Question about Cameras
Canon 50mm f3.5 Macro Lens// nFD version 1980 Haze behind first element
You have been recommended...so are #25 or 26 in the list of experts, none of whom have so far adequately addressed the issue I listed 2 days ago. This lens does not have a front bezel as do most lenses, nor are there screws to hold in the lens shroud which is approx. 1.5in deep, funnel shaped and sits nearly on top of the front of the first element. I need to remove the lens shroud to get to the retainer which holds the lens in place, to clean haze (not condensation) from the rear of the 1st lens element. I've already done the job for the rear lenses, located behind the diaphragm.This lens was manufactured after the Canon Lens Repair manual was published (I have a copy). The shroud rotates in place but doesn't extract, nor is there a clear way to remove it. I need specific guidance in removing the shroud so I can access the lens. If you have no experience with this specific lens (not the earlier SSC version) please don't guess...lots have tried and failed.
  • 1 more comment
  • scl8 Jan 12, 2009
    Thanks Steve, I've cleaned a number of lenses' interior surfaces over the years and most of them are still working great and crystal clear. You obviously understand why I want to get to the rear of that lens element, to reduce the possibility of fungus as well as bring the resolution and contrast up to the standard for this lens . Time is on my side, as I am retired and this lens is one of five (4 in excellent condition) macro lenses in my possession. Since I paid for expert advice in removing the shroud, that's what I am seeking.
  • Toyota Ed May 11, 2010
    Sir, If you do not get the advice that you seek, you are entitled to a refund.
    SCL8...
    The expert who answered your question has impeccable credentials. He looked after periscope optics for the US Navy.
    His experience and input is beyond reproach.
    New Friend:
Wondering if you ever got an answer. I know the lens is clipped in place, but have not found a way either to open up the front of the nFD 50mm 3.5...
Posted on Sep 14, 2015
    Sergeant:
  • 306 Answers
Haze is condensation. I am schooled in optics and physics. Seriously, if you go to a local pawn shop they will verify what I say. Mold in the lens optics will follow. I would gladly send you a lens if you are destitute but do not throw bad money (time) after good. Steve Medley
Posted on Jan 12, 2009
How to lens disassemble canon 50mm macro 2.5
Just one page of a repair manual from Canon. Just to ask yourself if you understand how to adjust a lens. If you can't make up anything from this, it is not worth buying a repair manual for this lens, because bringing it to a certified Canon repair shop will be cheaper. And the result 1000 times better.
Opening a lens is no problem. Putting it together so you can use it as sharp as it should be, needs special tools and special skills.
Sep 07, 2014 | Canon Normal EF 50mm f/2.5 Compact Macro...
Sigma 50mm macro2.8 for canon error 01 with my 450d and 1000d camera
This really needs to looked at by a service tech to determine the cause of the errors,before further damage is done.
Jan 21, 2013 | Sigma Af 50mm F/2.8 Ex Dg Macro Lens For...
How do you remove the macro lens
The 50mm f1.8 lens is not a macro lens. If you attached a close up filter, it should just screw off. Try not to squeeze the ring too tight as that may make it harder to remove. Also "righty tighty - lefty loosey"
Nov 30, 2012 | Canon EF 50mm f/1.8 II Lens
Are extension tubes any good?
Extension tubes will not affect the zoom range. They simply allow the lens to focus closer by moving the glass farther away from the film or image sensor. I use them for my own close-up work.
The 18-135mm will let you focus down to 0.45m for a maximum magnification of about 1:4.8. True macro is at least 1:1 (lifesize) so this lens can't really be called a macro.
If you mean the 50mm f/2.5 lens, this will let you get to 1:1.
Oct 24, 2012 | Canon EOS 600D Rebel T3i Digital Camera
Canon ef 50mm 2.5 macro autofocus broken. Buy new or have it fixed ?? can u advice ?
I thought mine was broken but i cleaned off the copper tips on the bottom with a clean eraser very gently, and afterwards i put on the lens and it worked. I would give that a try if you have not already
May 10, 2010 | Canon Normal EF 50mm f/2.5 Compact Macro...
Canon EF 50mm 2.5 macro autofocus broken. buy new or have it fixed ?? can u advice ?
Given the cost of this lens new, it's worth asking a repairer for an estimate. Protech Photographic, Uckfield may be able to help
Mar 16, 2010 | Canon Normal EF 50mm f/2.5 Compact Macro...
Tamron lens and canon speedlite compatibility
Your question is posted under a Nikon version of this lens. I assume you are talking about using the Canon EOS mount version.
The short answer is: Yes
Jan 15, 2008 | Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP...
Hazy central area in images
please try to look at carefully at the center of your front and rear lens,see if there is a fungus or any dirt in the middle,or try to look reversely full open facing the light so that you may confirmed the cause of the problem.
Apr 01, 2007 | Sigma Macro 50mm f/2.8 EX DG for Nikon AF
Cameras Logo
451 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
