ram in each slot. If switching them around does not solve the problem and your slot is truely bad, you will have to replace the motherboard or increase the size of the ram in the slot that works.
May 23, 2012 | Dell Optiplex GX280 Intel Desktop PC -...
Emachines T5082 Adding 512Mb ram. Getting slot 0 installed slot 1 not installed.
Try swapping the memory in the two slots. It sounds like either one of the memory chips is bad or one of the memory slots is bad.
If you find that one of the slots is bad, then you might try just putting a 1GB Chip in the slot that works.
Apr 24, 2012 | E-Machines eMachines Desktop PC
Getting 2 short beeps and 1 long beep – black screen. gave a quick message once – “could not initialize video card”
Your computer has memory problems. First checkvideo. If video is working, you'll see an error message. If not, you have aparity error in your first 64K of memory. First check your SIMM's. Reseat themand reboot. If this doesn't do it, the memory chips may be bad. You can try switchingthe first and second banks memory chips. First banks are the memory banks thatyour CPU finds its first 64K of base memory in. You'll need to consult yourmanual to see which bank is first. If all your memory tests good, you probablyneed to buy another motherboard.
Clean the ram and the ram slot .then fit it again.
http://www.ehow.com/how_895_install-ram.html
Hope it will help you.
Dec 23, 2010 | HP Pavilion m8120n PC Desktop
Just bought 2 1GB PNY dual Chanel memory modules for my Computer Make: HP Pavilion 061 Computer Model: RJ181AA-ABA a1600n Currently has Memory: 4 slots: 512 MB, 512 MB, empty, empty QUESTION: which slots...
Start off by putting the first memory module in DIMM slot 0 this is the slot nearest the processor. DIMM slot 1 is the slost after DIMM 0.
Regards.
Jun 28, 2010 | HP Computers & Internet
I wanted to upgrade the memory on my pavilion zt1130 notebook from 256mb so I purchased to 512mb memory cards and replace the resident memroy under the keyboard. It runs faster but as soon as I put the...
According to Hp website your computer will handle two 512 Mb RAM chips. Make sure they are PC133. If computer will not boot with both inserted properly, one of them is bad. Put one in slot 1 and none in slot 2 and see if it boots. Then switch the chips put the extra chip in slot 1 and none in slot 2. See if it boots. This way you can troubleshoot a possible bad chip.
Aug 15, 2009 | Office Equipment & Supplies
Powering On Issues
With the power not staying on, its a motherboard problem. Try another ac adapter just to be sure just to rule out a faulty ac adaptor.
Mar 31, 2009 | Gateway M-6750 Notebook
DDR2's only showing half installed RAM
IF THE SYSTEM SAYS YOU HAVE 1GB RAM THAN YOU HAVE 1 GIG OF RAM, EVEN THOU SOMEONE TOLD YOU YOU HAD 2-512MG=1GB.
HERE IS HOW I SEE WHAT YOU ARE SAYING YOU HAVE 2-DDR-2 1 GIG STICKS THAT MEAN IF 1 IS INSTALLED THAN YOU HAVE 1 GB AND IF YOU COULD GET 2 STICKS WORKING TOGETHER THAN YOU WOULD HAVE 2GB RAM.
1 CHIP SET = 1GB RAM
2 CHIP SET = 2GB RAM
YOU MOTHERBOARD MAY NOT ALLOW THAT MUCH RAM, OR WHAT I MEAN THE BIOS MAKE UP THE AMOUNT OF RAM.
TO RULE OUT ANY BAD CHIP SETS OR GOOD RAM OR BAD RAM.
TAKE THE PEACE OF RAM THAT IS WORKING OUT AND REPLACE IT WITH THE OTHER PEACE AND SEE IF IT WILL RUN.
IF IT WORKS THAN LEAVE THAT ONE IN PLACE AND INSTALL THE SECOND PEACE IN THE SECOND SLOT.
IF BOTH CHIP SET ARE GOOD THAN BOTH SHOULD WORK OKAY TOGETHER.
IF THERE IS A PROBLEM, IT MAYBE SOME DUST IN THE MEMORY LOTS
OR THE SLOT MAYBE DAMAGED.
OR
THE CHIP DESIGN LAYOUT MAYBE THE OPPOSITE SIDE, THIS MAY MEANS THE CHIPS MAY FACE EACH OTHER, OR FACE OUTWARD FROM EACH OTHER.
ROD
Mar 14, 2009 | EliteGroup P4M800-M7 Motherboard
Where is my RAM board on my 2002 hp pavilion desktop computer? I can't figure out which part it is!! There are 6 different parts that look like it!!
the RAM slots are near on the processor you can see it will snap when everytime you put the RAM or memory. you can also refer your motherboards manual for the information that you wanted. there is a direction and specification of RAM in the manual.
thank you for using fixya
CHARCOIS
Mar 04, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Screen goes black and SD-ms (memory card slot) light comes on..
Change the memory chip to another slot or swap two memory chips if you have two memory chips on both slots, see what happened and come back to me again.
Nov 17, 2008 | HP Pavilion dv1000 Notebook
Computer ram
Best Solution
Hewlett Packard Pavilion 503w Memory Maximum Memory 2GB Memory Slots to 2 Slots. non-removable base memory 0MB Your HP Memory Pavilion 503w only supports modules made with a specific type of chip build. If you come across a website and find what seems to be the exact same memory for a lower price, it is likely that the cheaper memory will not work in your system.
use :1GB DDR2
Thanks and Regard
Dilip Bagdi - contact me at - johny_inmexico@yahoo.com
May 11, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Computers & Internet Logo
727 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
