Question about Panasonic Televison & Video
Th-l32x20z how do i update the software when there is no ethernet nic on the tv itself?
Under the setup - system menu there is a 'system update' option. this works well on my other panasonic tvs whixh have an ethernet conection but this model of tv does not have a nic. can i update the system software or is this menu option just teasing me?
SOURCE: Panasonic TH-50PX60U no buttons working
The software in the cpu of this set is damaged you must reload it to fix the problem..
Posted on Dec 18, 2008
  • 21 Answers
SOURCE: TV Screen Stripes
NOt very clear.....
Multiple stripes all over the screen? Vertical or horizontal?
If it's only like an inch vertical lines put a mark on the cabinet where exaclty the line is, turn off the TV then open the back, you'll see lots of ribbon wires (gold color) from the plasma panel it self going to buffer boards, using the mark find the closest ribbon wire where the line is showing then remove and clean the contacts, make sure to reseat it properly when putting it back otherwise you'll just add more lines or black bar on the screen if pins are not seating properly.
But do not be afraid if the lines get worst just turn the power off right away and reaset the ribbon wire till you get it correctly.
CAUTION;
DO NOT try to do this while the TV is on oherwise you'll burn COF (Chip on film) on the panel and you'll end up replacing the whole PDP.
Posted on Mar 11, 2009
dsacco86
  • 1077 Answers
SOURCE: My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
Posted on May 27, 2009
SOURCE: Panasonic 50'' Plasma TV TH-42PX75U - Cannot Control Back Level
Repair it
Posted on Aug 17, 2009
SOURCE: Panasonic plasma TV model TH-42PD60U won't turn on
I had this problem in 2007 / 2008 here is what happened to me. Jan 09, 2008 - I also have brought the unit to the authorized Panasonic repair facility and the problem is a failure in the P-board which is the power supply board. The P-board needs to be replaced. The repair will cost $475 plus tax. $250 is for labor. The unit was nop more than two months out of warranty. This does not speak well for Panasonic. I have been researching the problem and it looks like this has happened to many of the Panasonic plasma TVs.
Jun 14, 2008 - As an update to my problem with the failed P board. Contacted Panasonic Service and talked to a customer service representative. I told them how I have purchased many Panasonic products and how unhappy I was with the failure of the product. They proposed paying the labor cost of $250 and I would pay for the part. I just hope it does not happen again.
Posted on Oct 14, 2009
How can you connect a Toshiba L300 laptop to a Panasonic TH-L32X20Z TV
Your laptop should have a AVG port , run a cable from this to the HDMI port on the TV ,showing AVG port
Feb 25, 2015 | Toshiba Satellite Pro L300 Notebook
Tip
How to find your MAC address using MS-DOS
The MAC address is the physical address your computer's Ethernet card or network interface card (NIC) uses to identify itself to other computers and devices on your network. There are different ways to find your Ethernet card's MAC address, depending on what operating system and programs you have installed. Since most Windows-based computers have access to the MS-DOS command prompt, using DOS to find your MAC address is one standard way to do it.
There are a couple of different tools you can use in MS-DOS to find your MAC address. All of them requiring opening a command prompt window, which you can do by typing "cmd" into the Run bar on the Start menu (or in Windows Vista or 7, you can type it into the Search bar instead).
- Getmac
Getmac is a utility that is included on Windows Vista computers and on newer Windows XP systems. Typing "getmac" by itself on a command line will return the MAC addresses of any NICs that you have installed in your computer. (If you have an Ethernet NIC and a wireless NIC, for example, Getmac will list the MAC addresses for both of them.)
- Ipconfig
Ipconfig is a command that will display your IP address if you are currently connected to a network. However, by adding the "/all" switch to it, you can also see your MAC address, as well as many other configuration settings. Type "ipconfig /all" and look for the line labeled "Physical Address." If you have more than one NIC, the MAC address for each NIC will be displayed separately.
on Oct 04, 2010 | Microsoft MSDOS 6 Upgrade Operating System
Samsung HT-E5400 changes/cycles through sources by itself.
