Question about Sharp Televison & Video
I need to replace a 2700uf 16 v capacitor on my tv set
Modellc-42sb45u
2 Suggested Answers
onemadashell
  • 9 Answers
SOURCE: 2700uf 16v capacitors
replace them
Posted on Sep 28, 2012
Sharp Flat Screen lc- 42sb45u It seems that whatever it is that controls the power (off/on) in my tv is not working correctly. The tv will not turn on using the remote or power button on the tv....
sounds like it could be a power supply problem - this is a common symptom for a failing capacitor. If you are handy with a soldering iron, you could replace yourself. Look for capacitor which has a bulging top located on the power board.
Oct 21, 2013 | Televison & Video
Sharp lcd tv modellc 32d44u power light blink no power i what to fix it i a tv technician allso
How many times do this power light blinks at one time switch ON? Count it. These are fault indication, called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. If you're somewhat in electronics, you can make it right too. If you wish to get more details about these blinking codes, and fault indications, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option
Aug 01, 2013 | Sharp Televison & Video
Capacitor replacement
You can use upto 3300MFD, 25V, according to available space on PCB. Do not use a lower value than 2700MFD. That is all.
Apr 27, 2013 | Sharp Televison & Video
To long to come on
I would start with checking the capacitors. Replace any with bulged tops
Oct 26, 2012 | Sharp Lc-42sb45u Tv Parts 715t3150-2 Power...
Hard time turning on tv. I turn it on, green light flashes a few times then becomes solid green. No picture or sound. I turn it off and light becomes red. I do this at least 5 times before tv will come...
There are some capacitors on the main boardthat are low quality. You can buy a capacitor repair kit on Ebay that contains a set of capacitors to replace the offending ones - about 15-16 bucks. I soldered in the new capacitors and the TV has worked perfectly since.
Nov 11, 2011 | LG 42LC7D-UB Television
Watching tv last night, the tv turn off by itself with out touching remote control, after that i keep trying to turn it on and the on/off red tv light startted flashing for a few minutes until it when off...
It can Have one of 2 Troubles, The Inverter Board is Defective or the Power Supply has bad Capacitors. I found 3 Capacitors known to go bad in that set. Replace the 10 Volt Capacitors with 16 Volt Caps and they will last forever.
Oct 07, 2010 | Samsung LN40A450 LCD TV
LC-42SB45U will not find channels from setup Auto Ch Search. Also tried reset with no results
Make sure you getting a good signal and that you are properly connected to the tv. If all else fails, look into replacing the main board.
Dec 05, 2009 | Sharp Televison & Video
I replaced 4 caps 2700uF and it is slow as on 10 On MSI 6309
I doubt that the cap voltages are a problem. Have you defaulted the bios settings yet? Also check for stray solder on the board. Inspection is priceless. If the bios has a PC Health page, check the reported voltages etc.
Jul 13, 2009 | MSI Computers & Internet
Powerbolt 1000 uses up batteries in a week
Get in touch with Weiser Canada via the contact info on their web site (http://www.weiserlock.ca/wei-eng/contact.htm) for a replacement under warranty (the Powerbolt has a lifetime mechanical guarantee). i have two rental properties with Powerbolt locks on them and have found - over the past 3 years - that it's safest to just replace the batteries on a 4 month schedule to ensure the tenants don't get locked out! The batteries actually last for longer than ~ 6 months, but i prefer to be on the safe side ...
Cheers,
Jun 08, 2009 | Weiser Lock Powerbolt 1000 Lock
Televison & Video Logo
27 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
