Question about Samsung HP-R5072 50 in. Plasma HDTV
Rectangular Burn In on Samsung Plasma One day after i bought it:(
Just bought a Samsung PS42A418 on sale and i have a huge rectangular burn in nearly in the middle of it :(
I was never made aware that still pictures like the menu on a dvd will cause permanent damage to the plasma and now i just read on the instruction manual that burn-ins are not covered by the warranty :(
I am trying to find out if i can fix it at all before going to the store tomorrow although i very much doubt it that they will be accepting any liability.
On the tv menu there is screen burn protection but it says to prevent rather than to fix.
Can you please help in anyway ? Did not enjoy this damn tv for more than 24 hours :((((
  • VeilVarken Jan 12, 2009
    Yes i slept and the dvd menu stayed on for a couple of hours . . no it was sealed and not a display item . . i am trying to leave it on no signal ( aerial mode) giving black and white dots maybe it will come back to normal.
    Scholar:
  • 87 Answers
No fix for this unit.The panel will have to be changed out and there is no way you did that in 24 hours unless you left it on a still image for several hours.If this was a floor modle it is very common for stores to achive burn in due to long hours on display.
Posted on Jan 12, 2009
Hot surface when oven is on
what is so "safety hazard" about that??,do you put hands on things that are known to be hot?,it is normal and stop putting your hands on things that can burn
Jul 13, 2015 | Kitchen Ranges
1965 falcon sedan resistor
Ignition ballast resistor is usually mounted on the firewall near the back of the engine. It's white, rectangular, and has a wire connector on each end. It's function is to limit primary coil current during engine running. The ballast is bypassed during starting so you get a higher spark voltage. If you remove the ballast, you will burn out your coil.
Feb 23, 2014 | Ford Falcon Cars & Trucks
I have samsung plasma ps-42d4s but it has fault (sound ok but no display) can you help me? plz reply
Hi
This is most probably down to your Y Sustain board, This is situated on the left hand side of your TV when the back is removed, rectangular in shape about 11" by 5-6" Look for the part number on the board and google for a replacement.
The main cause of this is the module that blows under the big heat sink, this can be replaced but i would not advise if you do not have surgery soldering and de-soldering skills!!
Try these guys for a replacement LCD and Plasma TV spares
Feb 02, 2011 | Samsung PS42P2S 42 in. Plasma Television
Intermittantly there is a black rectangular box that appears on the screen for a few seconds then goes away. Our set is 4 years old. Kris 317-201-6643
Turn off close caption in tv, need to go to menu to turn off close caption function, that will solve your black rectangular box problem.
Aug 29, 2010 | SunBriteTV 2300HD 23" TV
Just bought a 50 inch samsung and the lines for the 16:9 ratio are pretty visible all the time, is there any way to get rid of that?
They could be burned in or maybe you just need to hit the P-Size button.. look for that button or it may be called "aspect" or "format" or "ratio"
if the lines are over top of the pic, it is burn in. go in the menu and try to turn on screen burn protection and use the p.size button to eliminate the black bars when you can, so it won't burn in more. after a while the lines will fade away (as long as you don't continue to burn them in further).. best of luck, let me know if you need more assistance
Jul 27, 2010 | Samsung PN42A450 Plasma TV
A couple of days ago I turned on my brand new (about 6 weeks old) Samsung 50'' plasma pn50b650 I noticed an imperfect picture at the top of the screen. Upon closer inspection, there were about 4-5...
U freeze video games 10-20 mins in video game alot of time.Never pause or freeze any kinds of video image in Plasma tv.It very easy cause to burn in Plasma tv problems alots.
Feb 25, 2010 | Samsung PN50B650 50 in. HDTV Plasma TV
How to find rectangular to round transition adaptor
They used to sell them at sears. Its a common duct item for vents. Try home Depot.
Jan 13, 2009 | Samsung SMH7178STD Microwave Oven
Samsung ps42a457 42" plasma tv
Screen burn in will only occur if you keep the same image for an extended period of time. This can be cleared if you send a pure white image to the set until the "burn" is cleared. In normal home usage, burnin is not a problem unless the set is used for gaming all day. No manufacturer will replace a panel due to burnin. Burnin should not be a consideration when selecting a set.
Dan
Sep 19, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Plasmasync 42 (2004)
the screen abnormality is not plasma burn. it sounds like u may have a shorted driver feeding the panel.
its repairable (might not b practicle)
May 01, 2008 | NEC PlasmaSync 42MP1 42 in. Television
My Samsung Plasma just got burned in!
I stupid friend of mine came over to feed my dogs when I was out. He watched my Plasme tv for a while and when he shut the system down he only turned the cable box off for opprox. 6 hours. I did have th Tv on pixal shift . Know my screen seams grainy in dark scenes . I does seem a little better after a rolling picture screen. How long do need to run the screen before it gets better?
Apr 02, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung HP-R5072 50 in. Plasma HDTV Logo
96 people viewed this question
Henry  Thomas
Henry Thomas
