Tv not picking up hdmi connection from laptop
  • BLAH May 11, 2010
    Is the TV set to PC mode and have you set the laptop up for secondary displays?
  • mikelpoynter
    mikelpoynter May 11, 2010
    Does anything else work in the hdmi port?
  • 591 Answers
I suspect the TV is unable to use the Horizonal and Vertical scan frequencies put out by your computer.
Posted on Oct 14, 2009
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
Hdmi laptop to tv
I'm assuming you wish to connect the laptop to the TV.
first off connect the HDMI to the laptop and the TV and then change the source to the correct one for what HDMI port you chose so if the wire is in HDMI2 then switch to HDMI2.
next how to make it use the TV so go to the desktop right click and go screen resolution if it has picked it up it will be in the drop down menu then its just a case of resizing until it looks right
Dec 24, 2013 | Computers & Internet
How do I connect a laptop to this tv?
It will depend on the laptop's available external video ports. You can connect a VGA cable from some laptops to the VGA port on the TV. Then plug in a 3.5 mm audio cable from the headphone jack to the PC audio in port. (The audio connection is optional. You could continue using the laptop's speakers.)
Make the connections with the TV and the laptop off. You may need to enter the BIOS to enable the external video port. (It can be turned off to save power. The BIOS is accessed on boot by pressing a key (Esc, F1, Del) noted on the splash screen. For Win8 machines, you'll need to do a special restart.) Then turn on the TV before turning on the computer. The TV monitor should be automatically recognized for resolution and refresh rate. Next, if you have a Windows system, right click on the desktop (pick a spot with no icons or running programs). Click on Screen Resolution (or perhaps Graphics Properties, depending on the OS). Set the monitor to duplicate the screens or send data only to the TV screen.
I'm not sure if the HDMI ports will understand a computer signal. (Not all TVs can interpret the computer's HDMI signal; it is different than that of other set top boxes.) You can try the following connections.
If your laptop has a DVI output, use a DVI to HDMI cable (or adapter) to connect to the TV. Then connect the HDMI cable to HDMI 1 and use the PC audio connection as above.
For an HDMI output, use an HDMI cable. (You will still need the audio cable unless you can reset the audio signal to output on the HDMI port. Go to the Control Panel and then the Hardware and Sounds section. Under Sound, select Manage audio devices. Then in the Playback tab, make the HDMI audio the default.) For Display Port or Thunderbolt outputs on the laptop, you will need a DP to HDMI adapter.
If the HDMI port doesn't understand the computer signal, you'll need to use a converter to go from the computer's output to component video or to VGA. Then connect the converter's output to the appropriate port on the TV.
I hope this helps.
(To access the Control Panel in Windows 7 and earlier versions, click Start and then find the Control Panel in the right hand column. For Windows 8, press the Windows key + X (or access the Charms menu on the right-hand side (Win+C) and choose Settings). Then select the Control Panel.)
Oct 13, 2013 | Haier L42B1180 - 42 1080p LCD HDTV
Tv not picking up hdmi input
HDMI is goofy. Connect everything while it is off and then power everything up. That should take care of it after the first time you do it.
Apr 19, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
When I connect my laptop to BEKO 26LML87 (LCD) with HDMI I can't get picture or sound on my TV from the laptop. My laptop correctly recognize my TV and sends picture trough HDMI but TV can't show...
not sure on this one but i think you need to go into your tv setting and see what hdmi setting you need to be on to pick up the laptop,where as some tv just picks the laptops up with out going into the setting.
but link i said not sure if this is what you have to do.
Nov 02, 2017 | Beko Televison & Video
I'm trying to connect my XPS to my tv with an hdmi cord (hdmi to hdmi). My computer picks up the connection but my tv doesn't seem to read it.
Hello there. I might be able to help you here. Go to your desktop right click and go to resolution settings. Make sure you have your tv selected on your pc as the display you want to use. This may solve your problem.
Apr 01, 2011 | Dell XPS M1530 Notebook
Laptop connection
Buy a HDMI cable.Hook up one side of the HDMI cable to ur tv HDMI Hub.The other side of the HDMI cable to ur laptop USB Hub.That it u got a connnection,now go in ur tv input pick which HDMI inputs,u put it in,example 1 to 4 HDMI Hubs.Pick the one HDMI Hub that ur laptop it hook up in.That it now u got ur LCD tv used as a monitor.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Hdmi does not work
go into TV menu and turn the HDMI on. guessing it should be in settings? or Video input.
Mar 07, 2009 | Spectroniq PLTV3250 32 in. LCD TV
Computers & Internet Logo
289 people viewed this question
David Payne
David Payne
