Indesit washing machine wixl1635 lights wont stop flashing..help
Macjine has constant flashing lights.turned off at wall an when switch back on wont stop flashing
SOURCE: The door lock flashes constantly - Indesit WIA101
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
Posted on Aug 23, 2008
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
  • 417 Answers
SOURCE: washing machine is not draining and lights keep
It is likely that the pump/filter has blocked thus preventing the water pumping out.
You would need to check and if so unblock it. The location of the pump/filter varies with the brand but sometimes it is behind a flap at the lower front of the machine whilst on others you have to get the back off to locate it.
Posted on Jan 23, 2010
Testimonial: "that worked a treat thanks"
blueextc3221
  • 15935 Answers
SOURCE: Indesit WIDL 1265 All LED's are flashing
Unplug for 40 minutes to attempt a reset of the ECU - otherwise you must replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
  • 6277 Answers
SOURCE: washing machine stopped working and 3 lights
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 04, 2011
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
I have a indesit iwb71250 that the red door lock light is on constantly but we can open the door and shut although the machine will run it wont fill with water... any ideas
May be the switch is loose try fixing it with ascrew driver or the rubber hose is not fixed properly and the machine pump is taking air or the pump failure
Oct 19, 2014 | Indesit IWB71250 White 60 cm Washer Front...
Lights keep flashing
I would check the water pump for a blockage, there could be something in the pump preventing it from doing its job as the machine cant go to the next cycle until the water has been expelled before the machine can continue eric
Jan 16, 2018 | Indesit Washing Machines
Washing machine wont stop it has been going from last night
turn off at wall and unplug .after a few minute's plug back in and try and reset machine by putting dial on one of the dots switch on the red light should flash 3 times and switch off .I this works try and put machine on again a spin only will do if the same problem returns you probable need a new pc board . cost about £55to 90pounds before fitting .
Feb 11, 2010 | Indesit W 123 Front Load Washer
INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Nov 01, 2007 | Washing Machines
Indesit W123s - Hates Us
first thing to do is to make sure the washing machine is not siphoning. sometimes if a washing machine is bringing in water its all so draining it ,known in the trade as siphoning. the drain hose must be higher than the tub?? Unplug your washing machine from the wall socket for a minute or two and plug it back in to reset its micro. to me it sounds like a main board fault. I think you might find that it still maybe under warranty. ring a Indesit service agent and get some advice.
Aug 17, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
