Question about Xerox Phaser 8560DN Laser Printer
I have alot of 8550 ink left over from my old printer.
I have a lot of 8550 ink left over from my old printer, Can I use it in my 8560 printer? I would need to trim it just a little to fit into the slot.
Is the ink the same material?
    President:
  • 2,072 Answers
Same ink but, it may be hard to cut them correctly to hit the switch on the bottom of the ink loader. They will code out with 09,xxx,xxx codes if they don't move down the loader properly.
The shape is the difference in those sticks.
Posted on Jan 12, 2009
On the 8560, what does the error code 07,010.43:14070 mean??
In the Xerox support website that error indicates that the printer needs to be turned off and call for xerox assistance. Does not specify the problem.
Although, this website refers to this problem.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/25/xerox-phaser-8400-8500-8550-8560-07010-43-error-message/
If the printer has only one year old, the best solution will be to call for xerox assistance because it is under warranty.... I think...
Aug 08, 2012 | Xerox Phaser 8560MFP Laser Printer
During its warming up cycle, my Xerox Phaser 8560 stop before it can sent a text page and show ''printer error 09, 038, 46:1172'' on its display. Printer do not become operational at this...
Here's what the service manual has to say:
9,035.43 through 9,038 (8500/8550/8560 only): Ink count sensor flags are
stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41,
where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out
Sensor located at the forward end of each ink channel of the Ink Loader. The
sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This
can lead to false Ink Out messages as well as Ink Stick count faults. Using
8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick
count faults.
Jul 18, 2011 | Office Equipment & Supplies
09,035.43:46672 this is an error message i get on my xerox phaser 8560... can you tell me what it means?
If after following mariolands advice the problem continues, you will need to replace the ink loader, for the 8560 ,the part number is 133K27771. Here is a video that will show you how. The video also covers the 8400, 8500, and 8550. Though the part numbers are different the procedure is the same. ">
Jan 30, 2011 | Xerox Phaser 8560DN Laser Printer
Does phaser 8560 and 8500 take same ink
The 8500 and the 8550 do use the same solid ink cartridges. Not sure about the 8560 since couldn't find information about it.
Jun 24, 2010 | Xerox Phaser 8500/DN Printer
Xerox system error 09,035,43:46300.
This is from the service manual
Harry
count faults.
Troubleshooting Procedure for Ink Loader
Step Questions and Actions Yes No
Is the ink Genuine Xerox? Are they the
correct sticks for the model?
Go to Step 2. 1. Advise customer.
2. Replace the Ink
with Xerox Ink.
3. Run Clear ISC
Fault
test to clear
the error. The
Clear ISC Fault is
located in the
Internal
Diagnostics
Function menu.
2 Manually verify that the ink stick is able
to advance in the ink loader chute.
Check for broken or wrong type ink
sticks.
Go to Step 3. 1. Remove any
blockage and/or
replace the ink
stick.
2. Replace the Ink
Loader.
3. Run Clear ISC
Fault
test to clear
the error
Feb 25, 2010 | Xerox Phaser 8560MFP Laser Printer
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Feb 18, 2010 | Xerox Phaser 8500/DN Printer
Getting this error code on 8550 Phaser: 37,006,42:26076 Have been having problems with the fan
Hi outonalimbwi:
Here is your problem.
37,006.42: PEST - Drum disconnect. The drum heater is not drawing the expected power from the supply.
1 1.
Run the appropriate diagnostic test:
37,002.47 = Left Jetstack Heater
37,003.48
= Right Jetstack Heater
37,004.40
, 37,005.41 = Reservoir Heaters
37,006.42
= Drum Heater
37,008.44
= Preheat Heater
37,009.45
= (8500/8550) All ink melters
= (8400) Ink Melt 1
37,010.46
= (8500/8550) Ink Melt 1
= (8400) Ink Melt 2
37,011.47
= (8500/8550)Ink Melt 2
= (8400) Ink Melt 3
37,012.48
= (8500/8550)Ink Melt 3
= (8400) Ink Melt 4
37,013.48
= (8500/8550)Ink Melt 4
2.
Did the test pass?
Go to Step 3. Go to Step 2.
2 1. Check the wiring running from the component to the printhead.
2. Is the wiring damaged or not working properly?
Replace the wiring harness.
Replace in the following order:
■ Drum assembly
■ Preheater
■ Printhead
■ Ink loader
Aug 11, 2009 | Xerox Phaser 8500N Printer
Xerox 8550 Scanner Locked
8550or 8560???
The 8550 has no scanner.
Apr 18, 2008 | Xerox Phaser 8550DX Laser Printer
Xerox Phaser  8560DN Laser Printer Logo
90 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
