Question about Health & Beauty
Hanson hxm20 bathroom scales err0
Err0 after changing battery
SOURCE: electronic bathroom scale lithium battery spent
I had a problem changing the battery too. I just couldn't get it out and was afraid of prying too hard because I might break it. So I called customer service to ask them (a bit extreme) but they basically just told me to take a small screwdriver (I used a hair pin) and pop it out. I tried again by pushing down on the opposite side instead of lifting and it popped right out. The battery is just a small electronic one like in a car's keyless entry controller.
Posted on Dec 10, 2008
SOURCE: We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
Posted on Jun 29, 2009
zlim44
  • 10 Answers
SOURCE: Hanson weigh scales I have no manual HXM150
just go to the website and down load the manual pdf form. it should be there!
Have fun!
Posted on Aug 27, 2009
Testimonial: "My first time to ask for help and it was totally correct. Thanks."
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
  • 5 Answers
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Posted on Mar 26, 2010
Hi I have a Hanson hx5000 glass bathroom scale Iv changed battery but all it says on the display screen is err any advice please
Try stepping on it lightly and quickly to see if it indicates a zero reading. If that happens, then weigh yourself before the zero goes away.
Jan 10, 2018 | The Health & Beauty
I have Hanson HX5000 bathroom scales that are showing error message OL. I have replaced the battery and ales no difference - anyone gave any ideas how to fix? Photo for reference
First, make sure the battery is not in backwards. If that's no help, let it set overnight without the battery in it before putting it back in. Also, make sure the unit is setting on a level, solid floor - not carpet (this looks like it's tile, but the grout lines are awfully bumpy-looking. . . If none of these things work, I'd say you got a bad unit. Were there no instructions included?
May 14, 2016 | Health & Beauty
My hanson hx5000 has started showing this error message. Battery has been changed with a new one, but still not working - any help greatfully received
This appears to be a set of bathroom scales - not at all suitable for weighing out chemicals to make your own developer. Have you tried the support section of the manufacturer's website ?
May 14, 2016 | Cameras
Hanson bathroom scale, model H113. Why is display not working, even after installation of new batteries.
1. The display may have failed
2. The replacement batteries may be defective
3. The batteries may have been installed incorrectly
Jul 20, 2015 | Health & Beauty
I have a set of hanson kitchen scales and i cannot change it from fl oz to grams etc
To switch your Hanson kitchen scales from ounces to grams, press the on/off button until you see the display change to the measuring scale that you require. This change option is ONLY available as you are switching on the scales, so if it already on - switch it off first and start again from scratch. Once you have set it to grams, it will remember your choice for next time, so you don't need to worry that you have to do this every time you switch on.
I hope this helps. Good luck.
Feb 08, 2010 | Health & Beauty
Aug 25, 2009 | Health & Beauty
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
Health & Beauty Logo
41 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
