Question about LG 24 in. LDS 5811 Built-in Dishwasher
Pump motor cycles LDS5811
Replaced motor after getting a motor fialure code and also found a broken gray wire in the door. Now pump motor will cycle when in the rinse and wash cycle, It has run up to ten minutes at a time and sometime only for a few seconds. What controls the pump motor that would cause it to cycle, flow sensor, overload? There are also other discolored wires, but they don't show any cracking or stress.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
If your unit has a serial number that starts with 712 or lower then there may be an issue with the wiring in the door. This sounds like your case if you had a broken wire and discolored wires. The issue has to do with black, tarry residue getting on the wires and causing them to deteriorate from the inside out.
If this is your case, call LG customer service at 800-243-0000 and have them refer to service bulletin IDSW20070060. If your unit is out of warranty they may extend it to cover the repairs (the door liner and wire harness will need replaced).
Posted on Jan 18, 2009
LG dishwasher model LDF6920WW 1 1/2 years old approximately. Suddenly stops a minute or so into cycle (it drains remaining water and fills with new water then get LE error). When I open the door at the...
The manufacturer has assigned this error or fault code to indicate a problem with the water circulation pump motor. Turn the appliance off for 30 minutes to allow it to cool. Then, restart the cycle. If the error code returns check the wiring to the pump motor. Also, if the wash impeller is broken this error can appear. If the impeller and wire harness check out, and the code keeps returning, you will probably need to replace the pump and motor assembly.
Aug 06, 2017 | Dishwashers
Hotpoint Ultima WF860T
Alarm
code Description of fault User
code Effect
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
My dishwasher is showing LE on the display and will run but doesn't seem to be cleaning the dishes. Any solutions?
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
(Just copy and past the above link in your web browser)
Good Luck!!
Thanks
Mar 27, 2010 | LG 24" Built-In Dishwasher - Black
LE error message
Good Luck!!
Dec 11, 2009 | LG Dishwashers
Lds5811 pumps motor cycles
The pump is supposed to cycle 4-5 times at the beginning to prime the pump motor. This should last only for about a minute.
Jan 14, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Pump motor cycles
If you are still having problems, providing the serial number is actually important because of a retrofit to several items in the door panel. Which could actually be related to your symptom.
Please provide the serial number or report back what you did to resolve the problem. Thanks!
Jan 12, 2009 | LG LDF6810 Built-in Dishwasher
LG modèele LDF78105T error code LE
Good Luck!!
Aug 15, 2008 | LG Dishwashers
There is an error code that says LE
Thanks for using FixYa!!
Jul 27, 2008 | Dishwashers
Error LE on display of a LG dishwasher model LDF 6180WW Leaves water in the bottom of unit
Thanks
Jun 27, 2008 | Dishwashers
Error code E1 on LG dishwasher
I have this sometimes where E1 is reported and the pump remains on. The following voodoo has worked for me.
1) Make sure there is not a real drain problem.
2) Cancel any cycle or turn the power button off then on.
3) Run a rinse cycle (15 minutes).
4) If pump continues to run, turn off the power to the dishwasher, let stand for a minute, then repeat steps 2-3. If still not working, leave power off over night and leave the door open then try again.
In each iteration, it is important to curse your LG product and/or threaten it with replacement.
Sep 04, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
101 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
