Question about Frigidaire PLFU1778ES (16.7 cu. ft.) Refrigerator Commercial
Frigidaire model PLFU1778ES2 ice maker problems
My freezers ice maker stopped working after I put new water line filter on. What could my problem be.
  • 1314 Answers
SOURCE: Frigidaire - FSC23F7DS - water dispenser not working but ice maker is
take out the crisper drawers and see if the water tank is frozen is the light on the dispencer lighting up when you depress the paddle and look up in the dispencer to see if the acuating paddis broken we will go from there
Posted on Feb 18, 2008
vanni7
  • 163 Answers
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Posted on Jan 03, 2009
SOURCE: Not making ice
the icemaker is not making ice,In the bottom of refridegerator you can see some coils and they are iced over bad.
Posted on Jun 04, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Frigidaire FRS3R3JB stopped making ice and dispensing water.
I have been studying your model most of the morning. The only thing I could come up with that would cause this is an electronic dispenser control. It may be defective.In the control the power is converted to DC and the water control valve work off of DC voltage. I am putting you with the best his name is Brian. His website and blog are different. Website==> http://www.technicianbrian.com/
And here is where most of his help is directed ===>
LINK TO --> TechnicianBrian
one of my sites===>http://appliancepartsandtechnicalservices.blogspot.com/
If you have any problems let me know, Sea Breeze
Posted on Jun 20, 2009
  • 117 Answers
SOURCE: frigidaire water stopped working...ice maker.dispenser fine
You probably have an obstruction in filter compartment. you should remove filter and inspect o rings etc. or anything that could have clogged it up. The only other thing that could be the cause is a bad water valve. Side by sides have a double water valve. one for water ,one for ice maker. You can check this by having someone flip ice maker arm down so it calls for water and feel water valve as it runs and possibly hear it too. Hope this helps.
Posted on Jul 24, 2009
I put a new filter in my fridaire, but water dispenser not working, and ice maker not working
repairs should be performed by a qualified repair person. when replacing a filter make sure the filter properly installed. once secured get 3,1 gallon containers to purge the water line and reservoir. BEWARE! water may continue to run while flushing the water line. this is why you'll need 3 containers. once you are able to finish flushing the line and the water is no longer gray the flushing for the water dispenser is complete. dispose the ice in the container in the freezer. let the ice maker cycle a few hours then dispose the filtered ice. once copleted you're done.
Jun 04, 2017 | Refrigerators
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Water line stopping right before going into ice
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 13, 2010 | Roper RT21SKXLQ Top Freezer Refrigerator
Bosch upright freezer ice maker and water dispenser just stopped working
hello many times when the water and ice stop working you are not getting water to your freezer. so a few things to check if you have a water filter behind the freezer check for a blocked filter next. where the water line hooks up to the freezer there is usually a screen . turn the water off and remove the water line and check the screen if that s all ok it maybe the water solenoid hope this helps if not get back with me pls jason
Jun 09, 2010 | Bosch Freezer B24ID80SRS Stainless Steel
Ice Maker is dead on Kenmore Elite TRIO bottom freezer with French doors. This model has separate water dispenser inside fridge on left and ice maker in bottom freezer. We've tried replacing the filter,...
you can check the fill tube in the freezer make sure it is not blocked with frozen water. if you can disconnec the water supply line from the fill tube try and reset the ice maker to advance it to a new cycle and if water come out of the supply line the you knwo there is a blockage if no water comes out the the ice maker may be bad or the fill valve is bad. last thing you may need to call a service tech out to find the problem.good luck i hope that this has helped some what.i would like to knwo how thing go for you
Jan 22, 2010 | Freezers
Ice maker stopped working
The water line may be clogged with debris. there is sometimes a filter in the water line to the fridge, or also a screen filter may be located at the point where the water line connects to the fridge. If they are clogged, your ice maker will not make ice and may even burn out.
Check that the water in the line is flowing freely. Also it might be a good idea to defrost the freezer in case you have a ice buildup in the freezer compartment. To do that, empty the freezer and blow air into the freezer for 30 minutes while the power if off. Note, keep the other side closed to protect the milk and other perishables.
Nov 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker not working
The activity with the water supply could have loosened some sediment in the line stopping up the little wire screen filter going into the water inlet valve. I would disconnect it and inspect the screen and flush the water line out before re connecting. Assuming you have water at the water dispenser Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 30, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
FRS262GEB Side By side Not Making Ice
Typically when this problem occurs there is a clog of some sort between the filter and the ice maker. Disconnect the filter, stop your icemaker and take the fill line off. Blow compressed air from the filter side, until air blows freely. Reconnect all parts and turn unit on.
Aug 22, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice in ice maker compartment smells
If you have a silver metal braided line to water source that is your problem. Replace mine with a braided vinyl line and it cured it. ps flush new line for about two minutes.
Jan 01, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Frigidaire PLFU1778ES (16.7 cu. ft.) Refrigerator Commercial Logo
217 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
