Question about Hoover Vacuums
How to replace hoover cord reel 41911014
Model s3630 Hoover Windtunnel Canister Cleaner
  • 126 Answers
SOURCE: hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Posted on Jan 20, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover Model S3281, disassembly instructions
Alot of these Hoovers has a panel on the top, near the back that has some screws to take out, then that panel comes off. The motor and reel cord are under that cover.
Posted on Jan 22, 2008
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
SOURCE: replacing a fraayed and twisted power cord on a Hoover windtunnel upright
ok so I took this vaccum apart completely except for the electrical and motor systems. It seems to me that without dismantling both of these systems on the vaccum you can't replace the power cord. And I wouldn't recommend taking them apart unless you know what you are doing since replacing the power cord seems to require cutting the old power cord and soldering the new one onto the old terminals. All in all its probably easier to get a new vaccum altogether.
Posted on Aug 08, 2008
  • 8 Answers
SOURCE: Hoover Windtunnel shuts off
I found the following solution on this website. I have searched for hours and finally found this solution, it works! I HAD the same problem after cleaning the filter mentioned below, it is now working like it was new.
***by maverick_bea***
yes this machine has a thermal protector in it to shut off the machine if it gets to hot, this is normal. if there is no clogs in the hoses or in the machine then you will need to wash the filter at the top of the machine. you will have to remove the dirt cup and at the top you should see a half moon orange, well inside of this piece is the washable filter, clean and let it dry completly before putting back into machine. if this gets dirty and has not been cleaned, you can lose alot of suction. in some cases if this filter is not cleaned it can cause the machine to overheat so bad that it can damage the motor.
Posted on Oct 25, 2009
How do I replace a severed power cord on hoover windtunnel upright bagless model U5280900?
Hi there! We recommend taking your vacuum to a Hoover authorized service center to have your cord repaired. Follow the link to locate the nearest service center to you. Thanks! Service Center Locator
Oct 13, 2014 | Hoover Windtunnel Supreme U5280-900...
How do I install Hoover part 41911014
Hi Jeffrey, we actually recommend having an authorized service center replace the cord reel assembly on your vacuum. Please follow the link below to locate the nearest service center location to you. Thanks!
Aug 19, 2014 | Hoover S3630 WindTunnel Bagged Canister...
I have a Hoover S3630 canister vacuum and the brush works on the bare floors but will not work on carpets.
does your vacuum have an adjuster knob on the front? if so try raising the unit so that the brushes don't bind up on the rug and burn out the belt
Dec 28, 2010 | Hoover S3630 WindTunnel Bagged Canister...
Hoover UH70120 WindTunnel TSeries problems with the cord. im a tech savy guy and have been trying to fix a cord after it was pulled to far out and now wont auto retract, but just cant find a way to pull...
You will probably have to replace the cord winding mechanism. I have never had any luck trying to repair one. Cord retracters are great when they work but it seems like they always go bad before too long. On many units you can't even replace the cord if you get a bad spot in it, you have to buy a new cord reel which can get expensive.
Jul 21, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
My vacuum cleaner has power through the switch and through to motor but will not go .The motor has no short in the winding what can be wrong
If you are sure voltage is going to the motor, then replace the motor brushes if its older than 4 years as they will be worn, what you may find is a broken wire @ the coils......
Apr 13, 2010 | Hoover S3630 WindTunnel Bagged Canister...
How to put the bag on a windtunnel canister s 3630 ?
on the bags there is an arrow to show the direction to install on the bag holder.
Jan 25, 2009 | Hoover S3630 WindTunnel Bagged Canister...
Hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Dec 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
S3765
Returned the sweeper to Costco for a full refund and bought another.
Sep 08, 2008 | Hoover S3765-040 WindTunnel Bagless...
Broken wire reconnected and power was restored.
Jul 13, 2008 | Hoover S3630 WindTunnel Bagged Canister...
Vacuums Logo
52 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
