How to wire trane electric furnace 2tec3f48a1000aa
4 Suggested Answers
james3751
  • 614 Answers
SOURCE: have an older Trane furnace. no 'board' just
If you do not have a fan board you have a fan limit switch. That brings the fan on about 120 and off at 90. It is located in the middle of your heat exchanger. Check across with voltmeter when you turn it on. If you have voltage after it runs for a while its bad. Or just jumper across it and see if afan comes on. They just go bad. Pick one up at HVAC supply house or you can order on line. If you have an electronic thermostat. On the back it has a switch that says gas or el switch to electric and the fan will come on with furnace. Rus but you still need to change fan limit this will just get you thru till you get it.
Posted on Nov 28, 2009
KLR Monkey
  • 22 Answers
SOURCE: what is the efficiency rating on the Trane model
Chances are you need to replace both the condenser and furnace, then you you should get a varaible speed blower with the new furnace, get at least a 90% gas system with a 16 SEER condenser, save on energy cost as soon as it's installed. Go Get IT
Posted on Feb 01, 2010
  • 69 Answers
SOURCE: wiring schatic to wire a 10 kw heat strip inside of a trane gas furnace
If you are using strip heat as seperate mode you must install a fan isolation relay which would be energized by emergency ht mode of stat.
Posted on Nov 25, 2012
Wiring schatic to wire a 10 kw heat strip inside of a trane gas furnace
Nov 25, 2012 | Carrier 38CKC042 Air Conditioner
Have an older Trane furnace. no 'board' just
Nov 28, 2009 | Ruud Central System Air Conditioner
Electric furnace. Just replaced the controller board but no heat. The blower does come on when the thermostat gives the heat command and I was wondering if that means the relays to the furnace coils is...
On a Trane furnace the fan realy must energize before the electric strips will come on. On the thermastat. See if there is setting for electric heat. This will bring the fan on and the strips should come on. First just turn on your heat and and turn fan to on postion if it works you need to set tstat to electric heat mode. Most of the time there is sswitch in the back of the stat that says gas elec. Turn to electric. Rus
Oct 29, 2009 | Heating & Cooling
Trane XE90 both ac unit and the furnace kick on at the same time
How about the Heating/cooling thermostat. Sounds like you better check it.
Jun 25, 2009 | Omega Trane Furnace Draft Inducer Blower...
Thermostat wiring
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Thermostat wire color codes explained.
Please note. Not all installers use the proper color codes when they install or replace equipment. It may be necessary go go to the furnace or outdoor unit to verify what wires are for what purpose. Also be sure there are no splices in the wire that could change the wire colors between components.
  • R (red) or Rh (Red heat) 24 volts from equipment.
  • Rc (Red cooling) 24 volts from transformer in cooling equipment.
Note: If only furnace has a transformer and cooling equipment does not jumper Rc and Rh.
  • W (White) sends 24 volts to furnace control to start the heating cycle.
  • W2 (no standardized wire color, usually whatever wire color is available) controls second stage heat.
Note: W2 is most often used for heat pumps to control what is called emegency heat or Auxillary heat, and most often will use the white wire.
  • Y (yellow) often (blue) is used, controls cooling unit (outdoor condensing unit) also is used for heat pump heat.
  • Y2 (no standardized wire color, usually whatever wire color is available) controls second stage cooling.
  • G (Green) controls the fan "on" operation of the furnace/air handler. Also often is used to start the blower for many electric furnaces.
  • C (common) most often brown but can also be black or other color available to installer.
  • O (orange) Energizes heat pump reversing valve for cooling (Trane and most other brands).
  • B (Blue) Energizes heat pump reversing valve for heating (Rheem, Ruud and Weatherking).
Jun 02, 2009 | Carrier Heating & Cooling
Need wire diagram for GE electric furnace
Usually the older GE's are straight forward and any generic wire diagram will help you out. If its newer and a Trane made unit try A Trane dealer.
Mar 27, 2009 | GE Heating & Cooling
Trane weathertron thermosatat
OK. Here is a Trane Weathertron BAYSTAT240 thermostat wiring picture. This heat pump w/ electric (emergency) heaters is running right now. Notice the G terminal has green wire, the R terminal has red wire, the white wire is jumpered from W to X2, etc. The black wire loop you see in the center hole is unconnected.
This unit is adjusted by leveling the base - loosen the screw to the left of "R" and the one to the right of "F". Twist the base clockwise to RAISE the indicator. This makes the mercury in the switch turn ON at a different temperature. Remember to tighten those 2 screws again.
You will have to experiment several times to make the unit read exactly right. If the tech installed the base exactly level, the unit would read right (it says here).
Mar 20, 2009 | Heating & Cooling
Need a schematic diagram on a trane furnace model blu080k0942b0
Have you checked on the inside of both front panels?
Mar 05, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
