Question about Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range
My kenmoe elite gas rang model 790.7540 door does not close all the way. Repairman replaced hinges but said they were flimsy and it did not fix the problem - what should i do
  • 1214 Answers
SOURCE: ovendoor not closing for tight seal...
You should feel the door pull closed when you as you lift it and get near the closed position.
There is some spring linkage associated with the hinge pins at the bottom sides of the oven.
I cannot find the oven you indicated, but I did find exploded views and parts list of the topic post oven on the SearsPartsDirect website.
Posted on Jan 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: Range door will not seal properly.
Place a hammer handle between the door and the frame at the hinges..
Push on the door, carefully.
This usually works to re-seat the door hinges.
Posted on Mar 08, 2009
57 varieties
  • 1653 Answers
SOURCE: I have kenmore elite gas range 790 series getting
The F93 shows that the Maximum oven door lock time has been exceeded.
Turn off the range and turn off the AC power and wait for up to 10 mins. The door should reopen. Turn on the AC power ans see if the error persists. If it does then check the following.
1. Check the wiring between EOC & Lock Motor Micro Switch.
2. Replace the Motor Door Latch assembly if necessary.
3. Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly.
6. Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
Posted on Nov 12, 2009
  • 72 Answers
SOURCE: Can I adjust the hinges on the oven door? Kenmore
not ajustable
Posted on Jan 20, 2010
  • 7 Answers
SOURCE: Kenmore Elite 790 series gas range, ran flex clean about 5 minutes after starting recieved a F93 error now door locked.
unplug it for about 15 minutes to reset it self and see what happens
Posted on Mar 17, 2012
Add tension to loose oven door amana gas model args7650ss
Hello. You will need to replace the door hinge assemblies. The part numbers are as follows:
Right hand hinge 31715202
Left hand hinge 31715201
I hope this helps you.
Aug 14, 2015 | Amana Kitchen Ranges
Tappan gas range oven door hinge is binding
What is the model number of the unit?
Nov 29, 2012 | Kitchen Ranges
Bosch oven model HGS3052UC doesnt close tightly, hasn't since new 3 yrs ago. any idea how to fix?
yesthis is a common problem with this brand. 2 things can be done. 1. replace the hinges left and right or add 3 washers on both sides of the hinge to bring the door hinges closer.Im a old bosch tech and I told them this was a issue.
Dec 27, 2009 | Bosch HGS3052U Gas Kitchen Range
Lofra five burner gas cooker, oven door not closing properly,
It sounds like you need to check the fixing screws of the oven,failing this replace the hinges.
I hope this helps.
Jul 07, 2009 | Lofra MXD96MFEPI Dual Fuel (Electric and...
Oven door hinge replacement installation
kitchenaid superba oven door will not stay closed.
Oct 22, 2008 | Kitchen Ranges
RSD30 F1 Error Code
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection. why would he replace the spark module?if the door is not closing>>> are the burners not igniting?
Bezel Panel
76480b/r BEZEL (Almond/Black/Arctic)
Spark Module
86526 SPARK MODULE, 4 POINT,
Both door hinges
82883 HINGE, DOOR
* 82508 HINGE, DOOR (Stainless Front)
or to fix your F1 error
92028 RELAY PCB, 105 C
Aug 01, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Frigidaire 40 inch range model #REG46NW-2
OPEN THE DOOR COMPLETELY. IF IT GOES BEYOND HORIZONTAL, THE HINGES ARE BENT FROM EXCESS DOWNWARD FORCE. THEY WILL HAVE TO BE REPLACED.
CHECK THE DOOR HINGE SPRINGS TO MAKE SURE ONE OF THEM ISN'T BROKEN. IF YOU FIND ONE BROKEN, REPLACE IT.
Mar 31, 2008 | Frigidaire PLCF489AC Dual Fuel (Electric...
Oven door just barely closes- light stays on
put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Nov 12, 2007 | Kenmore 96422 / 96424 / 96429 Electric...
Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range Logo
64 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
