Question about Apple iMac 24" Desktop
Keyboard and Mouse don't work anymore
I was using my iMac Al 20', everything was working fine, and after I did what I had to do, I shut it off, to go to bed, then I remember that I had to pay a bill, and turn it back on, but when it start up I noticed that my mouse wasn't working, I've tried my keyboard and noticed it didn't work also ( don't know about the remote, forgot to try it ).
I pick up my mouse and noticed that it was 'turned off' ( no light below it ), so I've unplugged and plugged it back again, the mouse turned on, but it still didn't move ( the cursor were at the apple on the top ).
I've tried to change the mouse from the keyboard usb to the computer usb, same result, tried to change the keyboard usb, unplugged an old iPod that I use as a backup drive ( through firewire connection ) unplug the cable that I use to sync my iPhone, nothing worked.
Can anyone help me here?
TIA
Marcelo Wolfgang
  • msimonmw Jan 13, 2009
    Update from latest test yesterday.
    The 3 USB ports behind the screen 'don't work', but the firewire port is OK.
    I've plugged an old iPod in the firewire and it synced OK, I've tried
    to plug my iPhone in the 3 usb ports with no success. I've also tried
    to plug another keyboard unsuccessfully.
    Also I've noticed that when I start the system the mouse laser is on,
    but as soon as the apple logo shows in the screen it turn off the
    light.
    Also the apple mouse is the only thing that I can plug to the usb ports ( after it has been turned off ) that come back on.
    Please help, what should I do?
  • slijmgaard Feb 08, 2009
    i've also plugged my camera in and now I have the same problems as msimonnw's
    Novelist:
  • 89 Answers
Hi, Sorry you are having problems,
Well Marcelo, the first thing to do in a situation like this is to restart your Mac or even better, shut down and restart. So, if you have done this, and still the keyboard and mouse don't respond, and, as you have mentioned, you have tried the other USB ports on the back of the Mac, it sounds like somehow, unexpectedly, your iMac motherboard got a shock of some kind and it killed the USB controller....
Last thing to try is to unplug the iMac completely of everything and let it sit for 10 minutes and then plug just the keyboard and mouse back in and try to see if that does the trick..
Otherwise, Apple will cover this if it is still under warranty.
Good Luck.
Posted on Apr 02, 2009
My mouse works fine but not the mouse wheel. It won't scroll up and down but when you click the mouse wheel it works fine.I've tried everything, from mouse wheel programs and everything. I change...
Hi, I believe you have to clean your mouse. that's no joke. You have to unscrew it and and clean out al the parts with a toothbrush and tooth-pic.. If that does'nt work. replace mouse with optic mouse.
Good luck.
Jun 10, 2011 | Logitech "Black" LX 300 Cordless Desktop...
G5 keeps powering up for a few mins then switches off?
Thank you for contacting Fixya Support, I am glad to assist.
There are a few steps you can try to troubleshoot this issue:
Try a PMU Reset:
* Turn of your iMac if it is already turned off
* Disconnect all connections to the iMac except the power cord
* Now disconnect the power cord for approximately 20 seconds
* Reconnect just the power cable the keyboard, mouse and power cord, and then power your iMac G5 up.
* Check to see if the iMac boots up normally without power interruption.
* If the iMac G5 shuts off again, try these steps, another recommendation would be to remove all connections including the power cord, and lay the iMac G5 on soft cloth face down and with a philips screwdriver, remove the plate on the bottom of the iMac G5 where your RAM memory is located.
Before removing the RAM however, touch your hand on the metal boot to discharge any static current you carry for approximately 5 seconds.
Now remove each RAM card and then reseat (re-install) each card.
Restore the RAM card cover with your Philips screwdriver, reconnect your power cable, keyboard an
d mouse and turn on your iMac G5.
See if this second procedure helps if the first procedure does not work.
Let me know if this helps.
Regards
-Mactechtrainer
Sep 11, 2010 | Apple iMac G5 Desktop
IMac bluetooth mouse won't move cursor
Did you seperately setup the mouse? Even if you have, go into the Bluetooth preferences under System Preferences. Select the mouse & delete it. Setup a "New Bluetooth Device" and select "Mouse." Be sure to press the Reset button for 2-3 seconds to get the mouse into "Discoverable" mode. Your Mac will then setup the mouse automatically.
If this does not work, the Bluetooth chip in the mouse may be defective.
Mar 22, 2009 | Apple iMac 17" Desktop
PC does not respond to mouse or keyboard
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 05, 2009 | Computers & Internet
Dell bluetooth keyboard/mouse bundle
i just got the bluetooth keyboard and mouse but i dont know how to get them to work. can any body help?
Jun 06, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Mouse does connect but keyboard does not, vice versa
reinstall the logitech cd which came with keyboard and mouse, with the mouse pluged in. once reinstalled restart and while restart plug the keyboard in..... this should resolve the issue.
May 29, 2008 | Logitech Cordless Desktop MX 5000 Laser
Hp a305w Pavilion No Mouse or Keyboard at first bootup
i would reset your keyboard and mouse settings to default then shut down pc.. unplug components and wait for 3o secs and then try again.. if the problem persists, you may just have some loose connections especially if your pc is older..make sure there is enough slack for your mouse and keyboard wire to move around.. i know sometimes we can ruin them if we have then stretched to far out.. hope this helps.. d
Feb 22, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Keyboard and mouse work only intermittently
yeah.. maybe you have a defective keyboard.. better look at your warranty now..
Sep 30, 2006 | Macally IKEY Keyboard
Apple iMac 24" Desktop Logo
1,097 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
