Question about Freezers
GE FCM7DUAWW CHEST FREEZER FAILED
CONSTANTLY RUNNING BUT NO COOLING POWER
bobotfel
  • 236 Answers
SOURCE: kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
Posted on Dec 28, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
  • 31 Answers
SOURCE: freezer compressor running, but no cooling
If the compressor is running and there's no cooling, chances are you have a sealed system leak somewhere. Meaning the machine has lost it's refrigerant charge. Pretty much need a set of gages at this point and start checking for potential leaks.
Posted on Mar 14, 2009
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Posted on May 01, 2009
buddymcl777
  • 67 Answers
SOURCE: Frigidaire Deluxe Chest Freezer is constantly
Two things to check without knowing the model number.
It is possible the drain plug was left out or not inserted correctly after defrosting and it is leaking..
Also there is sometimes an evaporator pan with a heater element on the bottom. If the heater element failed the evaporator pan would overflow.
Posted on May 04, 2009
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Hot point chest freezer , inertial fan is running constantly and only the top half of freezer is frozen
I hope the cooling fluid is not leaking out of the system. When the inside is becoming warmer every day, you can be sure it is. Then check what is bas, replacing the cooling aggregate (it is through the whole freezer) or buying a new one. For household freezers it is better and cheaper to buy a new one, because new freezers use less power. When it is now running 24 hours a day, quick replace it.
Apr 06, 2015 | Freezers
Magic Chef HMCF7WI is the green light suppose to go off ?
I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
May 17, 2014 | Magic Chef 7 cu. ft. / 198 liter Chest...
GE Freezer stopped working
Obviously, the compressor is not running. Confirm the presence of power to the compressor itself. If it is getting power and unit does not run, you have an open motor winding OR if you have a start capacitor the latter could be defective. Let's hope that you have the capacitor because they go bad and are a lot cheaper to replace than the compressor!
Jan 19, 2014 | GE 7 cu. ft. Chest Freezer FCM7DR
Water leaking from bottom of chest freezer
there having a wires which got damaged otherwise your cooling having problem.
Mar 19, 2013 | GE 14.8 cu. ft. General Electric Chest...
We have a 20 cu ft GE chest freezer that will only cool to 20 degrees. What can I check to determine how to fix it?
Please check : - Your door ( gasket /seals, small air leaks) - Refrigerant level - Temperature sensor for failed
Regards,
Dec 04, 2010 | GE 19.7 cu. ft. / 558 liter Chest Freezer...
Just bought a used GE chest freezer model FH5DSAWH from friends. Brought it home plugged it in and it doesn't get cold. Can hear it running and the compressor gets hot. Any ideas? Was told it worked great....
your ptc overload relay on the compressor is bad,unplug it off the compressor and get a replacement at an appliance parts store,plug in the replacement and this will solve your problem
Apr 27, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Small chest freezer, running but not freezing, cold inside, everything defrosted
the freezer has a defrost timer and relay. if either is bad, it may get stuck in defrost mode(depending on what position the switch failed in). The fan will run constantly if this is the case. You may choose to follow the wiring diagram on the back of the service panel or hire a technician. If you do it yourself, unplug the unit for your safety
Nov 19, 2009 | Freezers
Want to replace thermostat of ge chest freezer fcm7duaww
first of all, switch off your freezer and let all the ice to melt. now snap the capilary with a great force....... don't worry nothing will be damaged beacuse it is the only way to pull the capilary out.............have a nice day :-)
May 14, 2009 | GE Freezers
May 02, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Freezers Logo
23 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
