Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
Point gap for ford 4000 gas tractor - RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
2 Suggested Answers
  • 13 Answers
SOURCE: tappet settins for ford 4000
My manual unfortunately only lists clearances at operating temperature, great for when you're assembling a cold motor but they should help you out.
Inlet - 0.014 - 0.016th inch (0.355 - 0.406mm)
Exhaust - 0.017 - 0.019th inch (0.431 - 0.482mm)
Regards,
Errol
Posted on Apr 11, 2010
What would make the gas boil in the tank of my ford tractor?series 501 thru 4000 ford tractor
engine could be over heating and heating tank check radiartor coolant
Oct 31, 2014 | Garden
What is the point gap for a 1948 8n ford tractor
The ignition point gap is 0.015" and the spark plug gap is 0.025". More specs here:
http://www.tractordata.com/farm-tractors/000/2/2/223-ford-8n-engine.html
Jun 08, 2014 | Ford 8N Tractor
Points gap for 1953 8 n ford tractor
Here's how to do it:
http://www.ehow.com/how_7368031_set-points-ford-8n.html
set the point gap a .025
Jan 13, 2013 | Ford 8N Tractor
No fire at plugs on golden jubilee ford tractor . I have power to the coil and power out of the coil but can't get any fire.
check and see if the points are gapped, no gap or too wide(not closing) make sure the point set is grounded properly and the connector tab from the points to the terminal is insulated. if you dont find it here then you have a bad condensor. look closely where the terminal comes out of the distributor and make sure the insulator is intact. i have seen people putiing in points loose them and also cracks from the years have led them to rot and when the terminal is turned they just turn to dust. i found one from just 8n's for mine and put it in he has naa parts as well. the trick is the points have to open and close and not be gronded to the hull of the dist. the only ground on the points should be where the screws hold them in the other side (breaking side should not ground) . good luck and hope this helps
Aug 02, 2009 | Ford Tractor Naa Golden Jubilee Emblem
Have new plugs, wires, cap, coil, rotor points, condensor. Still no spark
Check for power getting to the center top connection at the coil.
Are the points opening?
Are they fully closing?
Check for a grounded connection/wire in the dist?
Be very careful how you set the coil onto the dist.
Jul 12, 2009 | Ford 8N Tractor
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