FW Update 001016 will fix your issue on the E5400. Try going to the settings menu and under support check system update. If you can make through the menus it before it cuts you off you should be fine and this will NOT reset your player
Alternatively you must reset the player (I know...) by holding the STOP button on the touch panel for 20 seconds until the screen goes black and it will hard reset. This will take you through the initial setup where you can upgrade free of distraction.
This will not technically FIX the problem of the ghost pushing buttons, but it will at least leave you alone while it plays from your laptop.
Mar 12, 2013 | Audio Players & Recorders
Error message while tryinh to instal broadband says 'No NIC has been installed on this sytem'. working with rather old Compaq Presario S0000
You need to update your drivers for your ethernet card. You can try running Windows Update to find it, or you can search for it on Compaq's website.
To run Windows Update: Go to your start menu and find "Windows Update". Click on it and do everything it asks you to do. If it asks you if you want to run Windows Update Express or Custom, pick CUSTOM. This will take a while. When it is done it should show you many, many updates available. Make sure to click "Hardware" on the left side under optional updates. This will usually have the drivers for your Sound and many other items. Check them all then "Review and Install Updates". Good luck!
May 05, 2011 | Televison & Video
How can I disable a Parental code that has been entered into my tv by some one. The tv is a Sharp Model LC-C4067UN Sharp Aquos
Press the menu button and select 'Parental CTRL' whcih will be located somewhere on that menu or in other submenus. When selected you will be greeted with two options:
  • New Secret No.
  • Secret No. Clear
Choose the 'Secret No Clear' option to clear the parental settings for the TV.
May 04, 2011 | Televison & Video
Update Drivers pour REALTEK8139/810X Family fast Ethernet NIC sur "XP"
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Apr 30, 2011 | Televison & Video
My NIC card is off.Could you help me turn it on?
You can click Start > right click My Computer > then click Properties > and then click Hardware, > then click Device manager > then Under Network Adpaters, click the (+) sign and check if the Intel ethernet card or Broadcom Ethernet card is off. If it is off, then right click the device and click Enable. If it is still off, you may download a broadcom or a intel ethernet driver so that it would update the NIC card. You can check out the intel.com or broadcom.com for downloading instructions. If symptom still persist then contact Dell to set an appointment with a technician to check your NIC card inside your laptop for possible repair.
Aug 17, 2010 | Dell Inspiron E1505 Notebook
What are the two ethernet for? Does it let you plug in both and you can use both at the same time, therefore downloading faster than one or something?
No you can't download any faster with 2 NIC ports.
In a typical setup where a PC has 2 NICs, one is setup as the connection to the internet and the other can be used to interface with any device that is Ethernet capable (home video cameras, alarm systems, home control systems, etc). However, the other NIC can be connected to another network.
You can even share an internet connection though a wall NIC throughout the home.
This means 1 for the internet and the other for networking to another hub/server or computer.
Regards.
Nov 13, 2009 | ASUS A8N-SLI Premium Motherboard
Ethernet port does not work in computer. The cable company set up a USB connection which worked, but now I installed a wireless router. The ethernet cable from the pc to the router does not show a...
Here are some things to check.
  1. In the system setup, ensure that the network adapter is enabled.
  2. Check device manager and see if the driver is properly installed.
  3. If the integrated NIC doesn't work, you can disable it in the BIOS and install a PCI NIC (Less than $20) and the system will work that way.
Sep 30, 2009 | Dell Dimension 3000 PC Desktop
Printer keeps pausing itself!!
dev_24ind: The parallel port cannot be used for printing by default. Heaps of people have made this mistake. You need a N Boot Rom installed and N system software. Almost certainly you don't.
Get a Network Multi PDL Printer Kit C1 for IR3300 (contains N Boot Rom and NIC aka ethernet port). A technician can install this and update system software and you will be able to print. You will be able to print over a network (which is the preffered option) use Remote User Interface and Pull Scan using Canon Network ScanGear (google it).
Aug 26, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Televison & Video Logo
22 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
