Question about Indesit WA 125 Front Load Washer
INDESIT WE 125
Washmachine all the time take cold water, I must close valve, because water flow out over drawer to washing powder. I asked for quick help. Many Thanks
  • Indesit Master
  • 3,463 Answers
If the water continues to run into the washer after switching it off, then the water inlet valve is sticking, and needs to be replaced, this is the valve where the hose(s) connect to.
If it stops running in when you turn the washer off, then it is the water level switch that is not working.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
My celcus cwm 1005 wont tack the washing powder
if the machine wont take in the powder
then the machine has no cold water supply
so this is caused by a few things
1} there is no cold water turned on to the machine
or there is a heavy pressure drop in your cold water supply too your home
2} the inlet filter is blocked solid the filter lives at the machine end of the cold water inlet hose... and you use a flat nose pliers to remove it for cleaning
3} the cold water inlet valve has failed
so it never opens so cant wash the soap from the drawer too the drum
i would get a tech too look at it
check the filter and also replace the valve if needed
Feb 08, 2015 | Washing Machines
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
My washing machine is filling up with water when off ,,i'v looked inside soap dispenser drawer I can see drips of water coming in.
you have a faulty water valve turn the cold water off at the main see if the water is still dripping in if it is it will be the hot water valve replace faulty valve they are fairly cheap to buy best to replace both piece of mind you can buy them on line and are easy to replace euro spares will have them if you still need help let me know.
Nov 23, 2012 | Indesit W 123 Front Load Washer
How to remove powder drawer indesit w1a101
see this causes and fix it. God bless you
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front
Sep 27, 2012 | Washing Machines
On the regular cycle for Bosch Nexxt 500 series, during the warm or hot cycle the washer interrupts the cycle with error code "E02" and stops washing . . . how can I fix this? I've made sure the door is...
If the unit is fed by both hot and cold it is possible that the single hot valve or one side of the double cold valve is not operating. Maybe a silly question but could one of the taps have been turned off inadvertently?
The other possibilty is that the pump filter or outlet hoses are blocked and the machine cannot empty the detergent water ready to refill with clean rinse water. To test the cold valve put the w/m on a cold wash cycle, open the drawer and check the water flow. To test the other part of the same valve, put the w/m on the rinse cycle that would take the softener or a wash cycle with prewash. Test hot valve by selecting the hottest cycle usually 90 or 95 degrees, check water flow thru drawer. Hope this helps.
Jul 10, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Can this machine heat its own water? It has a hot and cold water intake. also mashing machine is not taking the powder from the powder drawer. Can you help?
Yes, this washer does have a heating element.
Make sure there is a good water pressure at the inlet valve/s,
or the powder will not dispense.
Make sure there is no blockage or obstruction in the drawer, \also make sure you have the powader in the correct compartment.
Hope this helps.
Dec 20, 2009 | Hotpoint Aquarius WD640 Front Load...
WD 63
Remove dispenser drawer from m/c, and thoroughly clean it and all accessories.Clean all residual build up of undesolved powder and conditioner in drawer compartment..
If it still leaks, then remove top cover, locate large black hose at bottom of dispenser, and give it a good squeeze to clear any possible blockage in the hose itself..
If still no better, could be due to exceptionally high water preesure forcing the water out of the drawer.
Turn cold water valve down a little to reduce pressure.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Water leaking out through powder drawer
please take your drawer out and give a good clean also look inside when drawer is out and clean there as well good luck regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
Water is leaking out of the washing powder drawer
the spray holes in the soap manifold are partially blocked and spraying at an angle. try to reduce the water flow pressure at the feed tap and clean the water holes in the soap tray manifold (above the tray).
Feb 16, 2008 | Whirlpool AWM8143 Front Load Washer
Indesit 1200 washer/dryer instructions
probable cause is just poor water flow from outside. switch water off. undo hoses and check not kinked. in each hose, there should be a gauze filter. clean this. look inside the valve spigot and check no dirt buid-up. put hoses in a bucket and check water flow is ok. remove drawer and check holes in top of box are clear
Jun 14, 2007 | Indesit WA 115 Front Load Washer
Indesit WA 125 Front Load Washer Logo
132 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
