Question about HP Laserjet CM2320nf All-In-One Color Printer
Hp printer cm2320 stripes down the page
  • 45 Answers
SOURCE: black stripe down center of document
as you have cleaned the scanner glass..try these steps..
1)connect the printer to the wall outlet..
2)then try to make a copy..if you get lines..then go to next step..
3)unplug the power chord..press and hold OK and CANCEL button together..while pressing the buttons plug in the power chord..
4)after you plug in the power chord do not release the button till the screen goes blank..once its blank release the buttons and then turn on the printer..
5)try to make a copy..its still the same..it is a hardware issue..machine should be replaced
6)Call HP who would give u a rebate on old printer & replace it with brand new printer.
Posted on Mar 13, 2009
  • 3741 Answers
SOURCE: white stripe down left side of page ?
remove the toner cartridge and shake it upside down for couple of minutes vigoursly.and the check the printou.if it prints ok,but if same problem then toner needs refilling as the toner cartridge is empty.or there is powder but due to moisture its got stuck internally.
Posted on May 05, 2009
  • 990 Answers
SOURCE: HP LaserJet 4000 prints horizontal drops down the
Hello sir; It's about time to replace drum cartridge.
Posted on Oct 02, 2009
Testimonial: "Thanks for the advise."
thgrtalex
  • 38 Answers
SOURCE: white stripe down the middle of page when printing
Check to see if there is a peice of paper stuck in it. Then maybe get a can of air and try to clean it out. It could be dust built up on the print head. Paper gets dust in it when it is cut and will build up in printers.
Posted on Dec 01, 2009
BaronVonNuke
  • 1915 Answers
SOURCE: The CM2320nf printer has random 1/2" wide black
Really sounds like a defective cartridge or bad contact. Have you changed any of the toners recently? If so, try another cartridge of the color that you just changed.
Posted on Mar 17, 2011
Hp color laserjet cp1525
Here is a link to the HP Support Center Page that describes the Control panel messages for your printer....58.04 is not documented .
Troubleshoot problem for HP Color LaserJet CM2320 Multifunction Printer...
Mar 26, 2014 | HP LaserJet Office Equipment & Supplies
Slow printing hp laserjet 2320 mfp
I have just come up against this issue my self, 4 x CM2320's installed on 150 PC's. After a lot of head scratching I dug out wire shark and did some network analysing as I thought it was a network issue. Turns out it sort of was, the HP software installs a custom network print port, this print port scans the network to see if the printer has changed its IP address BEFORE it tries to spool...!! The solution is to create a new network port and put the printer on that. Originally it took well over 90 seconds to print a test page, once the port was changed it dropped to 2...!!!! All PC's at this client were win XP so here's how to do it on an XP machine... Please note the printer should be on a static IP address!!!:
Start > Printers And Faxes > Right Click on the CM2320 PCL 6 printer > Properties > Ports >
If you scroll down to find the printer in the ports list you should find it has installed on a port called 'HP Colour LaserJet' or something similar.
Add Port > Select 'HP Standard TCP/IP Port' > New Port > Next > Type in the printers IP address ie 192.168.0.202 (Don't tick always print to this device) > Next > Standard - Dropdown - Hewlett Packard Jetdirect > Next > Finish.
The new port will now be in the ports list, click the tick box next to it > Apply > OK. Now try and print a test page, it should only take a second or two...!!!
Jun 12, 2012 | HP Laserjet CM2320nf All-In-One Color...
HP CM2320 MFP blank pages come out with printout
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Lang Dibba, Gambia
Jan 30, 2012 | HP Laserjet CM2320nf All-In-One Color...
Mar 16, 2011 | HP Laserjet CM2320nf All-In-One Color...
HP Color LaserJet CM2320 MFP shutting off and on -does not work
unplug the telephone and network cable and restart the printer.
Dec 11, 2009 | HP Laserjet CM2320nf All-In-One Color...
Oct 02, 2009 | HP LaserJet 4000 Printer
HP Laserjet P1006 prints with blank white stripe down left side
Clean the Corona Wire carefully to remove any residue. As the charge on the wire is effectivley masked it cannot deposit any toner to the page and will result in a consistent white vertical stripe.
Aug 29, 2009 | HP LaserJet 1022 Printer
Laserjet cm2320 fxi mfp has scanner error 5
when Printing from my HP 2320 there is a slight blue streak on the Right side of the page
Jun 03, 2009 | HP LaserJet 2840 All-In-One Printer
HP Laserjet CM2320nf All-In-One Color Printer Logo
Seeker5211
Seeker5211
