There are two cells soldered together in a holder. The battery # labelled on the holder is 4822 138 10067. Please direct the source of the battery.
SOURCE: how to change battery in Norelco 5841XL razor
8/20/2009 I have successfully replaced batteries on Norelco 5841xl. Purchased 4AA NiMH rechargable batteries from CVS for $9.50. Only need 2. Removed 2 Philips/straight screws on back cover(1 screw hidden under sideburn trimmer extension button).
Specially, be sure to mark on the shaver which way the batteries are inserted, 'cause once removed there are no marks to tell which way to go. The 2 batteries are "SPOT WELDED" to the metal ribbon contact wires. I used a sharp jack-knife to carefully pry the top edge away from the battery, (Pressing down sharp edge, and prying the ribbon away from the battery) then with the knife reaching under the ribbon battery junction(knife sharp side up) and prying the ribbon away from the battery. I redid this process a few times, wearing away (fatiguing the metal) at the removal of the ribbon. the top of one sort-of broke off above the battery but no matter there was enough left below , that there was enough to solder a wire to if necessary. Anyway "success" 2 batteries removed, no threat to heat sensitive components below. Continuing, I used a sharp new nail-file to harshly scrape some scratches onto the top and bottom of the batteries, so the solder would have fresh rough (un-oxidized) metal to solder to. A 15 or 30 watt soldering iron might work but I used a 120 watt weller soldering gun to solder the ribbons to the batteries (as they were connected in series before). preheat the soldering tool to temp, Press soldering tool to the battery briefly and while there insert "rosin core solder" between junction between the battery and iron, after a small droplet forms, stop inserting and let the heat on the battery increase, seeing the solder wetting to the battery, only then remove heat quickly to prevent deeper heating of the battery. Having presoldered the 4 points on the batterys, insert batteries into holder, you can then solder batteries into place with iron pressing ribbon to battery, and a small touch of solder to the iron-ribbon-battery junction, to help "wetting" the surfaces (thereby helping the iron heat to transfer into the joint) and remove heat and let joint cool without movement, 'til frozen again. (Don't want "Cold-Soldering" joint to occur by movement while freezing) . One special note worth checking and evaluating: there are 2 capacitor cans at the bottom end of the battery holder, almost touching the bottom of the batteries..... BE VERY CAREFUL that the caps don't touch the horizontal wire connecting the 2 batteries together, or the batteries themselves. I have no knowledge of the concequences but don't wanna find out either. My shaver was 8 maybe 10 years old, and went from holding a charge for a week new, to not holding a useable charge for a complete shave. So I charged the newones once fully, it's been 2 weeks and I'm only down 20% to 80% charged, and it seems now on batteries to run just a little bit faster than new. (Like when the cord is in the wall). Avery awesome experience for me cause I thought the $90.00 shaver was a loss.
Just a thought in hindsight, Keep an eye for heat while charging, because I've not plugged it in and left it a long time unattended. The previous batteries were NiCad and these were NiMH and I'm not sure what the charging differences are, but I'm REAL HAPPY, and my keeping an eye for a while until I'm comfortable with it's safety, is a small price to pay for saving $90.00 for $10 batteries.
Only problem might be fire or explosion... Be careful in anything you do, ever... But there you go !!!!! Real Happy Camper...
SOURCE: I lost my Philips Coolskin 7775X shaver charger.
Hi, You can purchase a new charging cord from electricshaver.com for around $23.00 which is probably the best thing to do if you want to keep using the shaver.
Otherwise the specs for the shaver are as follows:
The part number for the replacement charging adpater cord is #3605160
Here's a link to the part you're looking for, should you decide to purchase a replacement instead of trying to make your own charger, which will be difficult unless you have the full array of electrical components and ability to fabricate it.
http://www.electricshaverstore.com/get_list_144.htm
You can also give them a call at 1-888-476-1785
Hope you find this Very Helpful and best regards!
SOURCE: How to open Philips shaver 7110X to replace batery
Remove 2 screws on the back to remove outer cover. Once removed, you will see 3 more screws that must be removed on the inner cover. Remove screws and cover to get to the battery.
When installing the battery, I suggest that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
You will find a battery for your shaver at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
SOURCE: The head holder of my Norelco Philips HQ6707 shaver is cracked
You will find a replaceent for model HQ6707 at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-6700-series-cool-skin-head-holder-p-310.html
SOURCE: my philips shaver hq7360/b head
You will find an instructional video at shaveroutlet.com. See link below
http://www.shaveroutlet.com/philips_norelco_heads_replacement
