Question about Westinghouse L2046NV Monitor
When power light is green I have no display on the screen
I took my computer to the shop and it is not the computer, it worked fine with there monitor. When I hooked the computer up our monitor we heard the windows sounds as the computer started, but the monitor screen never changed. Black no picture,but power light, green, is on.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Dwanlesso6, Please tell me brand of monitor and if it is LCD/FPD and size 15,17 19 etc. If it is an LCD then it is possible that the DC power supply and or inverter board has failed. Here is short PS101 lesson. All electronic things (Stereo, printer, radio, computer, TV,) all require DC voltage. You get AC Voltage from outlet on wall. the two don't mix. ever!! All the above mentioned things have AC to DC power conversion circuits. They are called power supplys. Only your's and everybody's LCD monitor has two. One makes DC for the monitor logic/digital kinds of stuff, 5.0volts and also makes a
second and higher voltage ( 12v or 15v or 24v) to send to the other power supply which is called an inverter power supply. The inverter PS changes DC into a higher frequency Square Wave AC voltage to power up the Fluorescent Tubes that make your display "bright white" !! Do you own any of those new style light bulbs. You know... the ones that look like small coiled fluorescent tubes and screw into the same socket that previously held the old filiament type of light bulb. Well your dealing with the same technology in your monitor. Just for kicks, you can go to www lcd-monitor-repair. com. Don't pay any attention to the 'advertisement' !!!! just look at the pics of what is inside an LCD/FPD.
The advert just wants you to buy books on LCD/FPD repair.. The best advice I can tell you is try to locate some repair shop that specializes in FPD troubleshooting&repair. Hell, I too am waiting for this 19in GatewayFPD to die. Hope is later.. not sooner, or I'll be in same boat w/LCD/FPD for anchor. Good luck. I'm lmistyrel @ aol north of Chicago been in electronics >3decades
Posted on Jan 13, 2009
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Shut-off while compting. Now it won't power up.I have green light on the power adapter but no green lights on the computer.
that sounds like total power failure. likely a diode or rectifier on the motherboard has blown out, and does not allow the charger to charge the machine or power it. You can take it to a shop where they will try another power adapter. If that works, you are in luck, because a universal power adapter is usually not more than 50 bucks. You might also be able to get a used power adapter for that unit online for about 25 - 40 bucks. If however, the computer shop cannot get it powered up, you are better off replacing that unit. the c640 was fine in its day, but now there are d600's for 250 bucks online, and they are way better. You can also get one (not exactly NEW) off the dell outlet site Outlet.Dell.Com. They have lots of refurbished and "used as a display" computers that work just fine, and come with all the same guarantees as a new one off the line.
Oct 26, 2009 | Dell Latitude C640 Notebook
Power light is green but nothing on the screen
Check the AV cables may be not connected right or the AV cable is broken.
Mar 27, 2009 | Nintendo Wii Console
Apple cinima display problem
have u updated the drivers, i assume u only took the screen in and they linked it up to there macs,
sounds like a driver issue, try an update,
actionman
Feb 26, 2009 | Apple Cinema Display Flat Panel Monitor...
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Westinghouse L2046NV Monitor Logo
254 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
