Question about Canon Pixma MG8120 InkJet Printer
Can I print from my iPad to my Canon Pixma MG8120?
5 Suggested Answers
SOURCE: Trying to connect iPad to
How do I connect canon mp495 to my I pad?
Posted on Feb 17, 2011
  • 10406 Answers
SOURCE: WHERE IS MY ******* SERIAL
The P/N (Part Number) and the S/N (Serial Number) are printed on a sticky-tag, usually found on the bottom of the printer.
Posted on May 21, 2011
SOURCE: how do you get the
The printer automatically chooses the back tray when you specify in your printer setting that you are printing a photo. You can also tell the printer that you want it to print using the tray setting specifically. You do this by going into your printer setup. Find the tab or button that says page setup. From here, you can specify the source for the printer whether is the cassette or the tray. As for the paper, the print faces back (away from you).
Posted on Nov 27, 2011
Angel Bird
  • 287 Answers
SOURCE: error code 6000 canon pixma mg8120 printer when trying to priint wirelessly
Hello and Welcome to FixYa!
Error 6000 actually a line feed error, with the problem originating from the timing disk film or the printer's logic board.
To solve this problem:
Check the timing disk film or Check the feed roller if is there any foreign body, remove it softly
Timing disk film is located at the left side of the printer
If you find my solution helpful for you the your Rating as FIVE STARS will be esteemed.
For further help, you can take my valuable,professional help by taking my Service
Thank you for using FixYa!
Posted on Dec 14, 2011
My Canon MG8120 all-in-one makes a loud noise when copying (not when printing). How do I fix it?
Dear
from the question I understand, the scanner move to right and during return it starts noise.
The problem with scanner assembly, It might be dust accumulated on gears, the scanner belt might have loose or the grips of the belt has worn out. Proper cleaning and lubricating the moving parts may overcome also if the belt worn out it has to be replaced.
In case of at home position it gives noise then the home position sensor may dirty/dusty, it has to be cleaned.
thanks.
Feb 15, 2015 | Canon Pixma MG8120 Wireless Photo...
How do i clean canon mg8120 printhead on the table
Use a q-tip dipped in rubbing alcohol.
make sure you have a tray and some paper towels. The ink may start weeping from the print head when the alcohol touches it.
Aug 18, 2014 | Canon Pixma MG8120 InkJet Printer
Replace pixma printhead
Print heads on this model run about $80 on ebay. Your best bet is to first replace the magenta cartridge even though it may appear to still have ink in it. After that, go into the maintenance menu and run a full cleaning cycle several times. This may clear your clogged print head.
Apr 18, 2014 | Canon Pixma MG8120 InkJet Printer
How do I fix canon mg8120, which is offline.
What have you tried? In order to reset a printer you must unplug it from the power. Just shutting it off wont do it. Try that first.
Aug 03, 2013 | Canon Pixma MG8120 InkJet Printer
How do you get the cannon pixma mg8120 to print using the rear paper feed? should I lay in the paper with the print facing me?
Jul 21, 2011 | Canon Pixma MG8120 InkJet Printer
How do you print an address to an envelope? And can you only print #10 envelopes?
No, you can print on any envelope size. As far as addresses are concerned, you need to setup a template for the envelope size in your program. What program do you have for this function, do you have Microsoft Word or come other word processor like that?
Jul 11, 2011 | Canon Pixma MG8120 InkJet Printer
WHERE IS MY ******* SERIAL NUMBER!!!?!?!?!?!?!!?!? Pixma MG8120
May 21, 2011 | Canon Pixma MG8120 InkJet Printer
What program do I need to install to allow me to print from my iphone4 to my canon pixma mg8120?
The app that you need is called Canon Easy Photo Print
and can be found here if in USA:
http://www.usa.canon.com/cusa/consumer/standard_display/mobileprinting
This page explains the program: how to use it, where to find it, and give a demo of how it works.
The app can be found at the App store for your iphone
or here if you are in Canada:
http://www.canon.ca/inetCA/serviceDetail?m=load&directLink=Y&mid=4504B003&type=D&opt=1
1. Click on drivers and software
2. Select your operating system from the drop down menu
3. Scroll down to the software selection and download Easy Photo Print .
Apr 23, 2011 | Canon Pixma MG8120 InkJet Printer
Canon Pixma MG8120 InkJet Printer Logo
269 people viewed this question
old marine
old marine
